Author Topic: Installing Cruise on non-equiped model.. Info/pics/procedure here (56K Death).  (Read 37195 times)
spocket
  • Bicycle Rider
  • Site Posts: 8
  • Transaction Count: (0)
  • Date Registered: May 03, 2006, 08:30:57 PM
  • Forum Member
Introduction
My biggest regret after taking delivery of my 2006 Mazda 3 Sport GS (Canada) was the lack of cruise control. I simply could not afford the 1500$ premium for the GT model. I originally thought I could later add an aftermarket cruise control until I realized the Mazda 3 featured a "Throttle-by-wire" system. Therefore the 'cruise control' is mostly operated by software (ECU).
I am not aware of any aftermarket system readily available for 'throttle-by-wire' applications, although in theory it would be very simple: the aftermarket module would simply need to monitor few sensors and then intercept and modify the signal going from the throttle pedal position sensor to the ECU when in 'cruise' condition. No mechanical parts would be required.
My Mazda dealer told me it was not possible to add the factory cruise control on a non-equipped model. However, upon additional research, I found few guys on http://www.mazda3quebec.com/ that had their local dealership successfully add the factory cruise control. According to those reports, the software and cables are all in place already. The only things required are:
  • The module with the cruise control buttons on the steering wheel (comes attached to the module with the radio buttons on the same wires/connector);
  • A "cruise control" compatible brake 'stoplight switch'.
Those users had the system installed at the dealership for around $300-$350. Parts alone can be found new at discounted price online for about $125 and the installation seems quite easy. I went one step further and actually found a complete used steering wheel with cruise controls for $35+$10 shipping. At that price, it was worth the try! Total investment for me, including the new stoplight switch: about $50.
I can now confirm that the information was accurate: I successfully added the factory cruise on my 2006 Hatchback (Canadian Model). The installation was really quick and easy. Find all the information required and installation procedure below.
Confirmed success (compatibility):
  • 2006    Mazda 3 Sport Hatchback GS (Canadian Model) <- MINE
  • 04-05    Mazda 3 Sedan and Hatchback (Canadian Models) <- www.mazda3quebec.com
       (PM me if you have additional compatibility reports for me)
Disclaimer
I do not have the credentials to offer automotive advice.  The modification procedure that follows explains how I chose to approach a modification I wanted to make to my personal car.  I am not suggesting that anyone else make this modification to his or her vehicle.  In the event anyone chooses to accept the responsibility of initiating a similar vehicle modification, they should do so with the understanding it could result in undesired damage to their vehicle and could void the warrantee provided by the vehicle manufacturer.  In addition, I wish to point out that undertaking any vehicle modification without proper knowledge, experience, tools, and safety equipment can result in personal injury and/or death.  This is especially true here, where the Airbag module on the driver side has to be temporarily removed in order to install some of the parts. I highly recommend that you have a dealership or competent garage install the parts.
Also, I don’t claim to be the originator of this modification. The following is a summary of the information required to perform the modification. The idea is to have the convenience of having all the required information located in one place. The original information was found on http://www.mazda3quebec.com/ and http://www.mazda3forums.com/ .  This procedure is a combination of those indications, helpful hints and pictures resulting from my own personal experience. Special thanks to 'charlano' on http://www.mazda3quebec.com/ for answering all my questions...
Parts Required:
  • BN7N-66-490 Brake switch for vehicles with cruise ~$6
  • BN8P-66-4M0 Steering switches for vehicles with cruise ~$119
Where to buy the parts:
- used: http://www.car-part.com ($40 to $100?, mostly interesting for the cruise steering switches)
- New:
Tools Required:
  • Small flat hear screwdriver
  • Phillips screwdriver
  • 10mm socket (battery, airbag)
  • 13/16" socket to remove the steering wheel
Time Required:
  • 20-30 minutes
Procedure
1.   Orient the steering wheel so that the wheels of the vehicle are positioned to move in straight line.
2.   Disconnect the negative terminal of the car Battery using a 10mm socket;
3.   Open the headlight switch and pump the brake pedal a few times to help drain any power left in the circuit.
4.   Wait enough to make sure that any capacitive load in the electrical circuit had some time to be drained out before removing the airbag (2-3 hours? maybe not necessary, but why take a chance??)  Use that time to swap the brake switch:
5.   Brake Switch Replacement
     a.   Locate the switch right above the brake pedal as shown.
     b.   Disconnect the electrical connector by pressing on the release tab;
     c.   To remove the switch, twist it like an 1/8 of a turn as shown, then pull it out;
     d.   Apply reverse procedure to install the new switch.
