How to replace Mazda 3 brake pads - Mazda3 Forums : The #1 Mazda 3 Forum
Old 11-28-2008, 01:51 AM   #1
deluxman
Short Track Racer
Send a message via Yahoo to deluxman
Default How to replace Mazda 3 brake pads
Hello M3 maniacs!!
I am looking for instruction to replace the M3 brake pads and also the tools needed to get the job done. Can someone please provide the link to the how to instruction? Also does anyone know how to flush the brake fluid and how many quarts is required?
Thanks !!
deluxman is offline   Reply With Quote
Old 11-28-2008, 02:26 AM   #2
tigermack
tigermack's Avatar
Send a message via AIM to tigermack Send a message via Yahoo to tigermack
Default Re: How to replace Mazda 3 brake pads
http://www.mazda3forums.com/index.php?topic=32297.0
tigermack is offline   Reply With Quote
Old 11-28-2008, 02:49 AM   #3
deluxman
Short Track Racer
Tigermack, thanks for the link.......!! and also the super fast reply. I really do appreciate it.
Old 11-28-2008, 03:04 AM   #4
tigermack
tigermack's Avatar
You're welcome.
Old 12-03-2008, 01:12 PM   #5
deluxman
Short Track Racer
tigermack, have you tried replacing it yourself using this instruction you gave me? DId you borrow the calliper tool compressor from autozone or did you buy from Harbor Freight one? Are they both the same or the Harbor Freight one is better? Please confirm before I took mine apart. Thanks! Also, what brake pads did you replace it with? If you replace it with an after market one, did it solve the dust issue on the rear pads?
Old 12-03-2008, 01:32 PM   #6
icspots
Super Moderator
icspots's Avatar
I purchased the caliper tool from harbor freight as it was on sale for $18 and I figured I'd change the brakes at least one more time. No idea what tools places will rent out, though I imagine it would be similar.
I put on Hawk HPS pads and they seem to have decreased the wheel dust. Really as long as you don't put on an organic pad like the OEM the dust will be better.
icspots is offline   Reply With Quote
Old 12-03-2008, 04:59 PM   #7
youngun
Send a message via AIM to youngun
Hey I have a question regarding brakes for anyone who knows. Do 3's with ABS need to be bled any diff than normal? Reason I ask is cause after I did my brakes about 2 weeks ago and bled them till the pedal was nice and hard the min I turned on the car the pedal felt soft till about half way down. Is that norm?
My Duratec got Nuked
[img width=215 height=100]http://i656.photobucket.com/albums/uu283/jeremiahyoung/052-1-1.jpg[/img]
youngun is offline   Reply With Quote
Old 12-03-2008, 05:11 PM   #8
icspots
Super Moderator
icspots's Avatar
If you're just changing the pads or pads/rotors you shouldn't need to bleed them at all.
Old 12-03-2008, 05:26 PM   #9
youngun
no i removed my calipers, rotors, and all so I could paint and replace
Old 12-03-2008, 05:39 PM   #10
Sokool
Send a message via AIM to Sokool Send a message via Yahoo to Sokool
[quote author=Youngun link=topic=129551.msg2783660#msg2783660 date=1228341593]
It's called vacuum assist.
PART OUT THREAD!!!!
[center]
Sokool is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Suspension / Brakes
