Mazda3 Rear Wiper Blade & Install Video - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-26-2011, 12:41 PM   #1
jeff618
Moped Rider
Default Mazda3 Rear Wiper Blade & Install Video
None of the autoparts stores stock the Mazda3 rear wiper in my area and I'm assuming others have the same problem. I found the wiper and a installation video:
Rear Wiper Blade: https://www.wipers123.com/product_di...amp;modelhid=3
Rear Wiper ( XX-D ) Install Video: https://www.wipers123.com/wiper_blad...ion_videos.php
I was always told not to force mechanical things, but you have to apply a fair amount of force to snap it out. Its much easier once you see it done.
Hope this helps.
jeff618 is offline   Reply With Quote
Old 03-26-2011, 01:51 PM   #2
smokinamd
Moderator
Send a message via ICQ to smokinamd Send a message via AIM to smokinamd Send a message via MSN to smokinamd Send a message via Yahoo to smokinamd
Default Re: Mazda3 Rear Wiper Blade & Install Video
Alternatively, get a wiper arm off a ford focus hatch and swap it over.
A revolution gets its name by always coming back around in your face.
smokinamd is offline   Reply With Quote
Old 03-26-2011, 01:55 PM   #3
halo0
Moderator of donks
halo0's Avatar
Now figure out a way to increase the pressure of the blade against the window.
halo0 is offline   Reply With Quote
Old 03-26-2011, 01:59 PM   #4
jeff618
Moped Rider
[quote author=halo0 link=topic=188399.msg3975028#msg3975028 date=1301162135]
I don't have that problem. Have you tried cleaning and lubercating the hinge at the base of the wiper arm?
Old 03-26-2011, 02:37 PM   #5
halo0
Moderator of donks
halo0's Avatar
I don't think the pressure has decreased, I just don't think the stock pressure is enough. In the winter it takes a ton of fluid and wiping to get the salt spray off.
Old 03-26-2011, 03:19 PM   #6
smokinamd
Moderator
Fillup, use go buy a focus wiper arm, it's a LOT stiffer. And you can use standard hook wiper blades which are better and cheaper.
A lot of the focus guys swap over to the 3 wiper arm for the "euro" look, That's the one thing I've noticed from my speed to my focus, the rear wiper works a LOT better on the focus.
Old 03-26-2011, 04:53 PM   #7
halo0
Moderator of donks
halo0's Avatar
Eh, the problem is def not big enough to warrant getting a different arm.
