Oil change - how many quarts did it take? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 02-10-2007, 02:12 PM   #1
ZooZoom
Default Oil change - how many quarts did it take?
did my first oil change last week. the manual clearly states that the oil capacity is 6 U.S. quarts.
but after putting 5 qts in the dip stick read right at the top (full) hole. I checked it after a few days and its still right at the full level.
so is it really supposed to take 6 quarts?
ZooZoom is offline   Reply With Quote
Old 02-10-2007, 03:09 PM   #2
warpspeed
Grand Am Series
Default Re: Oil change - how many quarts did it take?
Yes its suppose to be 6 qts. Now this is my first turbo car. I don;t know if the extra quart is for the Turbo I have no clue. But its strange you only took 5.
warpspeed is offline   Reply With Quote
Old 02-10-2007, 03:14 PM   #3
ZooZoom
the turbo's oil cooling lines should feed right off the same reservoir as the engine.
I'll keep an eye on the dip stick level. just wondering what's been the experience of other MS3 owners who've done their own oil changes recently.
and yes, this was with the oil filter changed out.
Old 02-10-2007, 04:49 PM   #4
ClickHeRe
Grand Am Series
It took me less than 5L (big jug of Mobil1 5w30).
There is always oil left around and you can't drain it all even with the filter off.
2007 True Red Mazdaspeed3
Mods: TWM Shifter Bushings, Corksport Mount Insert
Upcoming Mods: Cobb AP + Intake, MS Coilovers, Hotchkis Swaybars, Mazdaspeed Smokey Chrome 18x7.5, Chromium Angel Eyes
ClickHeRe is offline   Reply With Quote
Old 02-11-2007, 11:21 AM   #5
jcrystal
Short Track Racer
Default Less than 6
I changed the oil myself and it definitely took less than 6 qts. Dealer did the second change and probably put in 6 which overfilled it....
jcrystal is offline   Reply With Quote
Old 02-11-2007, 01:29 PM   #6
redms3gt
Grand Am Series
5qts here. Its about the same changing the filter or not. It dosent hold much in there.
redms3gt is offline   Reply With Quote
Old 02-11-2007, 04:53 PM   #7
ZooZoom
I agree that 5 qts seems to fill up the oil pan completely.
just kinda weird that the manual clearly states it takes 6 qts. :?
Old 02-12-2007, 12:20 PM   #8
dutchie3
what is the consensus on this?
6 qt total capacity, but 5 qt for change? Good to know if you are doing yourself.
I'm from the government, and I am here to help you.
dutchie3 is offline   Reply With Quote
Old 02-12-2007, 12:53 PM   #9
ClickHeRe
Grand Am Series
It takes close to 5 quarts (I have 5L Mobil1 jugs and it took almost 1 jug), you can't remove it all as the service guy told me last time when I said "hum, thought it was 6qt from the manual" and he confirmed that you couldn't get it all out even with the filter out.
Old 02-15-2007, 09:32 PM   #10
ElyasWolff
Short Track Racer
I donít know about FWD. But, when I drove RWD cars it was wise to over fill the sump by 1/2 qt. The logic was; under hard cornering the oil might cling too hard to the side of the sump, moving away from the oil pickup and causing oil starvation.
So I have no problem overfilling by 1/2 qt. (which 6qts fills to on my MS3)
1/2 qt will not harm anything. now if you put 9qts in the crankcase you might fill it up so far that the oil flows over the windage tray and contacts the crack, causing massive drag on the crankshaft.
1992 Miata: Individual Throttle Bodies, MegaSquirt, 11:1 camed up motor, 1978lbs, Gutted Beast of a Car, 130WHP Naturally Aspirated (that is on a 1.6 with 90whp stock) RIP: Killed by a Semi-Truck
2007 MS3: TWM Bushings, AWR 88, MazdaSpeed CAI, TurboXS Hybrid BOV and Race Pipe
ElyasWolff is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > MazdaSpeed > MazdaSpeed3 DISI General Powertrain
