To keep down on the opening of topics for thermostat replacement and CELs related to the thermostat, here is a central how-to location. Below is the best how-to I've seen written (and the one I followed). It doesn't have pictures but if someone has some I'll insert them and assign credit like I did with this how-to by MZ3MadMax:
Before following this how-to, the thermostat you should buy should come from the dealer and be OEM. It's around $50-60. Link to part number. Verify with a dealer that the part number is correct for your vehicle. Reference purpose only. There are many documented cases of aftermarket thermostats failing fairly quickly. I can verify this as it happened to my self.
[quote author=MZ3MadMax link=topic=120362.msg3625491#msg3625491 date=1271796877]
You don't need to cut the AC Belt to do the thermostat. You only have to cut the AC Belt if you want to replace the serpentine belt - a whole different topic. You only need to take the serpentine belt loose to do this job. Some have claimed to have replaced the thermostat without removing the belt or the tensioner. I suppose that it is possible but I can't imagine that it would be easier.
The following (from memory) is a quick summary of the job on a 2.3L:
A) Tools - Metric socket set with 1/2" and 3/8" drives. A couple of extensions and/or deep sockets are helpful. a pair of pliers for the hose clamps
B) Supplies - replacement thermostat, 2 gal of pre-mix 50/50 coolant. I only used 1 gal but I used all of it...
1) Prep - put the car up on ramps or jack stands so you can easily get under the vehicle. Remove the plastic shield/cover under the motor. Remove the plastic cover on the top of the motor. Let the car cool off enough so that you don't get burned by the hot coolant.
2) Drain the radiator coolant. There is a Walk-Thru in the Maintenance section on Drain and Fill Coolant and hose replacement - same procedure. Remove the cap on the reservoir. Remove the plug (1/4 turn counter-clockwise and pull straight out) at the bottom and back of the radiator on the drivers side. Fluid will shoot out about 3 feet directly into the transmission and splash everywhere if you don't get a bucket in place to catch it so be ready. Once it is drained, replace the plug and make sure that it is all the way in and turned clockwise to lock.
3) Remove the serpentine belt from the tensioner. The tensioner is a silver device with a pulley on the top front passenger side of the motor. Take a socket on a ratchet and attach to the "bolt" on the passenger side of the tensioner and push toward the rear of the car to loosen the belt (maybe toward the front, I can't remember. This should be obvious though to loosen the belt.). While holding the tensioner, slide the belt over and off of the pulley. Try to be careful not to let the belt come off the other pulleys. If it does, no big deal, just pay attention so it can be routed properly later.
4) Remove the tensioner from the motor. I believe that there were 3 (maybe 4) bolts to remove from the front and it comes right off. The thermostat should be out in the open now as it is located just below the tensioner on the front of the motor. It is pictured above in this thread and has two rubber hoses connected to it.
5) Remove the two hoses from the thermostat. The hose clamps can be loosened by grasping them with pliers on the tabs. This will loosen the clamps and allow them to be slid further down the hose a couple of inches in order to clear the flanges on the thermostat. The hoses can now be coaxed off of the thermostat hose flanges. You may have to work them a bit to get them off but it should not be too difficult. More fluid will drain from the hoses so be ready for that. Move the hose ends out of the way as much as possible.
6) Remove the thermostat. This is three bolts on the front. The thermostat should come off quite easily and leave no gasket or residue. Again, some coolant may come out but not too much.
The rest is pretty much a reversal of the process:
7) Install the new thermostat. Check to make sure that the mounting face on the motor is clean - I would wipe it off with a paper towel. Make sure that the flat rubber gasket is located in the groove on the face of the mounting flange of the new part. The new part should come with the gasket pre-installed. Just put the new part in place and insert the bolts. The plastic mounting flange has steel inserts in the bolt holes so it wont crack. Snug them down pretty tight - I don't know what the torque spec is but I made them reasonably tight.
8) Re-connect the hoses. Some folks like to replace the spring hose clamps with "real" hose clamps that use a screw to tighten. Feel free to do so if you want - I didn't and have had no issue with leaks. If you do, be sure to put them on the hoses before you put the hoses on the thermostat. This seems obvious but I've done this wrong many times. No big deal, you just have to remove the hoses again... Put the hoses on and move the clamps back into position and tighten.
9) Re-install the belt tensioner. Put in place and insert the bolts. Again, make them snug but not over tight since you are threading them into aluminum.
10) Re-install the serpentine belt. Use the ratchet as before to move the tensioner pulley into place and slip the belt over the pulley. You will have to put the socket/ratchet through the belt before you move the tensioner, otherwise you will not be able to get the belt in place - you'll see what I mean. This can be a little trickey, just pay attention to the routing of the belt on the other pulleys and make sure that it is in the correct place. This is the only step where it might help to have another set of hands to hold the ratchet/tensioner while you move the belt around. There is a diagram/sticker nearby that shows the belt routing if it slips off too many places.
11) Replace the plastic shield/cover under the motor and the plastic cover on the top.
12) Fill the coolant reservoir. With a funnel, as you add coolant to the white container on the passengers side, it should begin to flow into the radiator - slowly. Put as much in (up to 1 gallon) as you can. When it stops taking any more, it is safe to start the engine. You might double-check the belt to make sure that it is installed properly before starting. Also, make sure that no one is standing over the engine when it is started just in case it throws the belt.
13) You can back the car off the ramps or remove the jack stands. As the car warms up, it will extract more coolant out of the reservoir. You may have to slowly add more coolant to the container as the engine warms up. After about 5 minutes if the motor is up to operating temp, you can top off the level to the "Max" mark. Drive the car around for another 5 minutes or so and then let it cool off completely. When totally cooled off, check the coolant level and fill to the "Min" mark. Check it again a a couple of days and make sure that it is at the "Min" mark when cool.
Congratulations, you're done.
It is harder to write all of that than to actually do it...
[quote author=codyds link=topic=202138.msg4193185#msg4193185 date=1330473303]
Here are some pictures, since they are few and far between.
That is where the pictures end, as my hands got too coated with coolant to pick up the camera again. But it is self explanatory from there!
