Poor Gas Mileage on 2007 Mazda 3 - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-10-2011, 06:15 PM   #1
jackny07
Bicycle Rider
Default Poor Gas Mileage on 2007 Mazda 3
In the past year or so, I've noticed my gas mileage start to decline. Here's my car info:
2007 Mazda 3 i Touring 2.0
60,000 miles
I consistently get 23-25 mpg. Over the course of a week, I drive about 80% highway, 20% highway. I recently drove from Boston to DC (100% highway) and my gas mileage was about 26.
Here are some things I tried to improve the GM:
changed the air filter
made sure tires are all the same pressure
flushed tranny fluid
changed oil
drove less aggressively
Does anyone have some suggestions as to why my GM is low? Is 25 MPG normal?
jackny07 is offline   Reply With Quote
Old 03-10-2011, 11:20 PM   #2
tim s
Moped Rider
Default Re: Poor Gas Mileage on 2007 Mazda 3
I recently had an issue with a seized brake caliper that was dragging. my gas mileage improved when i fixed it. It's a long shot, but figured i would throw it out there.
tim s is offline   Reply With Quote
Old 03-11-2011, 01:06 AM   #3
fjaysay1017
Short Track Racer
If it's 100% highway, I wouldn't say that a normal mpg. Especially for 2.0 engine. I would say, clean out your MAF sensor and TB if that helps.
If not, you might wanna get a complete fuel system cleaner by the dealership. Overall, I heard that would increase your mpg by far.
fjaysay1017 is offline   Reply With Quote
Old 03-12-2011, 12:41 PM   #4
captjeffro26
Moped Rider
I have a 30-40 minute ride to work every day. It is all highway. My speed average 70-85 mph and I average about 25-26mpg. I have an 05' 2.0 ATX. On longer trips I get better around 30ish. Ive noticed its not necessarily the speed, but the consistency of speed. I use my cruise as much as possible and it seems to help.
Captjeffro26
2005 Mazda3 i
captjeffro26 is offline   Reply With Quote
Old 03-12-2011, 01:12 PM   #5
adumbrille
adumbrille's Avatar
I'd say get your fuel injectors cleaned. It's like 80 bucks at a jiffy lube. Do that and add a bottle of gum-out to your gas for 1 tank. I noticed my mileage go up after I did this by about 2 mpg. My car only has 25k miles though, so yours might see a bigger improvement.
Build Thread:
http://www.mazda3forums.com/index.php?topic=188505.0
adumbrille is offline   Reply With Quote
Old 03-12-2011, 03:31 PM   #6
Mummyman
Send a message via AIM to Mummyman
There is no need to goto the dealership or Jiffy Lube to clean your injectors. Buy a few bottles of Redline Si-1 off Amazon and you are good to go. Chevron Techron is good as well and can be found at retail outlets.
2004 Sunlight Silver 3i
Mummyman is offline   Reply With Quote
Old 03-21-2011, 03:00 AM   #7
P8N49025
Moped Rider
Lucas Oil Fuel Injector Cleaner is the best. Not only cleans injectors but also improves gas mileage just with what's in it. I try to use a bottle of that stuff in every tank, it's fantastic.
P8N49025 is offline   Reply With Quote
Old 04-11-2011, 02:55 AM   #8
Blkdoutm3
Bicycle Rider
I have had the same exact problem and the fix was very simple. All i did was replace the spark plugs with the recommended plugs from autozone and it went right back up to normal wich was 100 miles per 1/4 tank
Blkdoutm3 is offline   Reply With Quote
Old 04-18-2011, 08:23 PM   #9
Greggy_D
Short Track Racer
[quote author=P8N49025 link=topic=187562.msg3968927#msg3968927 date=1300687224]
No it is not. Not by a longshot.
You need a Fuel System Cleaner that contains PEA (which Lucas does not). That leaves a very short list:
Redline SI-1 (as mentioned above)
Gumout Regane (in the clear bottle)
Chevron Techron (fuel SYSTEM cleaner......not the fuel injector cleaner)
Greggy D.
Greggy_D is offline   Reply With Quote
Old 04-18-2011, 09:14 PM   #10
g3ck0
Wow, I gotta try this stuff out. I'm happy to get 21mpg on my car!
g3ck0 is offline   Reply With Quote
