Mazda3 Forums
The original Mazda 3 and MazdaSpeed 3 forum and club
Please login or register.
Login with username, password and session length
Advanced search
Pages: [1] 2 3 ... 15   Go Down
Author Topic: THE INTAKE POST!!! (Info on every MS3 intake out there.) POST QUESTIONS HERE!!!  (Read 34633 times)
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Le Mans: Prototype Class
  • Date Registered:March 13, 2007, 06:21:34 PM
  • Site Posts: 1920
  • Transaction Count: (2)
  • Car Year: 2007
  • Car Model: 2007 MazdaSpeed3-GT
  • Connecticut Mazda Enthusiasts
Okay been working on this for a few hours now and i think i've compiled almost every intake out there for the MS3, post any info you have, this post is about info on all intakes so people can choose which is best for them... If I missed anything post it and i'll get the info up there(with credits)...
Rob
AEM Cold Air Induction System
Cold air induction system. Polished.
Part #: 21-642P
$332.85
NO IMAGE YET!!!
MazdaSPEED3 XCelTM Cold Air Intake
Custom Performance Engineering™ (cp-e™) is proud to announce the release of its XCel™cold air intake for the MazdaSPEED3.
Our XCel™ intake is unlike any other intake for the MazdaSPEED3. This isn’t just another clever marketing scheme; we actually apply several crucial design details to our intake that our competitors overlook. To illustrate our point, let’s consider how our competitors make their cold air kits.
Our competitors bend their standard size aluminum pipe (think 2.5”, 2.75”, 3” etc.) as one piece and then put a filter on the end of it. This is cheap and easy to manufacture, but the resulting vehicle drivability can be hit or miss because little attention is paid to the mass air sensor, which is arguably the most important sensor on your engine! Because our competitors use standard size pipe, the diameter of the mass air housing is not ideal, and this usually leads to knocking and/or hesitation under heavy throttle inputs.
The cp-e™ XCel™ intake on the other hand has several features that ensure an accurate mass air meter reading. We not only machine out mass air housings from aluminum blanks to tolerances of +/- 0.002” (about the width of a human hair), but we also include a stock-style airflow straightener, which our competitors delete, yet greatly improves sensor precision. The resulting fuel trims are nearly stock, and the vehicle drivability is unchanged from stock…save for the extra horsepower of course!
MazdaSpeed3 SF Intake
Netting a + 11 lb. ft. and + 6 HP, the COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains!
The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems.
HKS Racing Suction Reloaded Kits have been developed as the leading intake system for high performance applications. Each kit features aluminum suction pipes that have been tested for optimal air flow. Included in each kit is HKS' Reloaded filter with its patented Super-Funnel and new technical advances:
- Filter cage allows for 30% more intake surface area
- Aluminum back plate for added strength
- Sealing ring reduces contaminants from entering engine
- Dual Density wet filter element
available through
Available through HKS Authorized Dealers
Application    MAZDA 3 Mazdaspeed 2007
Part No. 70020-BZ002
Inlet Size (mm)   80
Element Size (mm)   200
Price   $325.00
MAZDASPEED Cold Air Intake Filter Assembly For MAZDASPEED 3
The MAZDASPEED Cold Air Intake features a mandrel-bent 6061 aluminum inlet pipe for durability and light weight. Each MAZDASPEED Cold Air Intake system's length and diameter has been tuned and tested to work with an engine's harmonics (resonance frequencies) to help carry more air to the inlet valves across the RPM range.
Bring cold air from outside the engine compartment into the engine through mandrel bent 2.75" diameter, polished and powder coated aluminum tubing. The intake system is designed for improved engine breathing, while re-using the stock MAF sensor. The kit utilizes the latest in dry filter technology.
The MAZDASPEED Cold Air Intake features a revolutionary DRYFLOW filter. Their unique non-woven polyester element is independently tested to filter out 98.6% of airborne fine dust in initial efficiency, with an industry leading cumulative efficiency of 99.4% (cumulative efficiency is the average for the test cycle). The DRYFLOW also filters down to ONE MICRON of particulate! Competitors claim that as the filter gets dirty, it filters more efficiently. While this is true, what they dont tell you is that their clean filter lets dirt through until it traps enough to become efficient!
MAZDASPEED Cold Air Intake systems come with a complete hardware kit and a comprehensive installation instruction guide.
Every MAZDASPEED Cold Air Intake is either C.A.R.B. exempt or pending C.A.R.B. exemption (50-state legal). All MAZDASPEED Cold Air Intakes are manufactured and assembled in the U.S.A.
