Thread Tools |
#1 |
Short Track Racer
Hey everyone,
I saw a topic on this back in 2007 with the search, but it hasn't been touched in a long time and there were no answers really. so basically what the subject reads. Lately, while in drive and at stop lights, every time my AC cycles on, my car's engine shakes and it makes me very nervous that it's going to mess up eventually. My car's warranty is long gone and I don't want to bring it to the dealership and have them name this and that and try to take advantage of me, like they did once before after seeing I had aftermarket CAI. Anyone ever have this problem or know of any suggestions on how to correct it? Any advice would be appreciated! |
| Sponsored Links | |||
Advertisement | |||
#2 |
can you define shake more? is it rumbling or something? the alternator is running to provide you a/c so a tiny "shake" is normal
#3 |
When did you notice the vibration? Have you checked your engine mounts? The passenger side mount may be broken.
It is right next to the coolant tank. Check out this thread. Scroll down and there are a couple of pics of the location. If you see all that black oily crap on your inner-fender, then it's probably broken. It could be something else, but this is worth looking at first. http://www.mazda3forums.com/index.php?topic=119411.0
2012 World Rally Blue WRX 5 Door 2005 Sunlight Silver Mz3 5 Door - Traded |
#4 |
Short Track Racer
[quote author=unknown00 link=topic=153760.msg3285838#msg3285838 date=1250651948]
can you define shake more? is it rumbling or something? the alternator is running to provide you a/c so a tiny "shake" is normal [/quote] The "shake" is just in the engine, thus shaking my car as well. It comes in waves when the AC cycles on. I noticed when I have the AC off, it doesn't happen. [quote author=bicycle_wreck link=topic=153760.msg3285913#msg3285913 date=1250653875] When did you notice the vibration? Have you checked your engine mounts? The passenger side mount may be broken. It is right next to the coolant tank. Check out this thread. Scroll down and there are a couple of pics of the location. If you see all that black oily crap on your inner-fender, then it's probably broken. It could be something else, but this is worth looking at first. http://www.mazda3forums.com/index.php?topic=119411.0 [/quote] I notice the vibration at red lights when I'm braked and idling in drive, only when the AC is on and cycles on. I have to go to work now but I will definitely check out that thread when I get home. I haven't checked the mounts.. Thanks. |
#5 |
Short Track Racer
I also forgot to mention how that when the AC cycles, and the shakes (rummbles) occur, my RPM is at about the line under 1000 RPM and starts to shake and drop when the shake occurs. then goes back to being stable after that until the next cycle, which ihs about every minute or so. :-/
#6 |
Go-Kart Driver
Hey jasko,
This happens to me all the time. My car has more drama than my life. Anyway, mazda posted a bulletin about this problem. Here's the link: http://www.finishlineperformance.com...39-07-1842.pdf I went to the dealer about this last year and i guess they didn't do anything about it. Also, sometimes I smell a musty/mildew type odor may come from the vents when the air conditioning (A/C) system is operating. It is most noticeable when the A/C is first turned ON. They also issued a bulletin however, it is not covered under the warranty. |
#7 |
Go-Kart Driver
Hey jasko,
#8 |
Short Track Racer
I see that the bulletin was issued for 2006-2007 models. Does it matter that mine's a 2004?
I'm a complete n00b at these things. I'm assuming in order to reboot the IDS, I need to take it to the dealership and get charged an arm and a leg? Did you have this done? (if so, how much?) thanks for the reply and link... |
#9 |
Short Track Racer
btw, hotnightcrash, did you get this problem fixed? if not, any problems since? I'm always afraid that my car is going to stall out or something at a light.
#10 |
Short Track Racer
Anyone else experience this? Sorry to bump.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
