Won't start from PARK, but will from Neutral....anyone else? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 09-10-2007, 11:03 PM   #1
adrock3
Bicycle Rider
Default Won't start from PARK, but will from Neutral....anyone else?
My car is just about 3 years old, and it lately has decided to only start from park 25% the time, and the rest I shift to N to get it to turn over. I think the sensor that tells the ignition whether the car is in P/N (the only starting positions) might be bad in the P position.
Anyone else have this problem? I'm going to take it in on the weekend and hopefully its under warranty...even if it is a free fix its still annoying!
adrock3 is offline   Reply With Quote
Old 09-10-2007, 11:14 PM   #2
gar187er
Send a message via AIM to gar187er
Default Re: Won't start from PARK, but will from Neutral....anyone else?
so the key turns, but it doesnt start?
clicking noise?
anything?
[glow=orange,2,300]FS: MZ3 stock parts!!!![/glow]
[glow=blue,2,300]FS: Used 215/45/17 tires[/glow]
gar187er is offline   Reply With Quote
Old 09-11-2007, 03:53 PM   #3
adrock3
Bicycle Rider
Nothing. I can turn the key, but it won't start...just like if you were in R or D.
Old 09-11-2007, 06:23 PM   #4
tostitos44
Moped Rider
its your neutral sensor switch for you park gear....happened to my jeep....
probably gonna have to take it to a dealer
tostitos44 is offline   Reply With Quote
Old 07-21-2010, 05:21 PM   #5
perkinscl
Moped Rider
Did this fix it?
perkinscl is offline   Reply With Quote
Old 10-12-2010, 12:31 PM   #6
pinoy_eh
Go-Kart Driver
The neutral safety switch needs to be replaced. I had the same problem (2006 Mz3 Automatic) that it wont start on Park, I have to move the gear shift to Neutral and it will start. I replaced mine by myself, not a warranty part. The part will cost $65.
2006 Mazda 3 GS 2.0 ltr.
Previous owner of 1982 Mazda GLC and 1990 323LX
My second job pays for my car.
pinoy_eh is offline   Reply With Quote
Old 11-05-2010, 02:11 AM   #7
StephenC
Moped Rider
[quote author=pinoy_eh link=topic=88714.msg3825319#msg3825319 date=1286901086]
Got that right. The neutral safety switch needs to be replaced. The safety switch’s main role is to keep track of the position of the gear selector lever. It prevents the engine from starting if the gear or transmission is not on neutral or park position. If the gear is on this position, it would be easy and safe to start the vehicle. Yet there are some signs that will pinpoint defect on this part. One is when the lever has to be shifted from park or neutral mode in order to get the engine to start. Another, which you are encountering, is if the car starts in Neutral but not in Park mode. That’s the go-signal for a replacement. Hope it helps.
StephenC is offline   Reply With Quote
Old 12-14-2012, 02:15 PM   #8
jimbee
Bicycle Rider
Default
Quote:
If you replaced it yourself, can you tell me how? Any pictures? Maybe somewhere on the web that has instructions. I really don't want to go to the dealer and have them charge me $200 or more. Thanks.
jimbee is offline   Reply With Quote
Old 12-17-2012, 12:13 AM   #9
Bravoexo
Grand Am Series
Default
Mine happened when the Cold Air Intake lower mounting bracket got in the way of the cable attached to the switch. The cable kept snagging and wouldn't return to Park. I relocated the mounting brackit toa readily available bolt opening near the area.
Bravoexo is offline   Reply With Quote
Old 12-17-2012, 12:43 AM   #10
cclngthr
Send a message via AIM to cclngthr Send a message via MSN to cclngthr
Default
The ATX uses the transmission range switch as the neutral safety switch. It is on top of the tranny near the gearshift mechanism.
cclngthr is offline   Reply With Quote
