Thread Tools |
#1 |
Bicycle Rider
I HAVE AN 05 MAZDA 3 2.0 ROUGH IDLE STALLING AT LIGHTS, POOR THROTTLE RESPONSE. ANYWAY I CLEANED THE EGR VALVE DIDNT FIX,
RUN BOTTLE OF SEAFOAM IN TANK DIDNT FIX IT. I HAD A CEL FOR RICH THAN LEAN AND A O2 SENSOR SO CHANGED THE 02 SENSOR AND RESET ECU STILL DIDNT FIX. I TOOK THE EVAP SOLENOID OUT AND SPRAYED WITH PB BLASTER AND LET IT SIT THEN RESPRAYED, BLEW IT OUT WITH AIR RE-INSTALLED PROBLEM GONE. THROTTLE RESPONSE IS AWESOME AGAIN AND FUEL COMSUMPTION ALOT BETTER. THANKS FOR THE GREAT TIPS ON THIS FORUM, HAS BEEN ALOT OF HELP |
| Sponsored Links | |||
Advertisement | |||
#2 |
Moderator of donks
![]() Join Date: Jul 2008
WHY ARE YOU YELLING AT US?!?!
#3 |
Bicycle Rider
sorry
#4 |
Moderator of donks
haha j/k. Glad you got your problem fixed.
#5 |
Go-Kart Driver
can you explain to me what you did cause my car is doing the same thing
#6 |
[quote author=JOECO link=topic=150939.msg3237712#msg3237712 date=1248121222] I TOOK THE EVAP SOLENOID OUT AND SPRAYED WITH PB BLASTER AND LET IT SIT THEN RESPRAYED, BLEW IT OUT WITH AIR RE-INSTALLED PROBLEM GONE. [/quote] that is what he did. |
#7 |
Bicycle Rider
[quote author=halo0 link=topic=150939.msg3237723#msg3237723 date=1248121444]
WHY ARE YOU YELLING AT US?!?! [/quote] HAHAHA
My favorite sites: SEO Services | Internet Marketing | Internet Marketing Blog | SEO |
#8 |
Go-Kart Driver
[quote author=lemons6245 link=topic=150939.msg3500354#msg3500354 date=1263671435]
can you explain to me what you did cause my car is doing the same thing [/quote] egg also wants to know..where is evap solenoid and whats it look like? eggs car idle like old man pulling rickshaw uphill backwards |
#9 |
Bicycle Rider
Had the exact same problem. Idle would dip at stops, a couple of times the rpm went so low it almost stalled, when it would do this the check engine light would come on for a split second. Anyway I took out the EVAP SOLENOID which was super easy to remove, sprayed it out with pb, let it sit, and blew it out. Idle is back to normal =] Thanks for the help "JOECO"
#10 |
[quote author=Blimp821 link=topic=150939.msg3973354#msg3973354 date=1300996595]
Had the exact same problem. Idle would dip at stops, a couple of times the rpm went so low it almost stalled, when it would do this the check engine light would come on for a split second. Anyway I took out the EVAP SOLENOID which was super easy to remove, sprayed it out with pb, let it sit, and blew it out. Idle is back to normal =] Thanks for the help "JOECO" [/quote] where is the evap solenoid located at? also how it looks like? a picture would help. but if not please explain..
Always something new. Never ending possibility. Work Hard Play Hard! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
