Manual transmission hard to shift in cold weather - Mazda3 Forums : The #1 Mazda 3 Forum
Old 01-04-2008, 08:33 AM   #1
Macondawg
Bicycle Rider
Default Manual transmission hard to shift in cold weather
This is an 06 model with 35,000 miles. What can i do?
2006 Titanium Grey 5 door
Macondawg is offline   Reply With Quote
Old 01-04-2008, 09:17 AM   #2
TriggersDawn
Grand Am Series
Default Re: Manual transmission hard to shift in cold weather
Switch to synthetic fluid? It's probably time for a change anyway.
07 GT Sedan MTX Phantom Blue
TriggersDawn is offline   Reply With Quote
Old 01-04-2008, 09:21 AM   #3
breakthestatic
Send a message via AIM to breakthestatic
You could try changing fluids but I don't think it will help that much. All manual transmissions will be somewhat stiff and hard to shift in the cold weather. My advice would be to just get used to it, let the car warm up a bit longer, and run through the gears a few times before actually starting off.
breakthestatic is offline   Reply With Quote
Old 01-04-2008, 10:02 AM   #4
mazdathaiboi
im planning to switch my tranny fluid and clutch fluid to royal purple or redline
2007 Mazdaspeed3 sport =D ,Cobb AccessPort, black'd out emblem, debadge'd rear,AEM CAI, Relentless FMIC, Turbosmart hybrid BOV, test pipe, Resonator Delete,Autotech hpfp/cdfp, Street Unit RMM, Tein S-Tech Lowering Springs, TWM short shifter 55w 6000K HIDs Headlights and Fogs & LED Parking Lights
mazdathaiboi is offline   Reply With Quote
Old 01-04-2008, 10:22 AM   #5
fiji mazda3
Send a message via AIM to fiji mazda3 Send a message via Yahoo to fiji mazda3
It's normal, especially now that temperatures have dropped. For example, I left my car outside for a few days and had to move it in 25 degree weather. It was like shifting through syrup until it warmed up.
Click Picture For Modifications.
fiji mazda3 is offline   Reply With Quote
Old 01-04-2008, 10:23 AM   #6
epic3
Moderator
epic3's Avatar
Send a message via AIM to epic3
25 degree weather... haha you guys are all noobs!
Its been -10 for 3 days now when the sun is out
Spread the community love
epic3 is offline   Reply With Quote
Old 01-04-2008, 10:26 AM   #7
fiji mazda3
[quote author=aps11090 link=topic=98897.msg1966784#msg1966784 date=1199460224]
Vermont's a little farther north than Pennslyvania, so of course it's going to be colder up there.
Old 01-04-2008, 10:40 AM   #8
epic3
Moderator
epic3's Avatar
lol I know
Old 01-04-2008, 05:20 PM   #9
stuck24
[quote author=Fiji Mazda3 link=topic=98897.msg1966792#msg1966792 date=1199460395]
it's been 40 degrees here every morn the past 3 days... the gearbox is slightly sticky until warm/// consider yourself lucky that you don't drive older cars ... get used to it... amsoil syn oil will help slightly
stuck24 is offline   Reply With Quote
Old 01-04-2008, 10:49 PM   #10
hoffo
hoffo's Avatar
for really cold climates your best bet would be a 50/50 mix of Redline MT-90 and Redline MTL. This gives you a slightly thinner weight around 75w-85 or so. There are some people on bobistheoilguy forums that run this in their MS3 and say it is awesome. Or if you want you can also run straight MT-90 which is 75w-90 which is what the specs call for for our cars. I am running straight MT-90 in mine and it shifts much better in the cold than the stock fluid ever did but if you are in a really cold climate you might want to do the 50/50 mix as the thinner the fluid the better the synchros work especially in the cold.
2005 Mazda 3i 2.0 5spd mt velocity red. Corksport rear mount insert, Mazdaspeed short shifter, carbon fiber shift boot, Redline mt-90, K&N air filter, Denso iridium plugs, Optima red top, tb ground, Pivot mega raizin, ebay strut tower brace, H&R coilovers, 16x7 Rota fighter 10s, H&R rear sway, Corksport exhaust, Whiteline adj. front endlinks
hoffo is offline   Reply With Quote
