Thread Tools |
#1 |
PDF file
Copy and past this: http://www.o-m-g-w-t-f.com/stuff/Maz...19b%5B1%5D.pdf So that is A LOT of why the engines are poping (Speed 6 and now the onslought of ms3s). So all of you assholes who wanted to be a dick to me and didnt listen, you can kiss my ass. I am sure ALOT of us apply to this. I was scheduled to go to the dealer today at 1 for the final bit of tuning and touch ups to my car post engine replacement and I am bringing this up. We are working this all out today, I will be back with details tonight. This was already mentioned in the recall section, but it needs to be here.
"The Verdict: It may cause jail time, but never boredom." Nearly built and soon to be badass, fully gutted, flat grey textured 02 WRX, fully built ej205, Straight cut gears PPG 1-4, PnP heads/crower stage 2 cams, JDM Spec C RA-R Twin Scroll vf37, ported tubular twin scroll headers/uppipe/downpipe, reversed long runner/PnP intake mani, full jdm sti strut/sway bars, 18x10 +18ish with 265s |
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior Member
![]() Join Date: May 2007
fix your link
#3 |
linky no worky
#4 |
Sorry for the link not working.. Fixed it. Dont know why it got so fubard, but it is there now.
I got my car back Friday the 4th and this was issued the 2nd. The procedure on it says your are supposed to place a Aproved decal on the drivers side door jam and it isnt there.. so I do not believe this was done on my car! And it is the REASON it blew. So I will be headed there in a few minutes. GET THIS DONE! ASAP!!!!! Call your dealer now, especially any of you with tbe/intake/mbc combos <- you guys want to be there today! Good luck
#5 |
Man I just got my car back 2 days ago, and they didn't check this booO! gonna have to call again.... sigh
#6 |
[quote author=northmiler89 link=topic=108340.msg2220845#msg2220845 date=1207840784]
GET THIS DONE! ASAP!!!!! Call your dealer now, especially any of you with tbe/intake/mbc combos <- you guys want to be there today! [/quote] why the rush, especially for the guys with tbe/intake/mbc combos? |
#7 |
because this may be what is causing the major loss of power under load for a lot of people, including myself, and even engine failure and or damage for a few.
I had my car fall on it's face twice while accelerating in high gear, warm temps, also, hestation happens on a daily basis. I have an early build.
I'm from the government, and I am here to help you. |
#8 |
Yes, because modifications only further fuck up the AFR on this car and if it is having lean issues stock.. then throw on some parts and boom.
[quote author=dutchie3 link=topic=108340.msg2221000#msg2221000 date=1207843881] because this may be what is causing the major loss of power under load for a lot of people, including myself, and even engine failure and or damage for a few. I had my car fall on it's face twice while accelerating in high gear, warm temps, also, hestation happens on a daily basis. I have an early build. [/quote] The reflash... omgholyfuck it makes a HUGE difference HUGE. But not enough, still having problems so a new one is due to arrive on Saturday. And the dealers will have trouble finding this. Print it and remind them that it is a "Service Bulletin" not a "Recall"
#9 |
Grand Am Series
So this is just an ecu problem correct.
07 mazdaspeed 3 kosei k1's,turbosmart bov,cp-e tbe,cobb ap |
#10 |
[quote author=MZS3 link=topic=108340.msg2221498#msg2221498 date=1207855423]
So this is just an ecu problem correct. [/quote] ECU reflash and an inspection of the fuel pump. The pump will be replaced if the manufacture date falls within a specific range.
Mods: COBB SRI, SU motor mount, SU test pipe, RKM BOV |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