Dyno Info From "Speedy3" From: Mazdas247.com
http://www.mazdas247.com/forum/showthread.php?t=123662934
Dynojet Research Dynos were run on 2 different days. Dyno with MAZDASPEED CAI was run on 3-5-07 and Dyno with stock airbox was run on 3-6-07. Yes, I had to take off the MS CAI and re-install the stock hardware! Actually, I'm still stuck with the stock HW cause I don't have time to change it.
Dynojet Research Dyno on MAZDASPEED 3 in Stock Configuration
    * Ambient Temp=64 deg. F
    * Atmospheric Pressure=29.80 in-Hg
    * Humidity=50%
    * Correction Factor=SAE 0.98
    * 2 Large Cooling Fans placed 5 ft. from front of car
    * Hood Closed
    * Runs in 3rd gear only
    * Runs started at about 2k RPM and stopped at about 6250 RPM.
Dynojet Research Dyno on MAZDASPEED 3 with MAZDASPEED CAI
    * Ambient Temp=63 deg. F
    * Atmospheric Pressure=29.90 in-Hg
    * Humidity=53%
    * Correction Factor=SAE 0.97
    * Hood Closed
Results:
    * 10.14% HP (24.2 HP)
    * 10.28% Torque (24.8 ft-lbs)
Injen
2007 Mazdaspeed 3 L4 2.3L Cold Air Intake System w/ MR Technology
F5 Fujita
COLD AIR INTAKE SYSTEMS
A Cold Air Intake is traditionally longer and in most cases extended behind the bumper cover so that it can ingest direct air that is both cooler and denser. In addition to more direct air, the longer plenum achieves higher torque gains as well as impressive horsepower figures. Depending on the complexity of the plenum route, the Fujita Cold Air Intake may come as a 1 piece or 2 piece intake system. Different diameters, filters, and bends are all key factors of the R&D process of each Cold Air Intake. The in-house Dynojet is the final judge of which intake configuration will make it to production. Air/Fuel ratios are also an important factor in testing the Cold Air Intake, ensuring that safe and near factory levels are maintained in order to not trip any electronic sensors on the vehicle.
BEGi Cool Air Box for the MazdaSpeed 3: Credit: RonTonkinMazda
The Cool Air System features a totally enclosed Air Filter and MAF meter. Protecting it from engine temperatures. The Cool Air Box mounts in two places. The MAF meter has a fixed mounting point. The price includes mounting hardware, air filter, Cool Air Box, and black powdercoating. The Cool Air Box can be powdercoated in a Chrome / Silver Color, or buffed aluminum.
p/n 90020    $178.00  Black Powder coating or Buffed Aluminum
p/n 90020S  $218.00 Silver Powder coating
Dyno Results:
NOTE: 2007 MazdaSpeed 3
Front Mount IC vs. Top Mount IC  Comparision
Xede w/ Base Map, Forge By-pass Valve, and the BEGi Cool Air Box.
Dyno provided by: numbnuts22715
AutoEXE Ram Air Intake By: gwood
Part number: MBM959
Price:  $847.53 USD (based on 9/27 conversion rate)!!!
« Last Edit: January 10, 2008, 09:37:25 PM by CT-Zoom-Zoom »
Logged
araw at bituin
  • Restricted Avatar
  • F1 Driver
  • Date Registered:February 09, 2006, 10:30:55 PM
  • Site Posts: 6740
  • Transaction Count: (1)
  • Car Make: Mazda
  • Car Year: 2007
  • Car Model: Mazdaspeed 3 Sport
  • 1 SLO 3
Re: THE INTAKE POST!!! (All info on every MS3 intake out there.)
« Reply #1 on: September 25, 2007, 01:43:37 AM »
good stuff. wers the Mazdaspeed one though? or is it the same as one of those listed?
JMS3GTL
  • F1 Driver
  • Date Registered:May 30, 2007, 08:49:56 PM
  • Site Posts: 5283
  • Transaction Count: (17)
« Reply #2 on: September 25, 2007, 01:50:49 AM »
STICKAAY!
Logged
PirateKitty
  • M3F - You buy parts you don't need, with money you don't have, to impress people you don't know.
  • Senior Member
  • F1 Driver
  • Date Registered:May 31, 2007, 03:37:30 PM
  • Site Posts: 7226
  • Transaction Count: (23)
  • Car Make: Mazda
  • Car Year: 2008
  • Leader of the Avatar Movement & teamLOL
« Reply #3 on: September 25, 2007, 09:39:17 AM »
^ agreed
Logged
[11:05] LaraW: I'm gonna take up scrap-booking.
