Thread Tools |
#1 |
The changed the front pads, added the shimmer and replaced the bolts on the caliper. It still squeaks for the first 5 times of braking when the car is cold. This is after after almost 500km on the new pads so I consider them fully broken in.
Is this normal? Maybe it's the back that's squeaking? Although I don't remember there was a TSB about that.
2004 Mz3 GT Sedan (5 speed) with GFX in Indigo Blue... That's right Indigo Blue! Motor Oil ----- Mobil 1 0W20 Synthetic ----- Transaxle Oil ----- Redline MT-90 ----- |
| Sponsored Links | |||
Advertisement | |||
#2 |
there is a tsb fo both....the front needs to be grinded i think
#3 |
my bad the rears need to be grinded
#4 |
Did they turn the rotors?
If so, I think it's normal and that the pads are seating themselves into the rotors.
2005 Lava Orange Mica Mazda3s 5-Door ||4-Speed Sport AT||ABS/SAB/SAC Package ||KONI Sport Yellow Adjustable Shock Absorbers|| K&N Filtercharger || Mobil 1 5W-30 ||3.5" Stubby || Garage Vary Valiant Front Lip || Axela MAZDASPEED Shift Knob || MAZDASPEED Pedal Set||Zoom-Zoom. SOLD!
#5 |
I don't think they turned the rotor. They rear needs to be grinded??? as in the rotor needs to be turned?
#6 |
Moped Rider
Had my 05 3 back to dealer and complained about either brake squeek or grinding noise, for the first few brakes especially when weather is cold or damp.
Got their normal reply NORMAL FOR THE MAZDA 3....it seems everything I complain to this Dealer comes back as being normal for the Mazda 3. They tell me it is because of a slight build up of rust on brake pads/rotors. It is this scraping of rust that has formed, that you hear. After repeated braking the rust is removed and noise goes away. Sometimes, you swear there is Metal to Metal contact going by the grinding sound you get sometimes. There were several TSB"s regarding brakes on the 04 models though. |
#7 |
Short Track Racer
phattires, that's exactly what i've been noticing on my M3 too. If you drive in the rain and then leave the car in a dry garage overnight, you'll get a light coat of rust on the rotors. First couple of brakings squeak as you grind off the rust and get back down to clear metal. After that it's good.
Here in Vancouver I can expect mine to be like this 8 months out of the year, probably.
-- 2012 Mazda 3 Sport GS-Sky - Newport Slate 2005 Mazda 3 Sport GS - Winning Blue - Pioneer Navi (traded in!) |
#8 |
no, the rears have burrs sticking out which causes the squeaking. so they grind the burrs down or something to that effect
#9 |
So should I just accept this as normal when it squeaks for the first 5 times after the car's been sitting for a few hours?
I mean it's more of a annoyance issue than a functional defect. i don't want to start war with my dealership over something this small.
#10 |
im taking mine in for that...when i have some tie anyways...and my clutch squeaks like a mofo
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
