How To Install Cargo Net-Mazda 3 (Sedan) - Mazda3 Forums : The #1 Mazda 3 Forum
Old 12-24-2006, 10:30 PM   #1
Ivy
Moped Rider
Default How To Install Cargo Net-Mazda 3 (Sedan)
How to install the cargo net for a 2007 Mazda 3, 4 door sedan
Tools needed:
5/16 or 8mm drill bit
flat head screw driver
1: Remove the existing clips in the “trunk end trim” plastic interior piece:
these are where the t-anchors will be going.
2: Remove the rubber trim around the trunk end trim. Remove the trunk end trim plastic piece completely:
be careful not to bust the plastic clips which hold this piece down – be easy with it and take your time. This piece needs to be pulled upward not outward.
3: Now time to use the drill bit and drill the existing holes bigger in the top holes (metal)
4: The same thing needs to be done on the bottom holes however this is only plastic (part of the carpeting).
5: Insert the rubber grommet which came with the flat end t-anchors into the bottom holes in the plastic (carpet).
6: Reinstall the trunk end trim piece back on the vehicle. Now screw the top t-anchors in threw the plastic and into the metal (do not strip them). Also you may need to slightly drill the plastic hole to be a little bigger.
7: Now screw the bottom t-anchors into the bottom rubber grommet which you installed into the carpeting. These will take a little bit of turning to tighten. The idea here is for the rubber to flex and expand behind the carpeting causing it to be harder to pull out.
8: This is what it should look like – now just put the rubber trim back on and put the cargo net in.
2007 Mazda3 S Touring Sunlight silver
Ivy is offline   Reply With Quote
Old 12-24-2006, 11:00 PM   #2
f4i kyle
Location: Tallahassee, Boynton Beach, and Pensacola, FL
Default Re: How To Install Cargo Net-Mazda 3 (Sedan)
You guys had to install your cargo net? Lame (we've got built-in clips)
f4i kyle is offline   Reply With Quote
Old 12-24-2006, 11:52 PM   #3
mattleegee
:lmao:
2000 Toyota Tacoma
2007 MS3 SOLD 07/11/08 for $19,000
mattleegee is offline   Reply With Quote
Old 12-25-2006, 05:36 AM   #4
PierreB
Send a message via MSN to PierreB
nice how to, but not sure why you needed the drill for, I installed my cargo net without needing the help of the drill. hehe
PierreB
Mazda 3 2006 GT-GFX (R.I.P October 18th 2009)
Founder of: www.mazda5quebec.com
PierreB is offline   Reply With Quote
Old 12-25-2006, 06:35 AM   #5
icspots
Super Moderator
icspots's Avatar
wow, so does that little strap in the middle of the net let you attach both sides of the net to keep it from splaying apart? If so then I'm jealous because my 5-door one doesn't do that, and occasionally heavier things will just roll out.
icspots is offline   Reply With Quote
Old 12-25-2006, 09:56 PM   #6
zorminster
Send a message via AIM to zorminster
i was replacing the tailights in mine today and was messing around with my cargo net stuff..... and im terrified to know that THAT is how its supposed to be installed.... my rubber grommets are collapsed to the size of a lock-nut. I ended up adding some washers and just sticking in behind the plastic pannel to hold the bottom ones- theyre installed pretty securely now and dont seem to wanna pull straight through the thing. Whoever installed the net originally @ the dealership put the bottom ones in at a ridiculous angle- i think thats what caused the deformation originally.
2006 Sunlight Silver Sedan
LED Tails - VisualGarage Sharkfin - Hosetechniques SVH - XenonExpert Pedals
http://www.cardomain.com/ride/2441419
zorminster is offline   Reply With Quote
Old 12-26-2006, 12:30 PM   #7
Ivy
Moped Rider
The drill was to ensure that none of the T-anchors were stripped on the way in.
Old 03-04-2007, 06:13 PM   #8
ekcooper
Bicycle Rider
Folks,
I just joined this group so I could look up things like this. And, thanks for the instructions. I didn't follow these exactly, because the rubber grommet and washer go behind the plastic completely (not reset). But, I did need your instructions about taking off the plastic molding. Still, I broke one of the attachments. I must say, this setup is stupid. I expected addiing a cargo net would take about 2 minutes, not turn into this crazy production that required me to take apart parts of the car. Anyway, thanks for the great pictures.
Eric
ekcooper is offline   Reply With Quote
Old 03-07-2007, 07:59 PM   #9
ENH729
How much did the net cost you?
Looks good!
2006 Mazda3s GT Sedan Titanium Gray|Shark Fin Anenna|Removed Front License Plate|Mazda Raised Spoiler|35% Tint|Phatbox|Garmin 350|Cobra|
ENH729 is offline   Reply With Quote
Old 03-08-2007, 07:07 AM   #10
nxt
Send a message via AIM to nxt
I want a Cargo Net so bad, but taking that Trunk End Trim thing is a bitch! I was fooling around my car, and was trying to do something and wanted to take that piece off and for the life of me could NOT do it. So, seeing as that piece needs to be taken off, guess I wouldn't be getting the cargo net
nxt is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > Interior Modifications
