TL TYPE S RIMS - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-15-2010, 11:28 AM   #1
WhiteHot3
Short Track Racer
Default TL TYPE S RIMS
ANYONE KNOW IF TL TYPE S RIMS WILL FIT ON THE 05 3 I THINK ITS THE SAM LUG PATTER 5X114.3??? RIGHT???
THANKS
Just Vibe Son
WhiteHot3 is offline   Reply With Quote
Old 03-15-2010, 11:32 AM   #2
halo0
Moderator of donks
halo0's Avatar
Default Re: TL TYPE S RIMS
[quote author=WhiteHot3 link=topic=168476.msg3568666#msg3568666 date=1268663305]
THANKS
Your lug "patter" is correct, however there are many other factors that go into determining whether they will fit, and how well. Diameter, width, offset, tire size, etc etc etc.
halo0 is offline   Reply With Quote
Old 03-15-2010, 11:34 AM   #3
xtasy
Send a message via AIM to xtasy
[quote author=halo0 link=topic=168476.msg3568668#msg3568668 date=1268663543]
THANKS
WHAT HALO JUST SAID
Stormy Blue Mica Mazda3 2.3 ATX w/ I/H/E Tune RSB/Springs: Traded in for...
Mazdaspeed3 Black Mica Stock as of 3/22/11: Cobb SRI/TIP, Street Unit TP, Cobb AP, CXRacing FMIC, RX8 wheels and other "good looking" mods
xtasy is offline   Reply With Quote
Old 03-16-2010, 10:01 AM   #4
laraw
Super Moderator
Send a message via AIM to laraw
Well, according to some research, the Acura TL Type S rims are as follows:
Bolt Pattern: 5x114.3
Offset: +55
Hub Bore: 64.1mm
If you get the hub bored out (our cars take 67.1), they'll work just fine... provided the stats I found are correct.
2007 Mazdaspeed6 GT in Black Mica
AutoEXE | Cobb | Corksport | Gram Lights | H&R | HKS | SURE | TWM
laraw is offline   Reply With Quote
Old 03-16-2010, 10:18 AM   #5
sumthaiguy
Send a message via AIM to sumthaiguy
WAAAATTTT YEEARRRR TTTLLLL DID THEEEE WHEEEELSS COMEE OFF OF!?!
if its these^ then the specs are
17x8 +45
i dont know the hub size but if you get a spacer or bore it to clear the hub then the wheels should fit fine.
sumthaiguy is offline   Reply With Quote
Old 03-16-2010, 10:32 AM   #6
laraw
Super Moderator
I just went off what I found here: http://www.acuraworld.com/forums/f46...tlp-cls-24432/
Old 03-16-2010, 11:05 AM   #7
sumthaiguy
thats why i asked what year the wheels are from. the specs ^you posted are of the wheels off of a 2000-2003 TL Type s.
Old 03-16-2010, 12:23 PM   #8
laraw
Super Moderator
Good catch!
Old 03-16-2010, 08:27 PM   #9
six
theykickedmeoffnasioc
six's Avatar
[quote author=sumthaiguy link=topic=168476.msg3570245#msg3570245 date=1268745488]
17x8 +45
For a while I seriously thought about trying to track some of these down, I may still eventually go for it. Theyre secks
six is offline   Reply With Quote
Old 03-16-2010, 09:34 PM   #10
a-sher
Send a message via AIM to a-sher
pretty sure i saw a set of them on rsxclub the other day, im eyeing up some weds on there
a-sher is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Wheels / Tires
