Mazda3 Forums
The original Mazda 3 and MazdaSpeed 3 forum and club
Please login or register.
Login with username, password and session length
Advanced search
Poll
Does your Mazda3 have weak A/C (at level 1 or 2)
Yes
- 491 (56.4%)
No
- 176 (20.2%)
Sometimes
- 148 (17%)
Only In the City
- 37 (4.3%)
Only On the Highway
- 1 (0.1%)
I am usually too cold
- 17 (2%)
Total Members Voted: 870
Pages: 1 ... 30 31 [32] 33 34 ... 51   Go Down
Author Topic: Problem: Weak ( A/C ) Air Conditioning (Now with 100% more Poll)  (Read 72817 times)
NoVa
  • Le Mans: Prototype Class
  • Date Registered:October 07, 2005, 12:59:35 AM
  • Site Posts: 1717
  • Transaction Count: (0)
  • Car Make: Ford
  • Car Year: 2009
  • Forum Member
Re: Problem: Weak ( A/C ) Air Conditioning (Now with 100% more Poll)
« Reply #930 on: June 13, 2006, 05:38:52 PM »
99F out today. had my car in the sun, but with the sunshield up in the windshield, and front windows down an inch. Got in at noon and turned the AC on 3. With the AC mod, I had 46F air blowing in about 2 min., and 40F in 4 min.  cabin got comfortable (noo cold, but cool) in 10min. Full sun, 99F. Posting the mod tonight..
Ooooh...intrigue!  Suspense is killing me!
« Last Edit: June 13, 2006, 05:39:12 PM by NoVa »
Logged
SILVER 2006 3sT HB - 5sp - sr/cd
* Sok07 Silver Flange Dead Pedal * 3M XPel * RPM AudioLink for i Pod * Hidden Hitch * Yakima KingPin2 Bike Carrier * Anco 3100 Blades * CX-7 Antenna *  General Altimax HP A/S tires @ 215/50/17 * '06 B.M.W. ///MCoupe
jpgilman
  • Bicycle Rider
  • Date Registered:May 09, 2006, 10:06:52 PM
  • Site Posts: 2
  • Forum Member
« Reply #931 on: June 13, 2006, 09:23:39 PM »
... Posting the mod tonight..
Waiting anxiously but hopefully
Logged
billm
  • Le Mans: GT Class
  • Date Registered:January 12, 2006, 08:41:12 PM
  • Site Posts: 683
  • Transaction Count: (5)
  • Forum Member
« Reply #932 on: June 13, 2006, 09:50:04 PM »
OK, here's my AC mod...
*** DISCLAIMER ***  -- I did this for myself, with the understanding that issues could arise. I am not suggesting one way or the other that anyone else should attempt it. There was a long discussion about the pros/cons/ and issues that could arise in the Auto A/C forums, which you can read here: http://www.autoacforum.com/messageview.cfm?catid=2&threadid=15144
There was mention this could be dangerous... Read that thread carefully. Obviously, this mod can void a portion of your warranty.
If you choose to do something similar, you are totally responsible for any issues that arise, or any kind of damages. I spent time to research this, I bought A set of manifold gauges to take readings, etc. and I feel confident that this will not be a problem for me, but again, I am showing this for reference only, because I can in no way be responsible for anyone else..
<paranoia off>
It was 99F out today. had my car in the sun, but with the sunshield up in the windshield, and front windows down an inch. Got in at noon and turned the AC on 3. With the AC mod, I had 46F air blowing in about 2 min., and 40F in 4 min.  cabin got comfortable (noo cold, but cool) in 10min.
OK, basically, our system compressor cycling is controlled by a number of things involving special cases, like first starting the car, throttle opening >%55, pressure too high or low, etc,
but the normal operating cycle is controlled by a thermistor mounted on the evaporator face inside the car which measures the air temp blowing past it through the evap. The resistance changes with temperature. The CPU inside the climate control unit senses the resistance, and cycles the AC request signal to the PCM (which controlls the compressor's magnetic clutch) based on the measurement. It is supposed to cycle on at 41F, and the off at 39F per the service highlights manual. At this temperature, the thermistor has a resistance of approx 5.1K ohm.
My goal is to change this resistance curve slightly, so the climate control unit thinks it is not as cold as it really is, thus the compressor on-time is increased. Too much on-time will result in the evap freezing up, which is not desireable. This is the downside to the mod. I am shifting my curve down by ~5F, which I feel comfortable with in hot weather. The mod can be changed to do less than this. I do not feel comfortable doing more than this.
To shift the curve, I am placing a resistor in parallel with the thermistor, so that when the thermistor is saying 37F, the CPU thinks it is 41F, roughly the switchpoint of the unmodified design. This gets about 5F cooler air from the vents for me.
