How much tire pressure goes into nexen tires? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 09-10-2006, 12:31 PM   #1
sweetface
Send a message via AIM to sweetface Send a message via MSN to sweetface Send a message via Yahoo to sweetface
Default How much tire pressure goes into nexen tires?
I did a little searching before I posted this, but I no longer have the TPMS system and I have Nexen 225/40ZR18 tires and I'm wondering how much air goes into them?
TWM Short Shifter-18" Enkei RSVs-Injen CAI-Magnaflow Exhaust-Sharkfin-Progress Rear Sway Bar-SPC Rear Camber Links
StreetUnit.com
sweetface is offline   Reply With Quote
Old 09-10-2006, 04:46 PM   #2
Midnight_Speeder
Send a message via MSN to Midnight_Speeder
Default Re: How much tire pressure goes into nexen tires?
The max load (PSI) should be on your sidewall.
But Mazda is recommended at 32 p.s.i (I think..)
Midnight_Speeder is offline   Reply With Quote
Old 09-10-2006, 07:47 PM   #3
Vince8739
[quote author=Midnight_Speeder link=topic=56501.msg943265#msg943265 date=1157921168]
1) never inflate to the max load 2) mazda recommended is for the stock size, 205/50/17
I would recommend you inflate to 35 and drive it for a little while and see what you like and adjust up or down a few psi; there's no hard and fast pressure. YOu can vary up or down a bit without any problem. It can kind of get to be a personal preference toward ride comfort and handling leveraged against even tire wear.
2004 3s Sedan, 5spd, Velocity Red, Kuhmo ASX
Vince8739 is offline   Reply With Quote
Old 09-10-2006, 08:55 PM   #4
mantiss
Grand Am Series
well if u over infalte middle tread will wear faster and you will lose alot of traction, if u underinflate your tire will bow the opposite way and wear the ouside tread, and agian lose traction. as far as psi go, i have no idea.
mantiss is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Wheels / Tires
