How-to Guide: Rotor, Brake Pad, and BrakeLine install/replacement (FRONT / REAR) - Page 19 - Mazda3 Forums : The #1 Mazda 3 Forum
Old 07-01-2009, 02:38 PM   #181
vtluu
Moped Rider
Default Re: How-to Guide: Rotor, Brake Pad, and BrakeLine install/replacement (FRONT / REAR)
[quote author=bnwsting97 link=topic=32297.msg3206841#msg3206841 date=1246472962]
what about this
http://www.ehow.com/video_2327156_co...-calipers.html[/quote]
That really only works with the front calipers, and even then, even if you could get the screwdriver in there, chances are you'd bend/break the screwdriver.
I've regularly swapped pads on many different cars and I've never used that trick--it wouldn't move the pistons in enough in any case. I've also never used a brake "special tool"--careful use of C-clamps, channel-lock pliers, etc. whatever's appropriate has always worked just fine.
For example on my Evo I can just open the bleed screw, connect the bleed bottle and compress the pistons with my hand. But it's a very different caliper design. The Evo has separate parking brake drums so the rear pistons can be compressed just like the front. Most cars (those that have rear disc brakes) have rear parking brake adjusters that you need to turn to compress the rear pistons.
Viet-Tam Luu (a.k.a. "Tam&quot
Director, SCCA San Francisco Region
2011 Improved Touring S Regional Champion
vtluu is offline   Reply With Quote
Old 07-01-2009, 03:05 PM   #182
bnwsting97
Grand Am Series
[quote author=d-machine link=topic=32297.msg3205599#msg3205599 date=1246405179]
[quote author=bnwsting97 link=topic=32297.msg3205408#msg3205408 date=1246396217]
[quote author=icspots link=topic=32297.msg3151445#msg3151445 date=1243699985]
[quote author=cebo0650 link=topic=32297.msg3149620#msg3149620 date=1243609608]
Man, you weren't kidding when you said you have to push ungodly. It's two days later and my hands still hurt but I was able to get the caliper back in and get the brakes installed.
Thanks for the help! Next time around it will be much easier now that I know what to do
Next time spend the ~$20 and get the caliper compression tool....... makes the piston go in "like buttuh", plus then you'll have the tool for the next time around. Some auto parts stores will loan them out for free too.
Happy to help.
[/quote] we're talking about a c-clamp right?
NO dont go with a c clamp, you will likely cause damage trying to jam it back it... you have to put pressure and turn at the same time, the compression tools that you can rent/buy do this
i've always used a c-clamp and never had a problem
HKS CB - K&N CAI - Eibach Pro-Kit - Hood Struts - Grounded TB - 35% Tint - Red Calipers W/Mazda Decals - Shark Fin - Side Molding Delete - 4100K Fogs
bnwsting97 is offline   Reply With Quote
Old 07-06-2009, 12:05 PM   #183
Melissa8483
Bicycle Rider
Hi all, I'm about to have my brakes done over the upcoming weekend. I bookmarked the how-to that was reposted on wildweasel with the torque settings. Can anyone tell me where these torque settings came from? Are they reliable or did someone just guestimate?
Thanks!
Melissa8483 is offline   Reply With Quote
Old 07-06-2009, 02:13 PM   #184
vtluu
Moped Rider
Melissa, chances are the torque specs are from the Mazda factory service manual.
Here's what I got out of my copy of the FSM:
Front brakes:
Caliper bracket bolts: 78.5-102 N-m (57.9-75.2 lb-ft)
Caliper slider pins: 25-30 N-m (19-22 lb-ft)
Brake line fitting: 20-27 N-m (14.8-19.9 lb-ft)
Brake bleed valve: 7-9 N-m (70-79 lb-in) (regular 3), 12-16 N-m (107-141 lb-in) (Speed 3)
Rear brakes:
Caliper bracket bolts: 59.5-76 N-m (43.9-56.0 lb-ft)
Brake line fitting: 19.1-23 N-m (14.1-16.9 lb-ft)
Brake bleed valve: 12-16 N-m (107-141 lb-in)
Old 07-06-2009, 02:18 PM   #185
sok07
Send a message via Yahoo to sok07
Affirmative. Torque specs were sourced directly from the factory service manual.s
2009 Mazdaspeed3
Cobb AP | Cobb DP | Cobb bpv | Tubular exMani | PTP hpfp internals | RPMC turbo inlet | 3.5" core ETS TMIC | EliteEngineering PCV catchcan | CPE Trans/Pass MM | TWM SS | SU RMM | Cobb R anti-swaybar | H&R coilovers | Porsche997 bixenon projector | bosch h3 projector foglights | ...etc, etc
2003 Toyota MR2 spyder
1973 MGB GT
sok07 is offline   Reply With Quote
Old 07-06-2009, 02:34 PM   #186
Melissa8483
Bicycle Rider
Thanks guys!
Old 07-15-2009, 04:17 PM   #187
bnwsting97
Grand Am Series
anyone know what brand rotors he used?
Old 09-06-2009, 04:03 PM   #188
bernie3674
Bicycle Rider
what happened to the pics? I need to replace my rotors soon haha
bernie3674 is offline   Reply With Quote
Old 09-06-2009, 04:32 PM   #189
icspots
Super Moderator
icspots's Avatar
[quote author=bernie3674 link=topic=32297.msg3313505#msg3313505 date=1252267396]
just drop sok07 a pm ..... Maybe his hosting site is down.
icspots is offline   Reply With Quote
Old 10-21-2009, 05:51 PM   #190
trainspotter
Moped Rider
Send a message via ICQ to trainspotter Send a message via AIM to trainspotter Send a message via Yahoo to trainspotter
[quote author=icspots link=topic=32297.msg3313521#msg3313521 date=1252269153]
i saved these instructions to my laptop at home, including pics. i don't think saved the brakeline info though. i'll try to repost later w/ the pics hosted (hopefully we don't kill photobucket).
Life's a garden,
DIG IT!!
trainspotter is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Suspension / Brakes > Suspension / Brakes Technical Information, FAQ's, How-To's
