Mazda 3 electrical problem - Mazda3 Forums : The #1 Mazda 3 Forum
Old 12-27-2009, 10:37 PM   #1
caddosmith
Bicycle Rider
Default Mazda 3 electrical problem
I have 2005 Mazda 3. Yesterday both turn and hazard signals, electric door locks and high beam indicator quit working and the brake warning light came on and stayed on. All fuses inside and under the hood checked out OK. Plenty of brake fluid. Any ideas
caddosmith is offline   Reply With Quote
Old 12-28-2009, 01:44 AM   #2
ekanddsm
Default Re: Mazda 3 electrical problem
Is the connector on the left side of the instrument cluster plugged in?
Sitting in the drivers seat.
So you have a fast______(your cars name here)????
ekanddsm is offline   Reply With Quote
Old 12-30-2009, 05:11 AM   #3
MzrL5
Go-Kart Driver
try unplugging all connectors to PJB and then reconnect it.If that dont work you might need a new one. its located under glove box
MzrL5 is offline   Reply With Quote
Old 12-30-2009, 05:43 PM   #4
SpyderMonkey
Go-Kart Driver
[quote author=caddosmith link=topic=163738.msg3473061#msg3473061 date=1261967845]
I have this same exact issue, I can't figure it out and don't have the funds to be ripped off by the dealership
SpyderMonkey is offline   Reply With Quote
Old 01-01-2010, 06:11 PM   #5
caddosmith
Bicycle Rider
Thanks to MZRL5 suggestion of unplugging all the connections on the PJB and reconnecting them it solved the problem.
Thanks again
caddosmith
Old 01-08-2010, 03:10 PM   #6
SpyderMonkey
Go-Kart Driver
I forgot to reply, but yes, it was the connections on the PJB... thank you!!!
