But if you plan on taking it out, then you most definitely need to put secure the transmission, or else it'll fall over...
The dogbone/rear/bottom mount wasn't designed to and will not hold the transmission solidly in its place. The passenger mount does.
and so it does... anyway:
Forum Username:
dbuengerCar build date:
09/06Car delivery/title date:
10/20Your location:
Roswell, GAMileage when problem occurred:
7700Did YOU check your bolt previously:
yes,but with a non torque wrench. it seemed fine...If yes - How many miles before the problem:
everything looked the same this time, until I put a T wrench to itDid your DEALER check the bolt previously:
YES. a week ago I took it in and asked them to check this bolt specifically. when I got the car back my radio station presets were still there so I checked it again. How was the car being driven? (Track, aggressive, casual):
Aggressive, but overall smoothly with rev matching, roll on accelerations, NEVER clutch dumping, etc. What did you do to Fix it?
Red lock tight and torqued to 75lbs.The car was doing the "clunck" thing when shifting to 3rd under power so I was pretty sure things were working loose. So far (it's been 2 days) things seem much more stable and no cluncking noises. seems to shift a little cleaner too.
