Manual Transmission 4th Gear Grinding Noise - Mazda3 Forums : The #1 Mazda 3 Forum
Old 08-12-2007, 03:44 PM   #1
drumboy
Short Track Racer
Default Manual Transmission 4th Gear Grinding Noise
So, I thought it would never happen to me since I have been driving "sticks" all my life and have not had any gearbox issues in all of my previous cars. But...little did I know...
Anyway, my '06 hatch with a 5-speed has recently developed a somewhat scary grinding noise when shifting only from 3rd to 4th gear in higher rpms (under hard acceleration). It does not happen under normal driving conditions, but as soon as I decide to "step on it" harder and stay in each gear closer to the redline, I get a crunchy sound going into the 4th gear.
Anybody gotten that yet? Would it be the syncros? I am planning on taking it to the dealer to have it looked at... By the way, I am at 30,000 miles so warranty still applies...
2000 Nissan Xterra SE 4x4
drumboy is offline   Reply With Quote
Old 08-12-2007, 04:05 PM   #2
small town king
Send a message via AIM to small town king
Default Re: Manual Transmission 4th Gear Grinding Noise
i get a grinding sound when i go 2nd - 3rd when i'm really pushing it and try to get a fast shift.
but if i slow down my shift, it doesn't do it, so idk.
Went from a brand new 06 Silver Hatch to a Crispy 06 Hatch to a White 06 tC
I miss her
Ya. Thats my old Hatch on the Grip Tuning Advertisement Banner. After a nice photoshop, HOLLLLAAAAAAAAAAa
small town king is offline   Reply With Quote
Old 08-12-2007, 09:03 PM   #3
945LSTANG
my guess would be your syncros. i will bet you that as you keep driving it it will begin grinding even in normal driving conditions.
how many times are you guys going to remove my sig? jesus...
[quote author=ballinpapo]so they buy their mustangs, get some bullit wheels, and tune for straight-line (hey i have no skills at driving because even a 5 year old can shift) racing.[/quote]
945LSTANG is offline   Reply With Quote
Old 08-12-2007, 09:27 PM   #4
mazda225
Send a message via AIM to mazda225
i think mine does it going from 1st -2 how do u fix it get a new tranny?
[img width=450 height=90]http://C:\Documents and Settings\Justin\Desktop\New Folder (3)\axela.jpg[/img]
mazda225 is offline   Reply With Quote
Old 08-12-2007, 10:38 PM   #5
drumboy
Short Track Racer
I don't know how it gets fixed. Here is what I want to know...Am I doing something wrong that contributed to that? I used to assume that with proper shifting technique and proper maintenance I should not have any problems with my gearbox. Man, I used to flog my 2002 manual Honda Civic and nothing happened. I wonder if a more powerful motor, like in our 3s, created more stress on the tranny. Or, is it, that Honda gearboxes are more stout and simply better designed?
Old 08-12-2007, 11:04 PM   #6
YoungJim
Short Track Racer
The synchros are simply brass rings that look a bit like gears; they can be replaced, and as long as the (steel) gears themselves aren't chewed up, then that should be all you have to do. Now, exactly how much work it is (or how much it would cost) is something you'd have to ask your dealer about, but it is do-able.
Tell you what, handle your car the way you'd handle a loaded gun, and you'll probably be alright.
YoungJim is offline   Reply With Quote
Old 08-13-2007, 12:41 AM   #7
ViperKillerWannabe
Send a message via AIM to ViperKillerWannabe
It should be covered under warranty. As someone said above, it is a simple brass ring, but to replace it you must completely remove and tear apart the transmission. On a 3, this involves removing the engine as well, because there is no room in the engine bay to just remove the transmission. Therefore, you can expect your car to be out of commission for a few days to a couple weeks while they replace it. One thing you can try if you don't want to leave it in the dealer's hands for so long is replace the gearbox oil with a full synthetic. It won't stop the damage (it is usually progressive), but it will slow it down and possibly stop the grinding altogether, until the damage progresses more.
[img width=192 height=100]http://card.mygamercard.net/sig/firedcylinder.png[/img]
2005 Sunlight Silver Metallic 3s
ViperKillerWannabe is offline   Reply With Quote
Old 08-13-2007, 09:57 AM   #8
azazel1024
Senior Member
There certainly should be enough room to drop the tranny out. If there wasn't enough room to remove the transmision then the entire engine and tranny would have to be pulled everytime you had to do a clutch job, and they would run $$$, a lot more then they do.
-Matt
[quote author=crazyduckme]
Yay for doing it by hand then! That will probably last about an hour tops.I was craving meat REALLY bad. plus, my mom gets really hot, so I was uncomfortable. So I have to really stretch.
azazel1024 is offline   Reply With Quote
Old 08-13-2007, 02:12 PM   #9
drumboy
Short Track Racer
I am going to the dealership in the morning. Should be covered under warranty, that's what the service adviser said.
Thanks for all your help, guys.
Old 08-15-2007, 01:50 PM   #10
drumboy
Short Track Racer
Well, I came from the dealer today. The told me that because it only happens when I "power shift" from 3rd to 4th gear it is normal. That's bullshit. It just started happening recently. Dealerships suck... Oh, and on top of that they apparently called a technical hotline where it was confirmed to them that "our gearbox is not designed to powershift, so a grinding noise would be normal."
I guess I could try another dealership.
Any other suggestions?
