Keyless Entry - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-13-2011, 01:50 AM   #1
B-Squintz
Bicycle Rider
Default Keyless Entry
I have a 2011 Mazda 3 iSport with no keyless entry but have power locks. whats the best way about doing keyless? Thanks.
B-Squintz is offline   Reply With Quote
Old 05-09-2011, 06:49 PM   #2
rogelio
Bicycle Rider
Default Re: Keyless Entry
did you figure this out? I'm in the same boat. Need to add keyless entry for my daughter in law.
rogelio is offline   Reply With Quote
Old 05-09-2011, 07:05 PM   #3
psndbyrgrt
Bicycle Rider
Unfortunately, I am in the same boat for my new car. I have not had any luck with this....I am trying to look into getting an alarm installed at the same time...if I figure it out, I will post it on here.
2009 Mazda3 i Sport 4-Door
psndbyrgrt is offline   Reply With Quote
Old 05-10-2011, 12:26 AM   #4
n4rwhals
Moped Rider
If you have just power locks but no key less alarm, that can be easily done. Just make sure you are going to a reputable stereo/alarm shop. But if you have no power locks, you will have to get actuators with the alarm.
n4rwhals is offline   Reply With Quote
Old 06-19-2011, 07:31 PM   #5
shibbles
Moped Rider
I am also in the same situation. I was wondering if you guys knew any specific kits (just keyless entry, no actuators) that work well with the 2011 models. Thanks
shibbles is offline   Reply With Quote
Old 06-20-2011, 05:27 PM   #6
rogelio
Bicycle Rider
I just installed an inexpensive one. I only use it for door locks but it is a full alarm if you want.
Galaxy G20 from amazon.
Works good. Here is my post about it.
http://www.mazda3forums.com/index.php?topic=190513.0
Old 06-24-2011, 10:08 AM   #7
Hailskins
Bicycle Rider
I just had the Viper 211HV installed at Best Buy for $139, no alarm but the factory keyless isn't either. It has an AUX channel for accesories so I also bought the DEI 522t trunk release actuator off ebay and I am going to install that myself.
Hailskins is offline   Reply With Quote
Old 09-18-2011, 12:14 PM   #8
PandaSmash
Bicycle Rider
Sorry to dig up an old thread. I have a 2011 iSport with the power door locks. The car already should have the receiver for the standard keyless fob, mine did, however if you want to add the switch blade key it does need to be changed. When I get off work I'll post the instruction for the BCM responce so you can test to see if it's there. The ones for the 2011 are slightly different than what was floating around on here last time I checked.
PandaSmash is offline   Reply With Quote
Old 10-10-2011, 10:44 AM   #9
scotta368
Bicycle Rider
Panda, were you able to find these instructions? i have tried all the ones i can find - would be interested to see if the instructions you have would work. thanks
scotta368 is offline   Reply With Quote
Old 10-16-2011, 07:49 PM   #10
shibbles
Moped Rider
I purchased the Viper Keyless Entry System and had it installed at Best Buy. $150 included installation. Works well and even comes with a small blue LED light in the car. Installation took about 4 hours but I dropped my car off and he called me when he was done with it.
http://www.bestbuy.com/site/Viper+-+...;cp=1&lp=1
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2010-2013 Electronics Discussion