[11:05] LaraW: screw cars.
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #4 on: September 25, 2007, 11:15:09 AM »
It's there, it's the one with the "streetunit" picture...
Logged
RonTonkinMazda
  • Dealer
  • F1 Driver
  • Date Registered:November 18, 2005, 04:16:44 PM
  • Site Posts: 4200
  • Transaction Count: (42)
  • Car Year: 2007
  • Car Model: MS3 GT NAV FTW
  • Forum Member
    • WWW
« Reply #5 on: September 25, 2007, 01:00:41 PM »
no BEGi box?
Logged
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #6 on: September 25, 2007, 01:07:07 PM »
Researching it right now!!!
Logged
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #7 on: September 25, 2007, 01:17:52 PM »
Updated!
Logged
peanutsparts
  • Grand Am Series
  • Date Registered:October 19, 2006, 01:36:20 PM
  • Site Posts: 494
  • Transaction Count: (0)
  • Forum Member
« Reply #8 on: September 25, 2007, 02:39:37 PM »
You will soon have to add a K&N filter CAI. Their in the process as we speak.
Logged
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #9 on: September 25, 2007, 07:16:13 PM »
As soon as its on the site i'll post it up... may do an exhaust post next too... the MS3 Borla catback just came out 3 days ago!!
Logged
CRiZO
  • Photo Whore
  • Date Registered:February 12, 2004, 05:14:36 PM
  • Site Posts: 1676
  • Car Year: 2007
  • Car Model: TRS3
« Reply #10 on: September 25, 2007, 07:30:39 PM »
Has anyone else dyno'd the injen intake?  Those gains seem.... bloated.
Logged
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #11 on: September 25, 2007, 08:42:17 PM »
Seems right to me, its inline with the MS intake...
Logged
blkspd3
  • Date Registered:March 15, 2007, 01:01:50 AM
  • Site Posts: 1124
  • Car Year: 2007
  • Car Model: Black Mica MazdaSpeed 3
« Reply #12 on: September 25, 2007, 09:53:17 PM »
thanx for puttin' in the time, Rob.  8)
Logged
AWR 70 mount_TWM shifter bushings_Shortened shift lever_Redline tranny oil_custom SRI_Amsoil air filter_Mild port work_Hotchkis fr/rr sways_G-tech accelerometer_Penzoil Platinum full synth
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
« Reply #13 on: September 25, 2007, 09:59:09 PM »
No prob just tryin to make it easier on us all, now if only people would post questions here..lol
Logged
NYXphil13
  • Grand Am Series
  • Date Registered:August 05, 2007, 08:08:35 PM
  • Site Posts: 283
  • Car Year: 2007
good thread
the only thing that is misleading is the gain numbers
If im reading the dynos and everything correctly, the cobb sri is rated with the least amount of gains, yet supposedly it makes more hp and less tq. Im guessing this is just becuase of the different dynos, but can someone clear up the gains for me somehow? I also have heard that when an ms3 with a cobb sri (no other mods) was compared to an ms3 with a MS intake (no other mods) they were dead even until higher mph then the car with cobb pulled away everytime. Everything i read says that the cobb sri makes just as good of gains as all the other cai's, but these numbers say otherwise. Whats up?
Logged
yup24z
  • Short Track Racer
  • Date Registered:July 23, 2007, 11:45:23 PM
  • Site Posts: 110
  • Car Model: 2008 MS3
good thread
The difference in the numbers comes down to dynos.  The cobb uses a mustang dyno where all the others were using a dynojet.  I don't exactly know *how* much lower they read, but it is pretty significant.  I'd bet that the cobb sri puts out around the same hp as the others given the same dyno
Logged
2008 Black Mica Mazdaspeed 3: Cobb SRI, Corksport DP, Turbo XS Race Pipe, Custom 3inch Catback, Stock boost, Cobb Springs, StreetUnit Motor Mount, Prosport Boost Gauge, Blacked out Stock Wheels/Emblems/Reflectors
Stock: 227hp/241tq
SRI,TBE, 18 psi: 279hp/315tq
bazguitarman
  • Go-Kart Driver
  • Date Registered:May 05, 2007, 09:00:20 PM
  • Site Posts: 88
  • Car Model: Mazda Protege "Skull and Crossbones" special edition.
good thread
Mustang dynos typically put down lower #`s. I`ve seen that across the board with front and rear drive cars. FI and NA. I think their software is set up to mimick "real world" road variables. I don`t know exactly what that means. But I assume the software actually acts as though you lose a slight amount of power on the street rather that sitting on a dyno in a controlled environment. I think.