6.   Airbag Removal (Please read disclaimer above!!! Again, I higly recomment you have a dealership or a competent garage do the part of the install involving the airbag. Improper handling or a static discharge could set it off resulting in expensive damage, injury or even death. I do not pretend that the procedure explained here is adequate or complete to remove & re-install the airbag.):
     a.   Remove the 2 rubber plugs on each side of the steering wheel body, as shown below;
     b.   Using a 10mm socket, remove the 2 bolts holding the airbag in place;
     c.   Pull the airbag assembly out carefully;
     d.   Disconnect the electrical connectors of the airbag assembly: there are 2 connectors to disconnect. Pull the black locking tab using a small flathead screwdriver then pull the connector as shown;
     e.   Safely store away (face up) the airbag until you ready for re-assembly.
7.   Steering Wheel Removal
     a.   Disconnect the wires of the steering switches;
     b.   Using a 13/16" socket, remove the bolt clamping the steering wheel;
     c.   Once the bolt removed, the steering wheel should pull out easily (I did not need a puller).
8.   To replace the switch panels, you need to remove the back cover of the steering wheel. 2 screws must be removed from the back, then release the 2 tabs from the front side.
9.   Remove the old switch panels on either sides of the steering wheel and replace them with the new switch modules. They are held by a screw from the back side of the steering wheel. Pay attention to how the wires are routed and use the same approach for the new switches.
10.   Carefully re-assemble everything using reverse procedure, re-connect the battery and go for a test drive to verify that everything is working properly.
Enjoy!
« Last Edit: May 03, 2006, 11:33:57 PM by spocket »
BCZoomZoom
  • Former Staff
  • Le Mans: Prototype Class
  • Site Posts: 1256
  • Date Registered: August 11, 2005, 12:09:22 PM
    • My install (so far)
  • Car Model: GT Sedan MTX - Carbon Grey
  • Car Year: 2005
Cool... great research, and walkthrough... Not a bad little mod for those who didn't get cruise...
Did you also end up getting steering wheel controls for your stereo out of it?
Eclipse 8455 HU, CDT ES620 speakers, Xtant amps, Image Dynamics IDQ sub, Big3+TB Ground, K&N Filter, Black Calipers, Low Horn
Planned: Sways, s-shifter, 1.21 gigawatt flux capacitor
Power corrupts.
Absolute power corrupts absolutely.
But it rocks absolutely too.
bossboy
  • Computer Jock
  • F1 Driver
  • Site Posts: 4133
  • Transaction Count: (29)
  • Date Registered: October 25, 2005, 03:27:26 PM
  • Suck Whoosh!
  • Car Make: Ford
  • Car Year: 2009
NICE!  vote sticky somewhere!
Öperator
  • Philsoma
  • Administrator
  • F1 Driver
  • Site Posts: 11282
  • Transaction Count: (25)
  • Date Registered: September 15, 2004, 12:00:00 AM
  • Lawn Dart Instructor
  • Car Make: VW/Audi/Porsche
  • Car Model: A4
  • Car Year: 2007
Very nice job.  Awesome walk-through!!!! And most important you saved some loot!!!!!
small town king
  • My Car caught on fire. Buy my shit?
  • F1 Driver
  • Site Posts: 10607
  • Transaction Count: (14)
  • Date Registered: October 24, 2005, 01:53:14 AM
  • My Mazda is Fire!....Literally.
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2006
good thourough write up.
i have cruise control tho. =)
i had a friend who was doing this in his pickup, and he had a static charge or something and it set off his airbag :shock:
ended up being like 600 dollars to get another one installed
Went from a brand new 06 Silver Hatch to a Crispy 06 Hatch to a White 06 tC
I miss her :wtc:
spocket
  • Bicycle Rider
  • Site Posts: 8
  • Forum Member
- You have to replace both the radio and cruise control modules at the same time since both sides (modules) are actually one part number (the 2 modules are linked by the wires, going to one common connector as seen in parts picture).
- Thanks for the reminder; edited extra warnings regarding the airbag handling. Please do not attempt unless you are ready to deal with the consequences. Have a competent garage or the dealership deal with this part of the install.
- If you get the cruise buttons from a junkyard, make sure you have the complete wire harness with the connector (make sure they did not simply cut the wires, as I have seen in the past). You don't want to have to splice in wires there...
« Last Edit: May 03, 2006, 11:41:06 PM by spocket »
pingu324
  • Moped Rider
  • Site Posts: 47
  • Transaction Count: (1)
  • Date Registered: September 04, 2005, 01:20:32 AM
  • Forum Member
How is it that you use Cruise control when You drive a manual?? Or so the one pictures would lead me to believe. I always thought you could only have cruise with a fully automatic transmission, or steptronic setup, but it appears as though you have the base standard transmission?? I'm confused is all...
automaticman
  • Senior Member
  • Site Posts: 1996
  • Date Registered: July 13, 2005, 02:02:38 PM
  • Forum Member
Cruise control on a stickshift is no problem.  You just get on the freeway, shift up to 5th gear and turn the cruise on.  Stepping on the clutch or placing the gearshift in neutral will cancel cruise the same as stepping on the brake would.  I use mine all the time.  My last car was a '93 Ford Ranger and even it had cruise control with a stickshift.
