nav and remote/starter wiring diagram - Mazda3 Forums : The #1 Mazda 3 Forum
Old 02-26-2005, 02:48 AM   #1
toperz
Moped Rider
Default nav and remote/starter wiring diagram
i need wire diagram for 05 mazda3 2.3l hatchback
im installing rem/start and pioneer avic-n1
for nav i need speed sense wire(VSS) color
for r/s everything else
anybody knows where i can find it??
thanx
toperz
'09 Mazda3 Hatchback/2.3l/17" wheels/AUTOMATIC/golden sand metallic/
wife:
'10 Mazda3 Sedan/2.0l/16" wheels/Automatic/graphite/
toperz is offline   Reply With Quote
Old 02-26-2005, 04:46 AM   #2
moeman949
Send a message via AIM to moeman949
This is for a alarm I am getting. IDK if there is any difference.
Quote:
Mazda
Mazda-3
2004-2005
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
Black/Blue (+)
Ignition switch harness
Ignition #1:
Blue (+)
Ignition switch harness*
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
Black/Red (+)
Brake Light:
Green (+)
Brake pedal switch
Tach Signal:
N/A
Parking Lights:
Lt.Green/Black (+)
Drivers kick panel
Headlights:
N/A
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
*This vehicle is equipped with a Transponder Anti-Theft Security System.
Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
and this http://www.directwholesale.net/diagr...&MakeID=29
Hope that helped.
moeman949 is offline   Reply With Quote
Old 08-22-2005, 06:31 PM   #3
krstofer
Default Re: nav and remote/starter wiring diagram
I think I'm retarded. Why can't I find this damn door lock wire. I see it at the trigger, but not in the kick panel.
krstofer is offline   Reply With Quote
Old 08-22-2005, 09:50 PM   #4
ssinstaller
Look at the post about 3 topics down by fraken21, it has pictures showing where most of the wires are.
2006 Mazdaspeed 6
*Defi Link meter BF boost guage*6000k HID fogs*HKS SSQV BOV*Battery relocation kit*Odyessy PC680MJT battery*CP-E Xcel CAI*CP-E downpipe catless*CP-E mot_r mount*CP-E catback exaust*Fiber Images CF hood and* trunk
Future Plans:AutoEXE CF grille*Corksport CF Pillars*CP-E Front Mount*HKS Coil_vers*Garrett GT3076R*Cobb Accessport
ssinstaller is offline   Reply With Quote
Old 08-22-2005, 10:29 PM   #5
krstofer
Yeah, unfortunately, that is one of them. He said he will post more pics.... I guess my car will have to be in peices for a while.
Old 08-23-2005, 12:08 AM   #6
toperz
Moped Rider
this wire diagram is from diffrent source it may help u guys( it worked for me)
WIRING INFORMATION - MAZDA / 3 / 2005 / Remote Start
12volts* red (30A), black/red (30A)* *+* *ignition harness*
Starter* gray/black* *+* *ignition harness*
Second Starter* N/A* * * *
Ignition* green/yellow* *+* *ignition harness*
Second Ignition* N/A* * * *
Third Ignition* N/A* * * *
Accessory* pink/yellow* *+* *ignition harness*
Second Accessory* yellow* *+* *ignition harness*
Keysense* red/black* *+* *ignition harness*
Power Lock* green/red* *-* *driver kick, door harness*
Notes: Lock is negative trigger thru an 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock* same as power lock wire* * * *
Lock Motor* yellow/black* *5wi* driver kick, door harness*
Unlock Motor* white/black* *5wi* driver kick, door harness*
Parking Lights+* orange/white (L), orange (R)* *+* *passenger kick, harness to rear*
Parking Lights-* black/white* *-* *headlight switch*
Hazards* black/orange* *-* *hazard switch*
Turn Signal(L)* blue* *+* *passenger kick, harness to rear*
Turn Signal(R)* blue/red* *+* *passenger kick, harness to rear*
Reverse Light* green/orange or green/black* *+* *passenger kick, harness to rear*
Door Trigger* see notes* *-* *passenger kick, harness to rear*
Notes: The LF door is black/yellow, the RF door is black/blue, the LR door is black/orange, and the RR door is black/green. Use all four wires and diode isolate each. These wires are also found at the Passenger Junction Box behind the glove box.
These wires may rest at ground with the doors closed and go to an open circuit when the doors are opened.
Dome Supervision* black/blue to black/red* *-* *passenger kick, harness to rear*
Trunk/Hatch Pin* black/red or black/blue* *-* *passenger kick or light in trunk*
Hood Pin* black/yellow* *-* *hood pin switch*
Trunk/Hatch Release* N/A* * * *
Power Sliding Door* N/A* * * *
Factory Alarm Arm* black/blue* *-* *driver kick, door harness*
Notes: This wire may also lock the doors.
Factory Alarm Disarm* black/white* *-* *driver kick, door harness*
Notes: This wire may also unlock the doors.
Disarm No Unlock* * * * *
Tachometer* NOT green/stripe* *ac* *any ignition coil or fuel injector*
Wait to start* N/A* * * *
Brake Wire* red/white* *+* *brake pedal switch*
Parking Brake* black/lt. green* *-* *parking brake switch*
Horn Trigger* black* *-* *horn switch*
Memory Seat 1* N/A* * * *
Memory Seat 2* N/A* * * *
Memory Seat 3* N/A* * * *
Interface Module: Category:
Immobilizer Bypass* Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:*
Door Lock Interface* Required:
Yes Type:
Multiplex
Part #: 456LW
do not forget hook up sec. acc.
for door trigger i used door light supervision(doom light)(works the best because all door triggers are wired separatly and u will have to use diodes to make them work correctly)
about speed sense wire I still did not find it
any questions* ---- > post it and i'll try to answer for u
i will try make some pitures where is everything located( i didnt have camera when i was istalling rem.start/alarm}
toperz
wife:
Old 08-23-2005, 10:17 AM   #7
krstofer
[quote author=toperz link=topic=15909.msg380048#msg380048 date=1124770126]
I keep reading this info and looking for the wire, but I can't find it. Is it right in the kick panel, or up behind the dash? Is it the same green/red as in the door connected to the switch?
This was found in another post
Old 08-23-2005, 06:34 PM   #8
toperz
Moped Rider
yup its same wire but to lock the doors u have to use 1000 ohm resistor, to unlock it is direct wire from ur rem/start. u dont have to use relays, use instead diodes to isolate.
toperz
wife:
Old 08-23-2005, 07:59 PM   #9
krstofer
Damn. I don't think my car has this wire behind the kick panel. Has anyone used it anywhere else? or a pic.
Old 07-12-2006, 06:48 PM   #10
krstofer
I was searching for another item and came across this. I can't believe what an idiot I was. I did find the wire.
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2004-2009 Electronics Discussion