Eric
Logged
araw at bituin
  • Restricted Avatar
  • F1 Driver
  • Site Posts: 6740
  • Car Make: Mazda
  • Car Year: 2007
  • 1 SLO 3
rofl damn im blind sry bout that. good job on this and it should be stickied ASAP
peanutsparts
  • Grand Am Series
  • Site Posts: 494
  • Forum Member
« Reply #18 on: September 26, 2007, 11:33:18 AM »
a exhaust and DP sticky would be great!
Good job!
Logged
gwood
  • Quality Control
  • Date Registered:January 20, 2007, 05:19:25 AM
  • Site Posts: 1331
  • Car Year: 2007
  • Car Model: Black Mica MS3
  • Strong if I can but I am only a man...
Anybody running the BEGI yet?  Thoughts?
Logged
Beer - It's not just shy sluggin' gorms neemer!
RonTonkinMazda
  • Dealer
  • F1 Driver
  • Site Posts: 4200
  • Car Year: 2007
  • Forum Member
    • WWW
i would like it more if it also replaced the intake tube thats one reason i am not sure about it.
Logged
gwood
  • Quality Control
  • Site Posts: 1331
  • Car Year: 2007
You could use it and use your own tube...?
Logged
CaSHMeRe
  • ... missing my ms3 ... :-(
  • F1 Driver
  • Date Registered:April 15, 2007, 05:25:59 PM
  • Site Posts: 3715
  • Transaction Count: (6)
  • Car Model: 2007 Acura RDX AWD Turbo
Re: THE INTAKE POST!!! (Info on every MS3 intake out there.) POST QUESTIONS HERE
« Reply #22 on: September 26, 2007, 07:38:28 PM »
yup... look at the pics.  its the stock intake tube, then maf housing, then filter and box
gwood
  • Quality Control
  • Site Posts: 1331
  • Car Year: 2007
« Reply #23 on: September 26, 2007, 08:06:55 PM »
So just replace the stock tube with a nice silicone piece is what I'm thinking.
Logged
F4i Kyle
  • FMVmoderator
  • F1 Driver
  • Location: Tallahassee, Boynton Beach, and Pensacola, FL
  • Date Registered:January 08, 2006, 10:17:13 PM
  • Site Posts: 12518
  • Car Year: 2006
  • Car Model: Whitewater Pearl Mazda3 Hatch, 5spd
  • wM2 - "The Self-Toucher"
« Reply #24 on: September 26, 2007, 08:19:42 PM »
Stickied, but keep it on topic or else the status will be removed.
Logged
CT-Zoom-Zoom
  • The "HKS" Guy...
  • Site Posts: 1920
  • Car Year: 2007
I hope this stays on topic, I spent alot of time on this...
Logged
wxchaser
  • Contributor
  • Date Registered:March 12, 2007, 02:09:58 PM
  • Site Posts: 1000
  • Car Year: 2007
  • Car Model: True Red Mazdaspeed 3 GT
Please keep it a sticky. I'm looking into a CAI right now and this has save me a TON of research time. Thanks to Zoom Zoom! :exnbpup:
Logged
Mods:
 - Mazdaspeed CAI
 - Forge BPV
Gadgets:
 - Compustar Pro P2W9000FMR Alarm / Remote Start
 - Passport 8500 X50 Radar / Laser Detector
 - TomTom One XL GPS Unit
gwood
  • Quality Control
  • Site Posts: 1331
  • Car Year: 2007
Might as well add the autoexe "ram air" intake for the sake of being complete.  Here are some pics:
http://www.autoexe.co.jp/english/car/MSAxela(BK)/MSAxela.html
Part number: MBM959
Logged
pipejaimes
  • F1 Driver
  • Date Registered:March 02, 2006, 12:21:17 AM
  • Site Posts: 2636
  • Car Model: 08 Cosmic Blue MS3
    • WWW
i tried searching for specs for the MS3 fujita CAI and i can't find any...
does anybody know what's the diameter of the Fujita pipe?
Logged
texasaggie09
  • Moped Rider
  • Date Registered:September 30, 2007, 11:44:23 PM
  • Site Posts: 28
  • Car Year: 2007
  • Car Model: Mazdaspeed 3 GT, Black Mica
Is anyone having any problems with driving in rainy conditions with any of these CAI's? One of my buddies got a AEM V2 for is civic and he can't drive when it rains with out sucking in water!!
Logged
Pages: [1] 2 3 ... 15   Go Up
« previous next »
