Squeaking brakes - Mazda3 Forums : The #1 Mazda 3 Forum
Old 12-02-2005, 04:09 PM   #1
barhoc11
Grand Am Series
Default Squeaking brakes
Would very loud squeaking breaks be covered by the Mazda warranty? Ive have my car less than 3 months and dont rag on my car at all but I get a very loud squeaking when I brake to a complete stop.
- 2006 Mazda 3 GT - 35% Tint - Eibach Pro Kit - Shark Fin - 2 Tone side steps - auto start - TPMS - Bose -
barhoc11 is offline   Reply With Quote
Old 12-02-2005, 05:14 PM   #2
dallasmz3
Go-Kart Driver
Send a message via Yahoo to dallasmz3
Default Re: Squeaking brakes
Yep, my 4 month old 2005 just started squealing like a commuter bus. Especially on cold mornings or anytime it is 50 degrees F or below.
2005 WB Hatch
Ground ETB, Simota SRI, Tint, AWR Mount, Progress sway bar.
dallasmz3 is offline   Reply With Quote
Old 12-02-2005, 08:14 PM   #3
cbogey88
Send a message via AIM to cbogey88
Mine squeak a little when its cold.. I thought they were only supposed to squeak when the pads were worn.. what gives?
cbogey88 is offline   Reply With Quote
Old 12-03-2005, 04:50 AM   #4
rpn453
I had that problem. I put some Permatex Disc Brake Quiet on the back of the pads and it made a huge difference. It rarely squeals now.
Pads that are worn will squeal constantly, and may even squeal less when the brakes are applied. Pads that squeal on application of the brakes do so due to poor design. Mazda should have used shims or something on those pads.
04 Mazda 3 Sport GT 5 Spd 60K Miles | GC 0W-30 | MT-90
Michelin Pilot Sport A/S 205/50R17 OEM 17's | Cooper WeatherMaster S/T2 205/55R16 Studded on OEM Steelies
5% Tint | Fiamm Air Horns | Infinity 5X7 | Alpine R12 | Alpine MRV-100M | CP-E Mount | Autovation Pedals (heel-toe friendly) | Top Speed LCA Bushings
Wiring Mods: One-Touch Keyless Entry | AC Compressor Control | OEM Shock Sensor
Problems to Date: MAF Wiring (warranty), Front Engine Mount Failed (warranty), LCA Bushings Failed
rpn453 is offline   Reply With Quote
Old 12-03-2005, 01:30 PM   #5
amigo-2k
Moped Rider
Yup, the same thing here on my 05 which is about 4 months old.
Now that it is cold here in Wisconsin it does it for the first 5 or so stops and then it is fine.
I'm taking it in tothe dealer for an oil change in a couple weeks and I'm going to ask about it since I know there is a TSB on it.
amigo-2k is offline   Reply With Quote
Old 12-03-2005, 03:00 PM   #6
root
i mentioned the squeak to the service writer last time i was changing the oil, and at first he tried to write it off, "all cars do it". Then the mechanic discovered the TSB, they ordered the special brake pads per the TSB, and I am getting them installed on monday. All free.
no sig
root is offline   Reply With Quote
Old 12-03-2005, 06:51 PM   #7
cbogey88
cool, i got a maintenance comin up. ill check that out.
Old 12-04-2005, 05:55 PM   #8
nifty6
I have the squeaking brakes on damp or cool morings. Here in Canada the TSB is not valid and the dealer will not fix it. Had this problem since day 1 or 300 miles.
A new car and I have to pay to have the brakes fixed, o well...
nifty6 is offline   Reply With Quote
Old 12-07-2005, 03:06 PM   #9
echanchisai
Send a message via ICQ to echanchisai Send a message via AIM to echanchisai
You can just put on some anti-squeal compound on the back of the pads...but of course this requires removing the wheel and loosening the calipers.
_/\_ _/\_ I love automotive motorsports _/\_ _/\_
2008 Sunlight Silver Mazdaspeed 3 Sport - Zoomy
1995 Miata - Wendy Whiner
(Formerly: 2006 Mazda 3s 5-door - modified)
echanchisai is offline   Reply With Quote
Old 12-09-2005, 09:15 PM   #10
invent
Go-Kart Driver
hey dudes
i also live in toronto - home of the polar bears, and i get the squeek on my few months old 05. what is the solution for this? it goes away after getting warmer. i once drove about two miles not realizing that my passenger had pulled the parking break. when i got home a few minutes later there was a lot of break pad smell coming out.
would this have had anything to do with the squeeking?
05 M3 4D WB GFX LTR 20% AUX SIR
invent is offline   Reply With Quote
