Mazda3 5-door / Sedan & Speed3 “Blacked out” vinyl reflector overlays - Mazda3 Forums : The #1 Mazda 3 Forum
Old 08-06-2008, 11:35 AM   #1
southernsurfer
Default Mazda3 5-door / Sedan & Speed3 “Blacked out” vinyl reflector overlays
Blacked out
Vinyl reflector overlays
  • Side and Rear reflector vinyl overlays (4 piece kit)
  • Side and Rear reflector vinyl overlays with 3rd Brake light ** Sedan's Only ** (5 piece kit)
"Order now" and receive this kit shipped to your door for
$15 (4 piece kit) $19 (5 piece kit)
This is a very unique product in that it’s affordable, Looks great and does not damage your OEM or aftermarket reflectors. This product sticks onto your side and rear reflectors without adhesive. Giving you the look of expensive replacement lenses at a fraction of the cost. Two-Three-Four years down the road from now if you decide to sell your 3, you can just peel them off with out any damage.
I was looking for a way to “Black Out” my reflectors. That didn’t require hours of preparation and costly materials, causing my reflectors to become permanently altered. In the event that it wasn’t the look that I wanted and low and behold I ran across this product. Which suited my needs perfectly and I believe it will do the same for you.
Each one of these overlay kits have been hand fabricated, So there may be a small amount of deviation from set to set.
"BUY IT NOW" $15.00 Shipping included (4 piece kit)
"BUY IT NOW" $19.00 Shipping included (5 piece kit **Sedan only**)
When choosing the "Buy it Now" feature, PLEASE include your Mazda3Forums screen name ( sent to me via PM ) with your order.
Before:
After:
"Cl45music"
Very Very Happy with these! Great Product!
"krazyk86cu"
If theres a pic of my CRKT in this thread, I guess that means theres a pic of my 3 with southernsurfers vinyl's in the weapon thread hahahhaha
(see page 8 for details)
"Phantom3"
Mine came out great I love em!!!
"kevynnnn"
Another happy customer
"PJ 3i07"
Just got them installed a couple minutes ago. They look real good.
Thanks for the good service, and Fast shipment. They fit perfect and were easy to install.
"StealthSpeed3"
Got them today, and installed them 10 min ago. They look great and add more style/personality to Stealth...
Thanks again, i will let you know how they hold up through the winter months!
"bsapoznik"
I think you have a happy costumer
Thank you southernsurfer!
Pic taken w/Flash
"WhenInTEXAS"
Aaaah! They look so good!
Thanks dude! Super pleased!
"xxguitarist"
Yep, looking good!
We had some BAD weather today- heavy rains, strong winds, some hail, seem to have stayed stuck nicely!
If you have any questions Please feel free to ask
Thank you for your interest [/CENTER]
for Off road use only
southernsurfer is offline   Reply With Quote
Old 08-06-2008, 11:51 AM   #2
southernsurfer
Default Re: Mazda3 5-door / Sedan & MS3 “Black out” vinyl reflector overlays
"How to install your vinyl reflector overlays"
Step 1) Your going to need to clean your reflectors with a NON-ammonia based cleaner, I use a spray foam glass cleaner.
Step 2) Clean the reflectors well, this is an important step. As any debris left behind will show thru the vinyl. Make sure you clean & dry the reflector and all along the recessed edge.
Step 3) Take a damp paper towel and place the vinyl overlay between it while gently pulling it thru. This should remove any debris that may be on the vinyl and the residual moisture left behind will help in the adhesion process.
Step 4) Apply the vinyl overlay to the reflector and position properly, Then from the center outward apply lite pressure and "rub" out any air bubbles. Just like applying tint or a sticker ** a small squeegee makes things IDEAL here **
There may be a few air bubbles(or none if your lucky) but if there are some small ones, give it a day or two in the Sun and they should disappear.
If they do not, remove and repeat the process~
Last edited by southernsurfer; 09-20-2012 at 09:57 PM. Reason: Site format updated
Old 08-06-2008, 11:55 AM   #3
sintax
Grand Am Series
Send a message via AIM to sintax
Default Re: Mazda3 5-door / Sedan & MS3 “Black out” Reflector vinyl overlays
How much for just the two on the back? I already spray tinted the side ones and put some cheap tint on the ones on the back but it looks bad.
6k Headlights and 8k fogs, Blacked out badges, 15% tint, MS3 rear valance, Magnaflow Exhaust, Eibach Sportlines, eyelids, JDM rainguards.
sintax is offline   Reply With Quote
Old 08-06-2008, 12:30 PM   #4
danielj
Send a message via AIM to danielj Send a message via MSN to danielj
Nice! The reflectors look so much better blacked out.
These are great deal for anyone looking for a high impact, low cost change.
Hi Everybody
danielj is offline   Reply With Quote
Old 08-06-2008, 01:41 PM   #5
Apathetic Frimbo
More info on how to put them on? Like do you have to use soap and water or do you just slap them on?
Apathetic Frimbo is offline   Reply With Quote
Old 08-07-2008, 04:15 PM   #6
whenintexas
i didnt use any soap actually. its just like regular vinyls for application. u dont have to worry about it running out of stickyness when ur applying. if you do it dry then u can take it off and put it on over and over. or u can do the soapy water method and be able to slide it around into position. then just squeegee the soap out when u get it where u want. just make sure u get any sand or grit out or ull have little bumps.
whenintexas is offline   Reply With Quote
Old 08-08-2008, 01:05 AM   #7
bsapoznik
Send a message via AIM to bsapoznik Send a message via MSN to bsapoznik
where in south florida are you?
[url=http://www.mazda3forums.com/index.php?topic=128152.0]
bsapoznik is offline   Reply With Quote
Old 08-08-2008, 01:38 AM   #8
phantom3
Super Moderator
Send a message via AIM to phantom3 Send a message via MSN to phantom3
so its just a see thru black vinyl? Where should we send the money to?
phantom3 is offline   Reply With Quote
Old 08-08-2008, 01:56 AM   #9
bsapoznik
I want some... how black are they? I have a Black Mica... how they will match my color?
Old 08-08-2008, 02:19 AM   #10
southernsurfer
[quote author=bsapoznik link=topic=119729.msg2526271#msg2526271 date=1218171400]
There equivalent to 5% or Limo tints, There DARK
  Mazda3 Forums : The #1 Mazda 3 Forum > Sponsors > FMVperformance Sponsor Marketplace > Bronze Sponsors
