MAF Sensor Cleaning.. - Mazda3 Forums : The #1 Mazda 3 Forum
Old 10-14-2010, 04:37 PM   #1
FuzzySlippas33
Default MAF Sensor Cleaning..
What's going on guys? I posted a problem I was having with my car earlier in the week and every one seemed to think I need to clean my MAF sensor (I did check my wires and they all seem to be intact with no pinching occuring). Tomorrow Im going to autozone and buying MAF cleaner, so I wanted to ask how should I clean it? I've read that the sensor is a delicate part and I dont have $100 to throw around to replace it. Any help would be appreciated. I figure if the cleaning doesnt work then I'll have to just buy another one. Thanks
Magnaflow Exhaust | Eibach Pro-Kit | TWN Short Shifter | Skunk 25th Anniversary Weighted Knob | Alpine 7" DVD/CD/Navi System | MS3 Wheels | Custom Painted Interior
http://www.mazda3forums.com/index.ph...292#msg3642292
FuzzySlippas33 is offline   Reply With Quote
Old 10-14-2010, 05:01 PM   #2
jplus
Default Re: MAF Sensor Cleaning..
just remove the MAF sensor, spray the shit out of it with the cleaner, let it dry for a minute and re-install it, might want to spray the connectors as well
people post more than me
jplus is offline   Reply With Quote
Old 10-14-2010, 05:05 PM   #3
FuzzySlippas33
so if you spray the wires no harm will be done? And just too make sure...the MAF is connected right before the air intake (i have stock) you disconnect the wires, unscrew the screw, pop it out and spray it? Sorry I'm kind of a newb..
Old 10-14-2010, 05:26 PM   #4
cab0oze
Senior Member
cab0oze's Avatar
[quote author=FuzzySlippas33 link=topic=180887.msg3828320#msg3828320 date=1287090359]
[/quote]pretty much, yeah. I think there is 2 screws. Do not overtighten and strip them, they do not need to be tight at all (note tightness when removing)
And yeah, just use the cleaner and spray it good, you'll be fine. The spray will clean it off (its essentially just isopropyl (rubbing) alcohol) and then evaporate. Once its all dry, put it back in.
Just DO NOT DROP IT.
cab0oze is offline   Reply With Quote
Old 10-14-2010, 05:28 PM   #5
FuzzySlippas33
Thanks for the replies guys, hopefully cleaning the MAF will solve all my problems. I feel bad for my car with all the abuse its taken from this..
Old 10-15-2010, 11:01 AM   #6
haste
Short Track Racer
just did this on my girlfriends '04 hatch with 60k miles on it a few weeks ago and it did make a little difference in the "pep" of the engine. mileage was not affected at all though. still getting crap mileage...
can you till which part of the maf was on the intake side?
[img width=768 height=768]http://haste.4saken.org/pics/mazda3/maf/maf1.jpg[/img]
[img width=804 height=768]http://haste.4saken.org/pics/mazda3/maf/maf2.jpg[/img]
TWM SS, AWR 70 Dur RMM, Flex Innovations Big 3 w/throttle body ground
haste is offline   Reply With Quote
Old 10-16-2010, 07:16 AM   #7
cab0oze
Senior Member
cab0oze's Avatar
good pics... and thats nasty looking lol
Old 10-16-2010, 12:23 PM   #8
FuzzySlippas33
Mine didnt even look that bad, but never the less it didnt help my problem..
Old 10-16-2010, 01:01 PM   #9
Mindless
Mindless's Avatar
what's the problem? rough idle?
^ Click to see Build page^
Mindless is offline   Reply With Quote
Old 10-16-2010, 01:33 PM   #10
Retrobmx63
Go-Kart Driver
[quote author=haste link=topic=180887.msg3828988#msg3828988 date=1287154861]
Just want to make sure you and others know, the water drop looking thing is only the IAT sensor. To clean the actual MAF, be sure to spray the cleanup up into the MAF. That is where the tiny wires are that read the airflow.
Retrobmx63 is offline   Reply With Quote
