Thread Tools |
#1 |
Moped Rider
I have been gathering the pieces-parts to be able to flash the MS3 PCM. No rocket science here. You can get the flash program called MMP (Mazda Module Programming) from mazdatechinfo.com. A thirty day deal is 60 bucks – 24 hours is 30 IIRC. You download the flash program, which appears to be a subset of the MMDS software used by the dealer shop for diagnostics and PCM programming. I’m using V4.8.
The subscription is necessary, because new re-flash data is loaded over the internet while you’re running the MMP and are connected to the car. For the J2534 pass-thru interface, I’m using a Drew Mongoose PWM/CAN interface with the FEPS option (which allows Ford/Mazda programming). The current available flash is documented in this excellent thread – http://www.mazda3forums.com/index.php?topic=75964.0 Looks like it addresses a bunch of drivability and performance irritations we’ve been having. My current flash level is E. The most current for my VIN is G (I believe this applies all MS3’s). I got to the “jumping-off point” of doing the re-flash, but stopped short, as I’m still doing some structured logging and want to preserve my testing baseline. I'll advise the results when I push the button. The first screenshot is at the point-of-no-return. Note the G revision software part number. The second screen is the log-file showing my current configuration with the original E flash. Note that the MMP did Mode 6 diags on the PCM, DSC and other intelligent nodes in the system. There are a few trivial utilities in MMP. You can program ignition keys and turn off the driver and passenger seatbelt chimes. I turned off the driver chime as a test, verified the change and changed it back. Screenshots three and four show optional levels (1-16) for “Display Interval” and “Fuel Response". The control unit is the IC (instrument cluster). Just guessing - maybe the instrument refresh rate and the fuel gauge integral over time. I was tempted to mess with the fuel response to see if I could see a slosh, but I ran out of time. |
| Sponsored Links | |||
Advertisement | |||
#2 |
what is a Drew Mongoose PWM/CAN interface with the FEPS option (which allows Ford/Mazda programming). Where do you get something like that?
#3 |
Moped Rider
#4 |
So can I just go into my Mazda service dept and ask to be updated to "flash G" or do I have to complain about driveability issues first?
[img width=429 height=100]http://i106.photobucket.com/albums/m275/tire_smoke600/2006%20STI/Signature.jpg?t=1273719703[/img] |
#5 |
Moped Rider
[quote author=Tenacious_B link=topic=76162.msg1374176#msg1374176 date=1177903291]
So can I just go into my Mazda service dept and ask to be updated to "flash G" or do I have to complain about driveability issues first? [/quote] The thread referenced above has a lot of differing opinions about dealer re-flash policies and issues. I’d re-post this there to keep all those discussions concentrated in one place. |
#6 |
Very interesting. So you're using something like this:
http://cgi.ebay.com/ebaymotors/Mongo...spagenameZWD1V How is that list of PCM options populated? I know a couple members had mentioned it was possible for Mazda dealers to bump the 118 mph limiter. I'm kind of curious if a tool like yours could do the same.
#7 |
Moped Rider
[quote author=bearda link=topic=76162.msg1374709#msg1374709 date=1177940831]
Very interesting. So you're using something like this: http://cgi.ebay.com/ebaymotors/Mongo...d-Supports-etc. How is that list of PCM options populated? I know a couple members had mentioned it was possible for Mazda dealers to bump the 118 mph limiter. I'm kind of curious if a tool like yours could do the same. [/quote] Yes, that’s one of several J2534 interfaces that are suitable. I bought mine directly from Drew Technology. They are great folks and they have some great products, including a standalone, completely programmable “glass instrument panel” which will be released soon. The capabilities of the MMP are rather limited and there is no control of your speed parameter. A subscription service with Mazda is required to use the MMP. The MMP has the following abilities – 1 - Update a flash for your specific VIN using a concurrent internet connection for “ET phone home”. 2 - Swap out a PCM or Instrument Cluster (IC) by reading data from the old unit and transferring it to the new unit. In the case of the PCM, the VIN and probably a bunch of other vehicle specific stuff gets transferred. In the case of the IC, the mileage gets transferred to the new unit. 3 - Program additional electronic ignition keys and delete (discontinue) keys. 4 - There are a number of other marginally useful features. You can change the tire size constant to true-up the speedo, but I couldn’t get this to work. Some of the other utility functions are described above. I believe Mazda logs the important activity against your VIN across the internet connection. I wouldn’t think there would be warranty issues unless you are at fault and screw something up. MMP was provided to allow non-Mazda garages to update and replace the critical electronic modules. I think making this type of limited open toolset available for the mom-and-pop garages is required by commerce law. It appears you can get the full-boat MMDS / IDS system (Teradyne J2534 VCM Pod and IDS software) which the Mazda garages use for $4K. It comes in laptop and PDA versions. You supply the laptop. |
#8 |
Bicycle Rider
Anyone know where you can rent a J2534 cable? $450 for one flash is even more than the $102 I was quoted by the dealer.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
