spring rate :: eibach pro-kit - Mazda3 Forums : The #1 Mazda 3 Forum
Old 08-03-2008, 02:19 PM   #1
:: gusto ::
Send a message via AIM to :: gusto ::
Default spring rate :: eibach pro-kit
is the spring rate in tha pro-kit made from the speed3 that much stiffer then that made for the 3?
im currently running a pro-kit on my 3 w/ upgraded mazdaspeed sways(f/r) & im still rubbing alil in the rear... so i was woundering if i could upgrade to a set of Speed3 (pro-kit) rear springs... if that would fit the problem @ hand...
some1 help me out here... thanks
:: yea yea i know i cant spell ::
traded my mz3 for a Ms6
:: gusto :: is offline   Reply With Quote
Old 08-03-2008, 05:05 PM   #2
boosthead
Send a message via AIM to boosthead
Default Re: spring rate :: eibach pro-kit
The last ime I checked, Eibach told me that they have no plans to sell a speed3 specific pro-kit in the US.
boosthead is offline   Reply With Quote
Old 08-03-2008, 07:43 PM   #3
socalwrench
Grand Am Series
if you are running 18s, you may need a stiffer spring to prevent the rubbing (for that lowered height).
I don't think the Mazdaspeed springs are any stiffer.
Certified Ford Tech and Custom Car Builder (GRH Performance)
socalwrench is offline   Reply With Quote
Old 08-03-2008, 10:09 PM   #4
:: gusto ::
[quote author=socalwrench link=topic=119447.msg2514035#msg2514035 date=1217803428]
I don't think the MazdaSpeed springs are any stiffer.
thanks... -- thats what im looking to do...
i dont rub when cornering...
only squats alil @ high speeds if i hit a dip in the highway.... -- just barely rubs... enough to make a noise.. but not enough to do anything to the tires...
ive had the wheels on for a month.. no tire issues thus far...
Old 08-03-2008, 10:53 PM   #5
boosthead
You may also want to consider a set of shocks/struts instead of springs. Koni yellows made a significant difference in how flat the car handled, even with stock springs.
Old 08-03-2008, 11:00 PM   #6
:: gusto ::
oh yeah
i want something stiffer in the rear... damn that sounds bad.. heheha
i need a stiffer ride in the rear of my car.. there we go.. hehehaeh
but for real.
Old 08-03-2008, 11:56 PM   #7
boosthead
I've sampled a number of suspension setups on my 3 and found that shocks/struts have a larger impact on ride "stiffness" and also that rear stiffness plays a significant role in ride quality. O
Old 08-04-2008, 11:20 PM   #8
:: gusto ::
well i want a softer front.. & a stiffer rear.. i use to have that set up on my last car.. worked out pretty well...
i wounder if the KYB AGX is avail for our cars....??...
Old 08-04-2008, 11:55 PM   #9
socalwrench
Grand Am Series
yeah, I will also be running stiffer rear springs than the front.
KYB only makes the GR2 dampers right now. NO Gas-Adjusts and NO AGXs.
However, Tokico is making dampers. They should be out soon- hopefully.
Old 08-05-2008, 12:19 AM   #10
john_in_the_lbc
Senior Member
john_in_the_lbc's Avatar
or you could run koni yellows and set the rears to the stiffest setting and the fronts to the softest.
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Suspension / Brakes
