Replaced Battery Car...Car Stalls at Stops - Mazda3 Forums : The #1 Mazda 3 Forum
Old 09-25-2009, 09:42 PM   #1
Crazimon
Bicycle Rider
Send a message via AIM to Crazimon
Default Replaced Battery Car...Car Stalls at Stops
I have a 2005 Mazda 3i - 2.0L. Nothing special. Your typical stock car.
I just replaced the original battery today, and now my car stalls when coming to a stop. Has never done this before. WTH!? Took back to auto store to check battery. Battery & alternator are fine.
Any issues with reset after replacing battery? Help!
Crazimon is offline   Reply With Quote
Old 09-25-2009, 10:49 PM   #2
jason99
Grand Am Series
Default Re: Replaced Battery Car...Car Stalls at Stops
The only thing I could think of is the ECU is still learning, but honestly, I've only ever seen a car stall out once when the ECU was reset. After restarting the car kept running.
Are your connections tight? Did you scrub the terminals before installing the battery?
jason99 is offline   Reply With Quote
Old 09-25-2009, 10:52 PM   #3
Crazimon
Bicycle Rider
Yeah, everything looked good. Only thing that reset was the tripometer & the radio stations.
Well, I took it around the block after letting it sit for a couple of hours...no problems. Should I get diagnostics run on it?
Old 09-26-2009, 09:54 AM   #4
azazel1024
Senior Member
My guess would be that you didn't put on the battery cables correctly and one is coming lose, though this likely wouldn't stall it (as the alternator would run the electrical system).
Other guess is that the ECU was still relearning things and came to to abrupt of a halt during its learning process (it doesn't 'catch' itself as well if revving or dropping RPMs until it has relearned things after a few minutes of warmed up driving and idling).
-Matt
[quote author=crazyduckme]
Yay for doing it by hand then! That will probably last about an hour tops.I was craving meat REALLY bad. plus, my mom gets really hot, so I was uncomfortable. So I have to really stretch.
azazel1024 is offline   Reply With Quote
Old 09-26-2009, 08:27 PM   #5
DrWebster
Moderator
DrWebster's Avatar
When the car stalls, does everything electrical in the car die? Because if it was a battery connection problem, you'd see lights go out and whatnot.
I suspect your problem is due to a failing fuel pump...this is what happened to my old car (and was ultimately what made me decide to be done with it and trade in for my 3). I think you replacing the battery around when it started happening is just a coincidence.
DrWebster is offline   Reply With Quote
Old 09-26-2009, 08:39 PM   #6
Oricle
Senior Member
how many miles does the car have, and when was the last time you cleaned the MAF?
[img width=379 height=100]http://img.photobucket.com/albums/v446/oricle/sig38.jpg[/img]
Oricle is offline   Reply With Quote
Old 10-12-2009, 08:50 PM   #7
tnmats
Go-Kart Driver
[quote author=Crazimon link=topic=157018.msg3341758#msg3341758 date=1253929350]
Wow, our cars must be freakin' twins. Same symptoms, started the same way.
My 2005 3s had a suspect battery so I went to AutoZone to have it tested yesterday (10/11). Under load the old unit put out 280A so time for a new one as this one is 1 mo. shy of 5 yrs. Put the Duralast Gold unit in there, drove it home. I pulled the battery when at home to clean out the battery container box (the crummy OE Panasonic unit once had some battery fluid spill over, crudded up the bolts underneath). Slathered silicone grease on the connectors, re-installed the battery and drove it around last night with no issues I detected, but my wife (who was driving it really) said she once felt a stumble. I never felt it. Note the car was warmed up when we took it out last night.
Today the wife takes it out, drove it from a cold start and last evening the temps dropped about 20F from the evening before. About 3 mi. from the house she calls in a panic that the car had stalled out but cranked just fine. She also told me that the trip odo hadn't reset nor had the clock/radio presets. Tell her to tool it back to A/Z to have the battery checked. Pegs their tester at 650A, no issue with battery. Guy checks the battery cable connections, tight as they should be. Put the alternator under load, tested okay he says. Then he checked for any codes in the ECM, nada. He thought maybe the ECM was relearning, didn't know what else could be wrong. Suggested gas may be bad, but the car has been running on the same tank for 250 mi. so far with no issues until the battery was replaced.
She drove it more, never stalled but did act flakey when coming to a stop at traffic lights. She said the RPMs would go to nearly 1000, drop to 500, then bump to normal as she's coming to a stop. Car also once on the several errand stops she made took 2 cranks to get it to start, something never happened before.
I call the service guy at the dealership, describe to him what happened. This fellow has never steered me wrong, immediately said it was the ECM re-learning, not to worry for a day or two. He seemed sure it was ECM relearning from his tone, something I'd not heard him be so sure of before (guy is at Capital Mazda in Cary, NC). It almost sounded like this is common with Mazdas from his tone.
This car had the new ECM firmware flashed in July 2008, so I think that's the latest rev and it addressed these exact problems (had the same issues with the car until the reprogram). I had similar issue, sans the 2 time starting problem, years ago but it was pretty consistent. The re-flash cured it back then, never had the issues since. My wife also tried cranking it after it had sat an hour in the garage after she got home; fired up like normal. She also tried after a 2 hr. sit, fired immediately, drove it a few blocks but no more stalling/weirdness. She said it acted like "problem? what problem?". It was as if nothing had ever been off kilter.
I tried cranking the car in the garage earlier, car had been sitting for 4 hrs., cranked fast as can be. I noted it had 60 mi. on the odo since I pulled the battery yesterday, and I've hear some cars can take up to 100 mi. to completely re-learn or 10-12 cranks. I'm keeping an eye on it but this is really weird and seems suspicious it happened as soon as I pulled that battery and the car sat easily 30 min. with it out. We'll see how it acts tomorrow morning.
tnmats is offline   Reply With Quote
Old 10-12-2009, 10:29 PM   #8
DrWebster
Moderator
DrWebster's Avatar
Though it's never happened to me, I've heard of 3's stalling or having weird idle while the ECU relearns. Give it a few more days to smooth out and see if you still have the problem.
Old 10-13-2009, 11:14 AM   #9
tnmats
Go-Kart Driver
[quote author=DrWebster link=topic=157018.msg3366725#msg3366725 date=1255400986]
The car still has the same problem after what the service guy said to try today:
1) make sure car if fully warmed up
2) disconnect the battery for 3+ min.
3) reconnect battery, crank car, let it sit idling for at least 2 min.
Did that (let it idle for 5 min.), still seems to have some of the problem (though not as pronounced). I made an appointment to take it on on Thursday just in case it doesn't clear up by tomorrow. The car was driven for over 90 mi. before I disconnected the battery earlier today; I figured it would have cleared up by now but didn't.
I've owned several computer-controlled cars since the mid 80s and never have seen a car twitchy to battery replacement before (if that indeed is what started this). I'm stumped as to what is going on. Time to feed the dealer more $$, eh?
Old 10-14-2009, 11:57 PM   #10
bernie3674
Bicycle Rider
[quote author=jason99 link=topic=157018.msg3341837#msg3341837 date=1253933357]
that happened to me, my car stalled once after reset the ECU, the car stalled at a stop, and after that it never happen again
bernie3674 is offline   Reply With Quote
