Poll: You Won't Believe This. Engine Oil Overfill By 4+ Quarts = White Smoke - Mazda3 Forums : The #1 Mazda 3 Forum
View Poll Results: Is My Engine Screwed?
Unsure 6 14.63%
No 18 43.90%
Light Damage 5 12.20%
Moderate Damage 4 9.76%
Bend Over (Engine Is Toast) 8 19.51%
Voters: 41. You may not vote on this poll
Old 03-09-2008, 05:27 PM   #1
wildfrisco
wildfrisco's Avatar
Default Poll: You Won't Believe This. Engine Oil Overfill By 4+ Quarts = White Smoke
Yesterday was one of the most depressing days of my life.
Had my friend change my oil for me as usual. As I left his place lots of white smoke started billowing out of the exhaust. Pulled over within half a block and shut off the engine immediately. Called my friend he followed me back to his place a few blocks away. He pulls the engine cover and plugs. Spark plugs #1 and 4 have dried oil stains. #2 and 3 are wet with oil.
At this point my friend thinks it's either a blown head gasket or valve train issue. I decide to leave my car at his place and borrow one of his cars to go home and do research/decide on courses of action. Btw my initial searches here for blown head gaskets didn't return much, save the occasional Mazdaspeed 3.
Today he tells me over AIM that he figured out what happened and it was his fault. WTF!
He forgot to drain the oil before filling the engine up with 4+ quarts of additional oil!!!
Is my engine fucked? Vote in the poll. If so, which part(s)?
Man I was so sad yesterday. If it makes any difference, I'm using Amsoil in the recommended weight. Also I didn't drive far, maybe 5 blocks round-trip. The whole time I kept it under 2,500 rpms when accelerating. Let me know guys.
Hypertech MESPP, Aasco flywheel, Medieval lightweight pulleys, Cordova throttle body, track pipe, Cosworth air filter, OEM BBK (Ms3 front & Mz5 rear brakes), Goodridge SSBBL, Koni FSD, OEM '04-06 16" Mz3 alloy wheels, staggered Continental ExtremeContact DW (225/50/16 front & 205/55/16 rear), Morimoto/Xtreme/Lamin-x HID 5,000K headlights & 4,300K fog lights, OEM LED tail lights, OEM leather seats, OEM JDM leather armrest, OEM + FIAMM + PIAA horns, Eneos 5W-20, Amsoil 75W-90 GL-4, ATE Super Blue
wildfrisco is offline   Reply With Quote
Old 03-09-2008, 05:30 PM   #2
wildfrisco
wildfrisco's Avatar
Default Re: You Won't Believe This: Engine Oil Overfill By 4+ Quarts = White Smoke
Oh and I did see him change the oil filter and filter gaskets. Just didn't open the drain plug to fully drain the oil.
Old 03-09-2008, 05:42 PM   #3
kjh1127
Default Re: Poll: You Won't Believe This. Engine Oil Overfill By 4+ Quarts = White Smoke
How is the world do you forget to drain the oil before putting the new oil in? Draining the oil is the first thing you do! Your friend is a dumbass, sorry!
I don't think your car is fucked, just drain all the oil out, and fill it up with 4 new quarts and a new oil filter
Kyle, 2006 Mazda3s GT
kjh1127 is offline   Reply With Quote
Old 03-09-2008, 05:49 PM   #4
t0p_sh0tta
Drain and refill with the proper amount. You should be fine after that. If you want, you can also do a compression check to make sure the rings weren't damaged.
edit: This is a common occurence when people start rushing. Just be glad you had too much oil rather than not enough.
Back from the dead. Check out my for sale thread.
t0p_sh0tta is offline   Reply With Quote
Old 03-09-2008, 05:52 PM   #5
allwakes
Send a message via AIM to allwakes
+1
[quote author=ITHURTZ link=topic=105057.msg2138124#msg2138124 date=1205172394]
Jake has 14 carbon fiber stickers with carbon fiber paint. These mods alone put on 320hp at the wheels WHILE lightening his ride 400lbs
allwakes is offline   Reply With Quote
Old 03-09-2008, 05:55 PM   #6
wildfrisco
wildfrisco's Avatar
[quote author=kjh1127 link=topic=105047.msg2135793#msg2135793 date=1205098968]
That's a good question. He's a cool kat but I want to slap him.
And you guys aren't voting
Old 03-09-2008, 05:57 PM   #7
wildfrisco
wildfrisco's Avatar
[quote author=t0p_sh0tta link=topic=105047.msg2135809#msg2135809 date=1205099390]
Yeah he's going to do a compression check today.
I figure it's a good tool for finding out large variations between cylinders, but what if they're all damaged similarly so the leakage is equal in all cylinders? He's a Honda guy so how would he know? Is there some kind of normal level for most 4 cylinder engines?
Old 03-09-2008, 05:58 PM   #8
t0p_sh0tta
Why vote? Change the oil and let us know the outcome.
Old 03-09-2008, 06:47 PM   #9
t0p_sh0tta
[quote author=WildFrisco link=topic=105047.msg2135830#msg2135830 date=1205099879]
There is an average range depending on the engine. I'm sure you'll be able to find the numbers somewhere in the service manual. I'd be more concerned with large variances between the cylinders as it's unlikely that all 4 were damaged simultaneously.
Old 03-09-2008, 10:27 PM   #10
kjh1127
[quote author=WildFrisco link=topic=105047.msg2135824#msg2135824 date=1205099700]
I voted no. I think you'll be ok. It's not like you drove a thousand miles like that.
