key stuck in ignition? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 01-25-2010, 07:44 PM   #1
idkjack12
Go-Kart Driver
Default key stuck in ignition?
i tried searching but i guess no one has had this problem ?
i have an 04 mazda3 and lately the key has been getting harder and harder to pull out of the ignition when i turn my car off.
it inserts fine and turns on with no problems, its just the pulling out. tonight i had to use 2 hands.
has anyone else experienced this kind of problem? tips/tricks please ? wtf..?
15% Tint | Pioneer AvicD3 in-dash | Apexcone 5k HIDs | Custom Faux Leather Seat Covers | 12" Rockford Fosgate sub | Black suede door inserts | white LED interior
idkjack12 is offline   Reply With Quote
Old 01-25-2010, 07:46 PM   #2
shwelan
Default Re: key stuck in ignition?
wd-40? ahha i dont know if that well eff anything up.
maybe she just doesnt like you pulling out?
got over the mod bug finally...just gunna keep this baby in tip-top clean shape
shwelan is offline   Reply With Quote
Old 01-25-2010, 07:48 PM   #3
DrWebster
Moderator
DrWebster's Avatar
Do you have an automatic transmission or a manual? The MTX cars have a little button you need to press next to the ignition cylinder to release the key, maybe yours is wearing out?
DrWebster is offline   Reply With Quote
Old 01-27-2010, 08:17 PM   #4
idkjack12
Go-Kart Driver
[quote author=shwelan link=topic=165800.msg3514168#msg3514168 date=1264466783]
[/quote]lmao
and no, i have an automatic.
one of my friends told me the key is wearing out. but i've never heard of that so idk if that has any merit?
i also thought about greasing it up, but i dont want to risk messing things up further ?
Old 06-17-2010, 08:07 AM   #5
mhikeboy
Bicycle Rider
I do not know if this reply is still valid, However, since you have an auto trans, you need to place the gear in "Park" or in "Neutral before you can pull the key out from the ignition. I think this is a safety feature to make sure that you are not in "Drive" when you start the car.
mhikeboy is offline   Reply With Quote
Old 06-17-2010, 09:28 AM   #6
Noisy Crow
Noisy Crow's Avatar
[quote author=mhikeboy link=topic=165800.msg3699945#msg3699945 date=1276776425]
Yup. The ignition assembly has a solenoid that is activated by the gear selector. If the solenoid fails or sticks you wont's be able to remove the key. Solution (I believe) is to replace the ignition assembly... I don't think the solenoid can be replaced separately.
Noisy Crow is offline   Reply With Quote
Old 06-17-2010, 11:14 AM   #7
mikesta
Send a message via MSN to mikesta
Time for a new lock buddy... I have an 04 auto and recently had my lock changed, the good news is they can just change the tumbler in the lock bad news is... 2nd key is given... do it now before it gets to bad, I ignored it as it wasn't always getting stuck then one day I couldn't get it to turn at all after 20-30 times and it just worked took it to mazda and they opened it up and told me new tumbler is the fix and they loosened it or something so I was okay until the new tumbler was installed... anyhow thats the answer
Just got a g35, but will hang with the 3 crowed
mikesta is offline   Reply With Quote
Old 03-03-2015, 11:29 AM   #8
wetz
Bicycle Rider
Default
Is a new ignition the only solution? Anyone have luck with graphite lube?
wetz is offline   Reply With Quote
Old 03-03-2015, 07:53 PM   #9
cab0oze
Senior Member
cab0oze's Avatar
Default
Quote:
Doesn't hurt to try the lube... worst case you end up needing a new ignition anyway, right? =/
Just don't overdo it.
cab0oze is offline   Reply With Quote
