PLEASE Need Help with Engine Swap On 2004 Mazda 3 2.3L 5-Speed ! - Mazda3 Forums : The #1 Mazda 3 Forum
View Poll Results: Need to replace 2.3 engine on my mazda 3
2.3L engine from automatic to my 5-speed 1 100.00%
2.0L will it fit? 0 0%
Voters: 1. You may not vote on this poll
Old 11-24-2009, 06:11 PM   #1
palka_usa
Bicycle Rider
Default PLEASE Need Help with Engine Swap On 2004 Mazda 3 2.3L 5-Speed !
Professionals, i need help bad! I have 2004 mazda 3 2.3L 5-speed. My engine died and i need to find the cheapest way for my car too be running.
1. I looked for 2.3 engine and come across problem. Online they separate automatic and manual. Can i buy engine from automatic mazda and put it in my? are the engines the same?
2. I found online 2.0 engine twice cheaper then 2.3L . againe i need to fix my mazda3 cheap. Can i buy 2.0L and stick it in my car? will i need to change anything? in order to to this swap, should i buy new main computer, transmission for 2.0L engine? new speed sensor or speedometer for 2.0?
Thanks for your help!
palka_usa is offline   Reply With Quote
Old 11-24-2009, 06:24 PM   #2
palka_usa
Bicycle Rider
Default Re: PLEASE Need Help with Engine Swap On 2004 Mazda 3 2.3L 5-Speed !
By the way, My email is : kudravets@gmail.com
Thanks again everyone!
Old 11-30-2009, 03:57 PM   #3
ekanddsm
just swap the front pulley and intake cam from the old engine to the new engine whatever you put in, and it should start, but not run anywhere close to what it is supposed to.
So you have a fast______(your cars name here)????
ekanddsm is offline   Reply With Quote
Old 11-30-2009, 08:49 PM   #4
gismo51
Bicycle Rider
I'm kinda new to Mazda ownership but AFaIK most injected engines are ECU specific. I'm guessing that you'll need a ECU for the 2.0L engine.
gismo51 is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Powertrain 2004-2009 Mazda3 > Powertrain Technical Information, FAQ's, How-To's