BCZoomZoom
  • Former Staff
  • Site Posts: 1256
  • Car Year: 2005
So that's what I was doing wrong... I was sitting at a stop light in neutral yesterday and hit resume... it didn't even shift into 1st.
Just kidding anyways.. yeah, once you're cruising at freeway speeds, you're pretty much exclusively in 5th gear anyways, with the exception of passing... then when you put the clutch in to downshift for the pass... it cancels the cruise.  Finish passing... get back in to fifth... resume.
Power corrupts.
pingu324
  • Moped Rider
  • Site Posts: 47
  • Forum Member
Oh, cool. thanks for the info, I had no idea, makes perfect sense.  Obviously I knew the car wasn't going to shift for you. As dumb as I may have sounded, I knew that much. Just trying to save my dignity :)
icspots
  • Fighting natural selection one moron at a time.
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Transaction Count: (3)
  • Date Registered: August 10, 2005, 01:14:55 PM
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
Great job, and excellent CYA disclaimers. ;)  Me thinks more people will be getting cruise control now.
                  Audio Input Thread || Key/Flip Key Thread
italiancutie136
  • Site Posts: 1070
  • Date Registered: March 04, 2006, 01:05:40 PM
  • Hail to Daft
awesome write up!  I've been wanting to add cruise control on my base model since I bought the car.  Where did you go to find all the parts?
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
He listed that in the first post under "Where to buy the parts:". ;)
italiancutie136
  • Site Posts: 1070
  • Hail to Daft
ah.. guess i looked over it the first time through
Kodiac 3
  • Contributor
  • F1 Driver
  • Site Posts: 14875
  • Transaction Count: (7)
  • Date Registered: January 07, 2006, 08:20:57 PM
  • Sedan Syndicate: The Screwball
  • Car Make: Mazda
  • Car Model: s-trim; Velocity Red
  • Car Year: 2004
the airbag is the scary part.........
Will the dealership do this kind of work???
spocket
  • Bicycle Rider
  • Site Posts: 8
  • Forum Member
I've heard several guys say they had the cruise control installed by their dealership, in the Quebec province (Canada). They paid 300-350$ CDN for parts AND labor.
The airbag removal sounds worst than it is.. There is not much to it. I just put extra warnings so that you are aware of the possible consequences... Still, I was not big in my shoes when I did it the 1st time.
Kodiac 3
  • Contributor
  • F1 Driver
  • Site Posts: 14875
  • Car Make: Mazda
  • Car Year: 2004
Just don't work in front of it........
cyberboi
  • Moped Rider
  • Site Posts: 42
  • Date Registered: October 20, 2005, 10:35:16 PM
  • Forum Member
GREAT GREAT walkthru...
I will jump on it if it doesn't require to remove the airbag and messing around with it...
Falcon50Driver
  • Moped Rider
  • Site Posts: 46
  • Date Registered: June 04, 2006, 03:49:38 AM
  • Forum Member
Great job spocket!!
I just want to confirm - how does the controls you installed on the steering wheel interact with the accelerator of the car. Is this functionality already in all Mazda3 models?
M3Bus
  • Short Track Racer
  • Site Posts: 234
  • Date Registered: May 30, 2006, 03:03:58 PM
  • Forum Member
I just installed cruise on my non cruise 3i. I however did not remove the air bag i just moved it to the side and removed the 2 screws in the back of the steering wheel then the two screws holding on the radio and cruise switches. Now i must go to the mazda parts shop to pick up the break switch and hopefully everything will work. Everything lights up and when you press the cruise on it lights up cruise main but it won't hold the speed so i'm thinking the break switch has something to do with that.
[size=20]······[/size]
Falcon50Driver
  • Moped Rider
  • Site Posts: 46
  • Forum Member
Hi M3Bus
I'm considering doing this install as well. However I have a Euro model Mazda3.
Is it possible for you to check whether you have a direct cable connection between your gas pedal and the engine.
My car definately has this cable, so I'm not sure if just installing the steering wheel controls and brake switch will actually work  :(
Thanks
M3Bus
  • Short Track Racer
  • Site Posts: 234
  • Forum Member
I installed the break switch lastnight and everything works perfectly. I also talked to the service tech falcon and he said all mazda 3 cars were capable of having cruise you just need to buy the control and break switch. Overall i paid $45 for the controls $15 for shipping from a junkyard and $8 for the break switch so about $68. Great walk-through by the way!!
KoRn
  • Le Mans: GT Class
  • Site Posts: 837
  • Date Registered: February 20, 2005, 11:22:30 PM
I just ran across this thread and man im jumpin like a kid in a candy store. I wanted cruise control so bad when, I bought this car. Just couldnt afford options at the time. Im doing this asap. Awesome write up.
