Car Won't Start After Engine Swap HELP!!! - Mazda3 Forums : The #1 Mazda 3 Forum
Old 09-18-2009, 06:38 PM   #1
noon21
Moped Rider
Default Car Won't Start After Engine Swap HELP!!!
I swapped out the 2.3 engine after I blew the old one. Everything is connected right and checked all the fuses and the car won't turn over. It seems that it is not getting any spark, also tried a flash test and don't get any results. Does anyone know what the problem may be? Engine cranks but doesn't start...
noon21 is offline   Reply With Quote
Old 09-18-2009, 06:48 PM   #2
smokinamd
Moderator
Send a message via ICQ to smokinamd Send a message via AIM to smokinamd Send a message via MSN to smokinamd Send a message via Yahoo to smokinamd
Default Re: Car Won't Start After Engine Swap HELP!!!
How long has the car been sitting?
Battery fully charged?
A revolution gets its name by always coming back around in your face.
smokinamd is offline   Reply With Quote
Old 09-18-2009, 07:04 PM   #3
dtravman
anytime u introduce a new ECU into the picture into any late model engine with our cars, the ECU needs to be flashed with current emission state and security (includes the VSS) settings. Have you had it flashed yet?
[[glow=red,2,300]Oo[/glow]|SKYLINE|[glow=red,2,300]oO[/glow]]
dtravman is offline   Reply With Quote
Old 09-18-2009, 07:06 PM   #4
noon21
Moped Rider
How do you flash it? The battery is fully charged. But the flashing thing, I've heard that from other people also. What is that and how do you do it? Thanks
Old 09-18-2009, 07:14 PM   #5
dtravman
oh man lol i went through the worst experience trying to get my new ECU in.  Once they installed it after they removed my other one which had been burnt up from touching a hot wire, they tried to start the car... not even a sound would be made except for the clicking of the key turning the ignition. mazda says that every ECU has to be flashed with that specific state/car/emission standards/manual transmission or automatic/etc.. all the specifics on the flash need to be exactly as your car is. But when i took it to mazda, they told me that they needed the old ECU (which was burned up and fried) to take the info off of it and put it onto the new ECU (which was blank, they dont come pre flashed like in the earlier days). Mazda said that it would take 6-8 hours to flash everything back on at $97.00 an hour... which was ridiculous. Go to your dealership and tell them to flash your car according to make, model, and emissions, federal etc.. and make sure its the right one, whether for a 2.3L or a 2.0L, cuz i have a 2.3L motor, and they had a 2.0 flashed on lol
i got good gas mileage tho, couldnt see what my average MPG was due to VSS not being flashed correctly, but i had a tank that lasted me 2 1/2 weeks
Old 09-18-2009, 08:20 PM   #6
smokinamd
Moderator
Ugh. You don't have to get anything flashed doing a motor swap, provided you used your original wiring harness and ecu, it should fire right up.
Old 09-18-2009, 08:37 PM   #7
noon21
Moped Rider
smokinAMD, I figured that, I used the old harness, pretty much everything from the old motor. I don't know if its a bad connection somewhere or maybe a fuse I overlooked. But it's killing me that I can't start this car. I just need to know how to start this thing. Thanks guys all your input has been really helpful.
Old 09-18-2009, 08:54 PM   #8
smokinamd
Moderator
How long has the car been sitting since you last got gas in it?
Old 09-18-2009, 09:01 PM   #9
silvapain
Grand Am Series
Send a message via AIM to silvapain
Make sure the crank sensor is connected and not damaged. If no CKP signal is detected the PCM won't introduce fuel (I'm not sure about spark) when trying to start the car.
2002 Pontiac GTP 40th Anniversary Edition
2007 MS3 - Beans Above the Frank Build
silvapain is offline   Reply With Quote
Old 09-18-2009, 10:15 PM   #10
noon21
Moped Rider
The car sat for about 3 weeks all together. I just don't want to take it to the dealer for them to find like a loose wire or something so simple and charge me $300 know what I mean?