For fuel economy and safety purposes, my mod has a switch to disable it completely, like in moderately warm weather where my current system works pretty well.
In addition, it has a safety timer that automatically disables the mod after a time interval. I built my timer mod such that I can adjust the delay to fine tune it. I am currently using 7 minutes, but as hot as it was today (100F, full sun), I may go back and readjust it for 10 Min. I don't feel comfortable yet with anything longer.
I also am using a switch that has a built-in LED, and my mod has a control output to drive the LED to signal when the mod is on or off, whether from being switched off, or from timing out.
Got your interest yet?
Here's a block diagram of the mod:
The timer circuit is powered on by the switch which starts the timer running. It has a relay that closes to place the resistor in parallel to the thermistor. Once it times-out, the relay opens and things are back to stock operation. My timer has an extra control output that drives the LED in the circuit so I can see when the mod is off or on. I'm not going into a lot of detail about the timer, but it is just a straightforward  one-shot with a long delay interval which I can adjust from 3-14 min or so. I currently have it set at 7 Min. I might build a couple more..
Here's a couple of pics of my install:
First, I had to decide where to get power, and where to place the switch. I chose the trim piece next to the lighter, so I had to remove it to tap into the power and to mount the switch. To do this you need to remove the cupholder and move the trim piece around the shifter out of the way to get to the two screws holding it in. Open the console, and then pull up on the back of the cupholder section, and it will come loose. It is held by snaps only. then lift the back of the trim piece around the shifter, lift it up to unsnap it from the console, and pull it back. Then these two screws need to be removed:
Once they are out, the trim piece for the lighter needs to come out. It is a little tricky. Held into place by a snap-in on each side. Partially open the ashtray cover, and pull outward on one side to unsnap it, then do the other side. It takes a little patience.
Here's the back view, and the connectors that need to be removed to free it for drilling for mounting the switch:
Rather than tap the lighter wires for power to the switch and gnd to the module, I decided to build something to insert between the lighter and the plug. To fit into the plug, I took a standard .25" spade terminal and cut it in half. Not real pretty, but it works. The female sides are unmodified 3/16" terminals that will attach onto the lighter body. I added a fuse link for safety with a 0.5A fuse.:
Now it gets inserted between the plug and the lighter body. The orange plug wire is +12, the black wire is ground :
In these two pics, I already have the switch mounted, and the wires from the module run inside the center console to the trim piece. You can see how it is tied down with the wire ties to keep the connections from coming loose from the plug. :
The switch I bought has three terminals. The top is the fused +12, the center is switched 12v to the module, and the bottom is for driving the switch's LED, which the module does with the green wire. You can also see the black ground wire to the module coming from the lighter plug tap.
Here's a pic of my timer module. The passenger side kick panel has been removed by pulling out the single plastic "rivet clip" holding it in. I also have the cover to the PJB (fuse box) removed. You can see the wires for power, ground, and LED control are routed behind the side of the console to the switch area. It is only a foot or so away, and is easy to see how to route them when you are looking into the space where th lighter trim piece came out. The twisted pair of orange and black wires goes up to the connector for the thermistor.
The two white dots on the module are for the delay and LED brightness adjustment. I fuond that I needed to adjust the switch's LED brightness to match the AC control's green indicator light brightness.  The timer delay can be adjusted as well, but once I find the right setting, I'm going to leave it there.
The ends of the twisted pair have a set of molex terminals (spring clips) on them  so I can insert them into the back of the connector for the thermistor. That way, no permanent tapping is required:
These ends slide into the connector slots for the red and white thermistor wires. I just push them in behind the connector wires to make contact:
to keep them from wiggling loose, I cable-tied them to the slot the kick panel goes into. Make sure the head of the tie is out of the way so the kick panel end can seat properly:
Now I just laid the extra wire behind the carpet, and placed the module behind it as well. There is kind of a padded  opening it can sit in:
Done!
Anyway, with the switch off, after running the AC yesterday in 95F, my vent air temps stabilized at 43F. With the switch on, they stabilized at 38F!
Today at 100F outside it was 46F off, 40F on. You can tell the difference in less than 30sec when you turn it on...
From the design, you can see I chose a 36K resistor. If a larger resistor was chosen I might not have needed the timer, maybe something like 51 or 56K. It wouldn't get as cool, but it might not need timer  protection. I would still keep the switch though, because once it cools down, I don't want the compressor running any longer than it needs to to remain cool. Or if it did freeze, it could be disabled.
 I built a couple extra timer units.
P>S>, my car has standard tint sides and back. Not heavy tint, just light, but it also make a big difference..