Mazda 3i 05 Velocity Red Mods: Borla cat back exhaust, SilverStars low&high beam bulbs, Removed side moldings, Red calipers with Mazda 3 logos, 17x7 Exel P-5 gunmetal wheels, 205-50 17 Hankook Ventus Sport K104 tires, Eibach pro kit, Stubby antenna, Satin fuel door, Graphite grey metallic badges, S model taillights
MZ3FRS
  • Le Mans: GT Class
  • Site Posts: 893
  • Transaction Count: (4)
  • Date Registered: July 01, 2006, 09:21:44 PM
  • Car Model: Base 3i
  • Car Year: 2006
This is beautiful! I really may have to try this, tho messing with the airbag makes me slightly nervous.  Great instructions!
How about a sticky?
Silver '06 3i Sedan | MTX | Fixpoint Roof Rack | Pedal Covers | Rear Motor Mount Inserts | Simota CAI |Progress Rear Sway Bar
pirpank
  • Bicycle Rider
  • Site Posts: 1
  • Date Registered: August 19, 2006, 02:53:03 AM
  • Forum Member
Hi M3Bus
Thanks
Did you try this mod yet.
I also have a European model and I don't know if changing this parts will have any efect on may car.
I went to a local dealership, trying to get the price for this parts and they said that no such parts exists, and that crouze control in mazda 3 does not exists.
I gues I am a little confused now.
Need to do a little more research first.
Falcon50Driver
  • Moped Rider
  • Site Posts: 46
  • Forum Member
Quote
Hello Pirpank
Did a bit of searching and this is what I came up with:
My model (South Africa) does not have "drive by wire". This means that the accelerator is not controlled electronically but by a physical cable connected between the gas pedal and the engine.
Therefore the above modification is NOT possible. Just adding the controls to the steering wheel and adding a brake switch will not work as the controls on the wheel will not be able to access the accelerator.
This is a big difference between my model and all US models.
Apparently the new 2.3l model being released here as well as in Australia will have the "drive by wire" system.
This is a big bummer, but oh well...  :?
Hope it clears things up a bit.
ATC@LWSK
  • If you see this man drinking, don't fly tomorrow!
  • Moped Rider
  • Site Posts: 34
  • Date Registered: April 18, 2006, 04:56:02 AM
  • Macedonian
So,
there's no way that we can install cruise control on our european 3's, right?
If someone figures it out, let us know.
cheers,
J.
NZCam
  • Bicycle Rider
  • Site Posts: 8
  • Date Registered: March 14, 2006, 05:59:47 AM
  • Rider, Driver, Navigator.
  • Car Model: 6-speed SP23
  • Car Year: 2007
Can anyone who's done this tell me what sort of illumination (T5 Globe, like the A/C controls? Surface-mount LED as per head-unit/cluster?) is used for the cruise and audio controls mounted on the steering wheel?
Cheers - Cam
reeeky2001
  • Short Track Racer
  • Site Posts: 246
  • Date Registered: September 15, 2006, 11:14:22 PM
    • My website in the slow works...
  • Car Model: MZD 3i
  • Car Year: 2006
Re: Installing Cruise on non-equiped model.. Info/pics/procedure here (56K Death
« Reply #28 on: September 15, 2006, 11:36:50 PM »
Quote
Hello Pirpank
No, you've got it all wrong. You have the best version for cruise ever! It's not too hard to install cruise on your Euro 3s.
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=341067&langId=-1
That's what I've used on other vehicles that have a throttle cable. You may have to do a ball-type chain mod to get it to work right. You may also want to get one of those wireless kits that work w/ these Audiovox CC kits (http://www.etaag.com/subcat36.htm).
Those two things are what I've used on over 47 vehicle cc installs. But I've only used a few of the RF Wireless controls, and I don't remember how to hook them up, but they weren't hard.
BTW, OP thanks for the Write-Up/Tutorial! I've been looking for this since I bought my 3, but couldn't find any thing. Looks like I was in the wrong place the entire time, huh?
"Sir, three years ago before I joined the army, I never thought I'd say 'That damn marijuana'."
Pending installation: eD 12HD w/ Crossfire CFA-300M, GB Faux Leather Seats.
Falcon50Driver
  • Moped Rider
  • Site Posts: 46
  • Forum Member
« Reply #29 on: September 16, 2006, 03:55:34 AM »
Quote
I hardly think installing a kit into the engine compartment and a switch somewhere in the dash is easier than just adding the factory steering wheel control.  :shock:
I agree that it is possible to mod a euro 3 to have cruise control, but the thread so far was talking about adding two mazda factory components, not modding the cruise with an after market kit.
If drivers are willing do carry out this kit, then yes, it is possible.
