HELP PLEASE!!! dead battery= power steering problem???? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 07-04-2007, 11:37 PM   #1
rustyrider
Grand Am Series
Default HELP PLEASE!!! dead battery= power steering problem????
i got back into my car and when i went to start it it turned over for a split second but did not start.i figured, dead battery. i got it jumped, let it run for like 5 min at 3000rpm and the went back to idle. when i turned my lights on i guess it put a load on the alternator and then stalled. so jumped it again let it run for like 10min and then reved it up a little and turned the lights on. then i started to drive around the parking lot and power steering was kinda off and on and the lights were flikering and dimming when i was turning and stuff. then it stalled again when i turned. jumped it again and drove home very carefully with off and on pwr str (right down the road). so right now i am hoping its just a dead batt and have it charging over night . i have some lights and an airhorn but all of those are fused could it be a short maybe? i will report back in the morning when i know the batt is charged. why would this effect the power steering?
rustyrider is offline   Reply With Quote
Old 07-05-2007, 10:38 AM   #2
rustyrider
Grand Am Series
Default Re: HELP PLEASE!!! dead battery= power steering problem????
i charged it up over night and every thing seems to be fine. it still seems kinda funny though. ?????????
Old 07-05-2007, 10:42 AM   #3
john_in_the_lbc
Senior Member
john_in_the_lbc's Avatar
maybe you should check the belt(s).
Old 07-05-2007, 10:47 AM   #4
velocityredgt
Short Track Racer
Default I remember reading something about electrohydraulic power steering
No clue what that means though
2014 Mazda 3 GT Soul Red
velocityredgt is offline   Reply With Quote
Old 07-05-2007, 11:10 AM   #5
dmention7
Our power steering pump is actually motorized, and not powered by the accessory belt. If your charging system is weak, then it will affect the power steering pump motor, just like any other electrical accessory.
2003.5 Laser Blue MSP #2543
dmention7 is offline   Reply With Quote
Old 07-05-2007, 11:58 AM   #6
rustyrider
Grand Am Series
ya i checked the belts when it happened but i knew we had a hydrostatic powersteering system (whatever that means) so i wasnt really sure what was going on
Old 07-05-2007, 12:13 PM   #7
rustyrider
Grand Am Series
correct me if im wrong but normally if you have a dead batt and jump the car wait ten minutes with the car running, and then turn it off, shouldnt you have enough power to start it back up again? i doubt its a charging system problem b/c the car is only 7 months old and has 6000 miles.
Old 07-05-2007, 01:50 PM   #8
dmention7
Honestly, it does sound like a problem with your charging system--you said turning on the headlights caused your engine to stall after it had been running for 5 minutes. That's not normal. I'd definitely bring it in to the dealer, because something is up.
Oh, and electrohydraulic is the word you're looking for
Old 07-05-2007, 05:14 PM   #9
billm
Bad battery connections might also be likely. The EHPAS (power steering) can draw an amazing amount of current when you are driving slow and turning.
billm is offline   Reply With Quote