Anyway, there it is...  :)
« Last Edit: July 07, 2006, 09:15:50 PM by billm »
Logged
newpz
  • Bicycle Rider
  • Date Registered:May 23, 2005, 01:04:43 PM
  • Site Posts: 8
« Reply #933 on: June 13, 2006, 11:07:29 PM »
 :shock:... Wow - good for you, man.  Way to take the initiative and accomplish something!!  It may have taken 30 pages and over 2 years, but this thread is finally worthwhile...  I am very, very impressed.
 :banana:
Logged
El Cheapo
  • Grand Am Series
  • Date Registered:March 12, 2005, 11:33:40 PM
  • Site Posts: 518
  • 2005 Mazda3 2.0L Auto
« Reply #934 on: June 14, 2006, 12:58:17 AM »
Bilm. Awesome!!  Where's the pic of the resistor?
Logged
rhythmless
  • search is your friend
  • Grand Am Series
  • Date Registered:April 17, 2006, 08:01:22 PM
  • Site Posts: 254
  • Forum Member
« Reply #935 on: June 14, 2006, 02:53:22 AM »
congrats on this mod. very impressive.
im being picky, but why did you not center the switch on the console piece?
Logged
icspots
  • Fighting natural selection one moron at a time.
  • FMVmoderator
  • F1 Driver
  • Date Registered:August 10, 2005, 01:14:55 PM
  • Site Posts: 12788
  • Transaction Count: (3)
  • Car Make: Ford
  • Car Year: 2005
  • Paramagic
« Reply #936 on: June 14, 2006, 06:35:44 AM »
Looks like he put it next to one of the little plastic ribs on the inside of that panel instead of having to cut it.  Of course he might just be leaving room for another switch.
Logged
                  Audio Input Thread || Key/Flip Key Thread
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #937 on: June 14, 2006, 07:43:50 AM »
 I drilled for a second switch
« Last Edit: July 07, 2006, 09:13:28 PM by billm »
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #938 on: June 14, 2006, 07:45:09 AM »
Well, it is inline with the orange wire at the module end covered in shrinkwrap. I put it inline so i could cut it out and replace it if needed with another value.
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #939 on: June 14, 2006, 05:44:32 PM »
 :banana:
Thanks, I did the same thing with the variable intermittent wiper (VIW) mod :
http://www.mazda3forums.com/index.php?topic=30885.msg744940#msg744940
Logged
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 12788
  • Car Make: Ford
  • Car Year: 2005
  • Paramagic
« Reply #940 on: June 14, 2006, 06:00:07 PM »
Logged
NoVa
  • Site Posts: 1717
  • Car Make: Ford
  • Car Year: 2009
  • Forum Member
« Reply #941 on: June 14, 2006, 06:09:30 PM »
Great job billm!!
It's sad to think Mazda is monitoring this board & won't even issue a fix that would cost them very few bucks I would imagine with their purchasing power!
Go jump in a volcano Mazda!
Logged
everfeb
  • Le Mans: GT Class
  • Date Registered:January 10, 2004, 05:36:42 PM
  • Site Posts: 637
  • Car Year: 2004
  • Car Model: 2004 Sport GT (hatch) 4 spd ATX
« Reply #942 on: June 14, 2006, 11:17:07 PM »
Great job billm.  Imagine you have done this mod 5-6 times and gotten pretty good at it.
Could you guess how long it would take you start to finish to do the job and how much $$$ for parts.  If Mazda does monitor this forum maybe they can figure something out from your work.
Very many Mazda 3's in your central Texas area?  If so you could probably start up a very profitable part time business providing Mazda 3 owners with A/C that works.  Or you could start up a franchise business for fixing M3 A/C and go international  LOL.
everfeb
Logged
THE3...'04 winning blue sport (hatch) 2.3 gt w/ 4 spd auto tranny, air, moonroof.  Build date Oct.03/purchased Dec. 11/03 in Manitoba, Canada.  No mods.
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #943 on: June 14, 2006, 11:23:39 PM »
Tnaks everfeb. the Parts <$60 US. Time to install depends on the switch used, and how you tap the power, but I'd say 1Hr or so.
Lot's of 3's here  :) :).
Not interested in a business, but I might build up a couple extra modules.
Logged
El Cheapo
  • Grand Am Series
  • Site Posts: 518
« Reply #944 on: June 14, 2006, 11:26:10 PM »
I think Bilm can make some easy tax free cash if he drops by to any of the Mazda meets inNorth America.  Or if he decides to claim his cash, he can also claim his expenses too.  I think the local Mazda groups/forums should invite him or he can "train" others for a fee and they can turn around and make some easy money, provided they know what they are doing.
