RPF1 vs PF01 in terms of weight - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-12-2010, 04:44 AM   #1
r2rrita
r2rrita's Avatar
Default RPF1 vs PF01 in terms of weight
I did a little research and found the actual weights on some of the PF01 17" and 18" rims according to tirerack.com
These are all 5X114 bolt pattern
RPF1 PF01
17X7 45mm 14.6 lbs 17X7 48mm 15.8 lbs
17X7.5 48mm 15.2 lbs 17X7.5 45mm 16.6 lbs
17X8 45mm 15.6 lbs 17X8 45mm 17.2 lbs
17X8.5 40 mm 16 lbs 17x8.5 40 mm 18 lbs
18X7.5 38mm 17.4 lbs
18X7.5 48mm 17.6 lbs 18X7.5 45mm 17.6 lbs
18X8 35mm 17.8 lbs 18X8 45mm 18.2 lbs
18X8 40mm 18.6 lbs
18X8 42mm 18.2 lbs
18X8.5 40mm 18.3 lbs 18X8.5 45mm 18.0 lbs
18X8.5 30mm 18.3 lbs 18X8.5 30mm 19.2 lbs
18X8.5 35mm 18.6 lbs
edit: update info (4.29.10)
they said:
"The ENKEI PF01 is designed to be an ultra light-weight wheel and is engineered to exceed the RPF1ís weight benefit, taking Enkeiís light-weight racing wheel line to the next level."
From the data above RPF1 is still the clear winner.. Hopefully enkei will post PF01s actual weight on their website and remove the post "weight in engineering stage"
Buddy Club Racing Condenser||AEM CAI||5000k ddm slim hid kit (FOGS)||smoked LED markers||Mazdaspeed 3 OEM rear wing||CP-E 75 DURO||Borla CBE||TWM short shifter and shift knob||Mazdaspeed3 OEM Sway Bars||Hypertech Tune||17x8 RPF1
r2rrita is offline   Reply With Quote
Old 03-12-2010, 04:51 AM   #2
cali_axela
Default Re: RPF1 vs PF01 in terms of weight
You can't say the rpf1 is the winner based on those unequal comparisons, the offsets are different on most of those. The few lines where the offsets are similar, so are the weights.
EDIT: wow, except the 17x8, that better be a mistake... there's no way it's going to be 1.5 lbs heavier in the same size and offset... and least I hope not!
Old 03-12-2010, 05:01 AM   #3
r2rrita
r2rrita's Avatar
I do understand that they have different offsets and it becomes also a factor in weight but the hype that enkei advertised about PF01 that it would be better than RPF1s..
I guess i'm expecting too much out of the PF01s..
Old 03-12-2010, 05:02 AM   #4
cali_axela
Yeah, I agree, so far I'm skeptical too but I'm giving them the benefit of the doubt until there's more info.
Old 03-12-2010, 05:06 AM   #5
r2rrita
r2rrita's Avatar
[quote author=cali_axela link=topic=168260.msg3565326#msg3565326 date=1268387480]
Yes, thats the weight posted if you search Honda civic SI on tirerack.
link: (I hope link works)
http://www.tirerack.com/wheels/resul...amp;sort=Brand
Old 03-12-2010, 04:19 PM   #6
Argon408
Short Track Racer
Call Enkei and talk to King. They weighed all the wheels when they arrived from Japan. I was told mine were 17.08 lbs (18x7.5 +45). Didn't have a scale to weigh them myself though.
Argon408 is offline   Reply With Quote
Old 03-12-2010, 08:34 PM   #7
tigermack
tigermack's Avatar
Send a message via AIM to tigermack Send a message via Yahoo to tigermack
Saw the weight thing on other forums, too. Honestly, I am a little disappointed as I expected all of them to be lighter but at least .5-1 lb and definitely not heavier.
tigermack is offline   Reply With Quote
Old 03-14-2010, 04:18 PM   #8
phate
Simply because the wheels weigh more overall does NOT mean that more power is required to turn them...Unless you know the mass distribution around the wheel, then you don't know the whole story. Said another way, if that mass is more heavily centered on the inside of the wheel radius, then there is less mass on the far edge of the radius, which would result in less effort required to spin the wheel.
Simply think about a lever with an endpoint as the fulcrum. Where you put the mass on that lever is what defines the required energy of movement.
Corn Fed 2007 MS3
phate is offline   Reply With Quote
Old 03-14-2010, 04:28 PM   #9
andrew1501
[quote author=phate link=topic=168260.msg3567814#msg3567814 date=1268597926]
very true
andrew1501 is offline   Reply With Quote
Old 03-14-2010, 11:03 PM   #10
r2rrita
r2rrita's Avatar
true true, the way PF01 is designed, the spokes are spread out compared to the RPF1s so there is a possibility the mass distribution is more on the center. Looking at the design structure of PF01 gives more integrity compared to the design structure of the RPF1s so it is really possible to have lighter mass with the further diameter of the wheels.
Hopefully enkei would justify their statement on the PF01 being better than RPF1 and post the actual weight of these wheels.
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Wheels / Tires
