Wheel fitment help - Mazda3 Forums : The #1 Mazda 3 Forum
Old 01-18-2010, 07:02 PM   #1
Silentwolf3
Short Track Racer
Send a message via Yahoo to Silentwolf3
Default Wheel fitment help
So im looking into getting some Tenzo rims, but im not sure if they will fit my car with it being lowered so i need some help... the specs i would be running are 225/35-40 R18 with a 42mm offset.. would this fit or no :shock:
Silentwolf3 is offline   Reply With Quote
Old 01-18-2010, 07:28 PM   #2
cali_axela
Default Re: Wheel fitment help
You want 225/40/18 tires, not 225/35/18. And those will fit fine, but you'll need to roll your rear fenders to completely prevent rubbing.
Old 01-18-2010, 07:54 PM   #3
Silentwolf3
Short Track Racer
howe fenders rolled?
Old 01-18-2010, 10:02 PM   #4
sumthaiguy
Send a message via AIM to sumthaiguy
well to fully know of how they will fit, we'll need a width. 7.5? 8.5? 11.5? width is a big factor in fitment. and if you were to get any kind of decent width/fitment you will need to roll fenders.
sumthaiguy is offline   Reply With Quote
Old 01-19-2010, 02:14 AM   #5
Silentwolf3
Short Track Racer
its 7.5 width.. and was planing on putting 225's on them
Old 01-19-2010, 02:22 AM   #6
sumthaiguy
should work no problem. i dont think you need to roll fenders either. stockers are 18x7.5 53. your new wheels will stick out only 10mm. out of curiousity, what is your current setup? is it similar to the new setup?
Old 01-19-2010, 02:28 AM   #7
ryukensfj
Send a message via AIM to ryukensfj
[quote author=sumthaiguy link=topic=165237.msg3503752#msg3503752 date=1263882170]
I think stockers are 18x7 with +52.5.
08 CWP Mz3 S Sport 2.3l 4dr
Current mods:F2 turbo kit, F2 exhaust, F2 BSD, F2 oil baffle kit, F2 rear swaybar, N9TH Racing Trunk Brace, KW V2 Coilovers, SPC Rear Camber Links, Medieval RMM, WORKS RSV with Dunlop Direzza Sport Z1 Star Specs, FI Grounding Kit, RKM STS, XenonExpert pedals, 15% tint, 35w DDM 6000K HIDs, Interior LEDs, Lamin-X Yellow Fogs, Sharkfin Antenna
ryukensfj is offline   Reply With Quote
Old 01-19-2010, 01:53 PM   #8
Silentwolf3
Short Track Racer
running stockers, with the H&R lowering springs
Old 01-19-2010, 02:43 PM   #9
a-sher
Send a message via AIM to a-sher
roll the fenders, check around local tuner shops they should have the tools to do it, got mine done at 35 a fender which is very reasonable
a-sher is offline   Reply With Quote
Old 01-20-2010, 01:42 PM   #10
Silentwolf3
Short Track Racer
hey everyone.. so i went and test fit the rims.. and they fit perfect.. i acually test fitted with 245/40R18 and i still had plenty of clearance.. the 245 stuck out just a slight bit, but i wont be using those.. ill be putting 225's on there, i think im safe with out rolling fenders, and it will be a perfect fit...
i appreciate everyones help, and as soon as i put tires on it, ill take pics for everyone to see
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Wheels / Tires > Wheels / Tires Technical Information, FAQ's, How-To's
