boost leak test - Mazda3 Forums : The #1 Mazda 3 Forum
Old 08-06-2007, 12:31 PM   #1
TRU-BOOST
Default boost leak test
ok so i assembled a leak tester yesterday using a 2" pvc cap and a valvestem.... $4.00 total.
it did its job just fine, but my results are ....... inconclusive. first i tested it from where the reducer goes on the inlet side of my MS intake. this method would pressurize the entire boost system, including the turbo and all the little vac. lines that come off of it. i pressurized to 25psi, and found a small leak where the plastic intake tube clams on the turbo. this would not be a boost leak, since it is on the intake side. i did tighten it up just for good measure though. i then proceded to put the tester right befor the throttle body to get a maor accurate manifold pressure test. i again used my compessor to pressurize to 25 psi. i did see that gauge was showing the pressure rapidly droppping, and i heard a rushing air sound. so i filled a spray bottle with soapy water, and pulled the IC off (i was only testing the manifold and hoses leading from it at this point) after several spray downs i found only a tiny leak right at the TB and only above 22psi, so i know that is not my problem. i still hear the air coming out somewhere, but it may just be passing through the engine.
i reset the battery and drove for a while i still see lower boost levels than i used too.
i see;
10psi in 1st
13 in 2nd
13 in third
14- 15 in 4th
5th and 6th will hit 16 and hold 14
did anyone else test or leaks yet ??
if not will someone try it and same their results ?? i would like to see if you hear the same thing or if i do infact have a leak.
i dont want to bring it in to the dealer and leave it for a few days just for them to tell me its fine.
PROTEGEGARAGE.COM NO CP-E FOR ME
mazda speed forums .org
dont waste your time PM'ing me. this gay ass forum has taken away my ability to send and recieve PM's.
TRU-BOOST is offline   Reply With Quote
Old 08-07-2007, 03:55 PM   #2
TRU-BOOST
Default Re: boost leak test
wow nobody else had done a leak test ??
Old 08-07-2007, 06:35 PM   #3
bombermanx
Short Track Racer
How exactly are you making the whole system air tight? Air is going to leak out from the throttle plate as that's not going to be a 100% air tight. Maybe make sure the engine cylinder 1 is at Top Dead Center, that should line up all the cylinders either at the top or at the bottom with all the intake valves closed.
bombermanx is offline   Reply With Quote
Old 08-07-2007, 07:08 PM   #4
eurotuner
eurotuner's Avatar
a question for you guys
no matter what bolt on u install, do you still run the same number of boost?
[u]Click below for pictures and specs of the FULLY BUILT TURBO 3 and SPEED 3!
[center][url=http://www.mazda3forums.com/index.php?topic=58914.0=1][center]
eurotuner is offline   Reply With Quote
Old 08-07-2007, 07:13 PM   #5
rotus8
[quote author=eurotuner link=topic=85432.msg1619574#msg1619574 date=1186524485]
the 17mm bolt give 17 pounds of boost. The 19mm bolt gives 19 pounds.
CB MS3 GT with Nav. Mods: Shifter bushings, Shortened shifter throw, Lower rear mount, MS CAI, 3.25" TMIC, SilverStar lights, Modified fogs, Kyokugen wheel nuts, Stebel Nautilus air horns, hardwired Escort 9500i, Auto-dim homelink mirror, Hood gas springs, leather shift boot, ebrake, and console cover, heated mirrors, rear bumper scuff plates. MS coilovers and camber links, Hotchkis ARBs.
rotus8 is offline   Reply With Quote
Old 08-07-2007, 07:13 PM   #6
eurotuner
eurotuner's Avatar
oh and how do u change that !?
on the WG?
Old 08-07-2007, 07:18 PM   #7
rotus8
[quote author=eurotuner link=topic=85432.msg1619592#msg1619592 date=1186524824]
on the WG?
Sorry - did you see the smiley? There is nothing simple you can change. The ECU controls everything.
Old 08-07-2007, 07:19 PM   #8
eurotuner
eurotuner's Avatar
no i didnt
but u should be able to change twist the screw on the waste gate...
no?
i am just been curious
Old 08-07-2007, 07:55 PM   #9
rotus8
[quote author=eurotuner link=topic=85432.msg1619609#msg1619609 date=1186525192]
no i didnt
no?
No, you can't. The waste gate limits to about 10psi. The ECU overrides limit to about 18 when it feels it is safe. If you change the spring it changes the basic boost, but the ECU is really in control. In fact, if the ECU detects the base boost higher than it is supposed to be, it may shut down the engine with a fuel cut.
Old 08-07-2007, 07:56 PM   #10
CaSHMeRe
+1 on overboost and fuel cut ... i believe those are the issues i have been having with my FMIC... grrrr
[center]
CaSHMeRe is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > MazdaSpeed > MazdaSpeed3 DISI Turbo