Logged
ak47clown
  • Date Registered:April 25, 2005, 11:13:35 PM
  • Site Posts: 1534
« Reply #945 on: June 14, 2006, 11:42:41 PM »
I'm wondering instead of a timer module you could use a temperture sensor/switch instead.  I would assume it would have to be tapped into the thermistor and use that as your saftey cutoff at around 33-34.  I've gotta look into it but in theory it seems like it should work?
Logged
'05  sunlight silver metallic 3s: leather, abs, sports package, moonroof, 6cd changer.
Eclipse CD8445 HU w/ full steering wheel control, sirius, infinity reference 311a amp w/ perfect 12.1d sub, ported box, rainbow slc 265 components, diamond d3 amp, custom amp rack, superbright white led map and dome lights, sharkfin antenna, aftermarket heated seats, Ark Shortshifter
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #946 on: June 15, 2006, 07:43:53 AM »
yes, you could just use the thermistor itself as the sensor. I've got another design in the works that does just that, but it is more complex. The timer does a very good job of initial cool-down. Onec it is cool the stock system seems to be able to keep it cool on my car.
Logged
weenieboy
  • Go-Kart Driver
  • Date Registered:October 20, 2005, 04:42:20 PM
  • Site Posts: 99
  • Forum Member
« Reply #947 on: June 15, 2006, 01:30:24 PM »
Bill, you've got to be a genius!
Logged
newpz
  • Bicycle Rider
  • Site Posts: 8
« Reply #948 on: June 15, 2006, 06:51:26 PM »
Billm -
Quick question - I would like to install this mod, but I am by no means an electrical engineer (you should see my soldering... ugh).  I definately am not up to the task of constructing a proper timer.  Would the module at http://www.hobbyengineering.com/H1991.html do the trick?
Also, I see that you've used your timer relay to control the LED on the switch as well.... Do you have two separate relays in that timer (one for the resistor, one for the LED?)
Thanks, and sorry for the noob questions.
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #949 on: June 15, 2006, 07:22:21 PM »
Billm -
No prob.
It might/should work OK, but if you are interested in a timer, PM me instead. :wink:
As far as the LED, I use a different trick to turn it on without a second relay using transistors instead. That keeps the power and cost down.
« Last Edit: June 15, 2006, 07:29:24 PM by billm »
Logged
ak47clown
  • Site Posts: 1534
« Reply #950 on: June 15, 2006, 07:55:30 PM »
I have the pleasure of working with an electrical engineer and i showed him this today.  We're gonna look at the unit at some point but he's thinking of using a variable resister inline with the termistor...
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #951 on: June 15, 2006, 08:19:47 PM »
That will have the opposite effect, and you won't like the results.
show him this:
it is the curve for the thermistor.
« Last Edit: June 15, 2006, 10:31:25 PM by billm »
Logged
ak47clown
  • Site Posts: 1534
« Reply #952 on: June 15, 2006, 10:02:03 PM »
well from the graph it looks like the higher the resistance the lower the temperture if i'm looking at it right? So how would a variable resister not work?
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #953 on: June 15, 2006, 10:09:24 PM »
Oh, it would work if you hook it up right.
Logged
newpz
  • Bicycle Rider
  • Site Posts: 8
« Reply #954 on: June 16, 2006, 09:13:57 AM »
I think what billm means is that you want to be parallell with the thermistor, not inline.
« Last Edit: June 16, 2006, 09:15:19 AM by newpz »
Logged
RB
  • FMVmoderator
  • F1 Driver
  • Date Registered:August 20, 2005, 08:54:45 PM
  • Site Posts: 14472
  • Transaction Count: (1)
  • Car Make: Mazda
  • Car Year: 2006
« Reply #955 on: June 16, 2006, 09:47:17 AM »
Excellent walkthrough!    :goodjob:
Logged
^ lol having trouble getting that up!?  :lol:
ak47clown
  • Site Posts: 1534
« Reply #956 on: June 16, 2006, 01:51:22 PM »
parallel schmarallel.  lol-
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #957 on: June 16, 2006, 09:02:02 PM »
yes, that's what I meant, I guess I could have been clearer  :?
Logged
nifty6
  • Le Mans: GT Class
  • Date Registered:March 06, 2005, 08:49:17 PM
  • Site Posts: 634
« Reply #958 on: June 17, 2006, 08:22:23 AM »
Wondering if I printed out the A/C mod and took it to the dealer if they could do it for me? But I think I know what they would say.  Anyone willing to send it to Mazda to see what they would say?
Logged
billm
  • Le Mans: GT Class
  • Site Posts: 683
  • Forum Member
« Reply #959 on: June 17, 2006, 02:35:10 PM »
nope
« Last Edit: July 07, 2006, 09:22:26 PM by billm »
Logged
Pages: 1 ... 30 31 [32] 33 34 ... 51   Go Up
« previous next »
