04 mazda 3 i low idle @ stop with barke applied - Mazda3 Forums : The #1 Mazda 3 Forum
Old 01-24-2011, 01:48 PM   #1
ktm181
Bicycle Rider
Default 04 mazda 3 i low idle @ stop with barke applied
I have a 04 mazda 3 I 2.3L Auto. At a stop with brake applied in drive, engine idle drops to around 450 rpm. If I let off the brake ,still in drive it returns to normal 700 rpm. in neutral or park with brake applied it has normal 700 rpm.
if I remove the Horn fuse the idle is normal in all gear positions and all brake application.
No CEL and car runs great besides the idle issue.
New spark plugs, cleaned throtel body, Newupstream o2 sensor. no help.
Can anyone help with this issue?
ktm181
ktm181 is offline   Reply With Quote
Old 01-27-2011, 02:41 PM   #2
Frezz
Short Track Racer
Default Re: 04 mazda 3 i low idle @ stop with barke applied
Clean the throttle body of the car. Will fix this issue I promise
Frezz is offline   Reply With Quote
Old 01-27-2011, 03:33 PM   #3
andrew1501
i cleaned mine as well but it does it regardless. You have to understand that when you have an automatic its coupled to the engine by the torque converter. I would say that the ecu lowers the rpms when you press on the brake to help engage the the other side of the torque converter more gently. I could be wrong but i don't see any other reason as to why it would do that. it will also do it in park as well, so its not physically loading the torque converter or anything
andrew1501 is offline   Reply With Quote
Old 01-27-2011, 04:05 PM   #4
dtravman
This is just an economical fuel map. At idle, it drops really low and runs leaner to use less fuel overall. Turn on your air conditioning at idle and watch your RPMs go up a little, the AC makes that much of an actual difference in power
[[glow=red,2,300]Oo[/glow]|SKYLINE|[glow=red,2,300]oO[/glow]]
dtravman is offline   Reply With Quote
Old 01-27-2011, 04:06 PM   #5
Hexedit
Super Moderator
Send a message via AIM to Hexedit Send a message via MSN to Hexedit
Look up PCV replacement. That is more than likely your issue.
Titanium Grey HB 5 spd, ABS, Moonroof, Leather seats, Exel RS-GT 17x7.0 Hyperblack 225/45/17 Azenis RT-615, Racing Beat Front/Rear Sway + Endlinks, Mazdaspeed MSP3 Coilovers, 88 AWR Mount, Apexcone 6000k HID, I deturboed my car and removed my built engine. I'm now stock powertrain + an Injen.
Hexedit is offline   Reply With Quote
Old 01-27-2011, 04:27 PM   #6
ktm181
Bicycle Rider
I have already cleaned the throttle body, and it didn't help.
I have owned the car since day 1 and it has just started this issue. always held a steady 700 rpm at idle before no matter what gear or brake position.
now the idle gets so low that it runs rough and feels like it may stall. again only in drive with brake applied.
Idle is normal with AC on .
Thanks everyone for your input, keep it coming.
ktm181
Old 01-27-2011, 05:42 PM   #7
andrew1501
if it's going low enough that it has a rolling idle, then it is probably an EGR hanging open a bit. if you can get a vid and post it that would be great.
Old 01-27-2011, 09:03 PM   #8
ktm181
Bicycle Rider
I thought about the EGR also and I did look at it, seem to me moving freely, I did not remove it and clean it yet though. But if it were the EGR I should get a low / rough idle in drive without the brake applied or in park. And why would it idle normal in all gear and brake positions when I remove the horn fuse. Its got me puzzled.
I will check the PVC and the EGR again.
Thank you for the ideas.
ktm181
Old 01-28-2011, 10:50 AM   #9
Hexedit
Super Moderator
[quote author=ktm181 link=topic=185300.msg3918079#msg3918079 date=1296180215]
ktm181
I'm not 100% sure how to test the PCV valve; however, replacing it fixed all my idling problems.
Old 04-30-2012, 12:30 PM   #10
chamaco
Grand Am Series
sorry for reviving this thread, but i'm having the same issue with my 04 2.3 ATX. i want to know if by any chance the OP figure out if replacing the PCV helped or what he has done to fix it?
thanks
chamaco is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Powertrain 2004-2009 Mazda3 > Powertrain Technical Information, FAQ's, How-To's
