ok guys, I didn't really have time to take pics during the modification, cuz the idea came up rather random, and I just went out and bought the needed parts. But I'll try to explain how I did it as clear as possible, if it doesn't make any sense, maybe in the future when I have more time, I'll take things apart again (and photograph the steps) to show you guys how it was done.
Parts:
1. 4 red LED light strips (go to eBay and type LED light strips, you should see what I'm talking about)
Time:
Apprx. 1 ~ 2 hours, depending on how stubborn the LED light strip is (I'll explain what this means later)
That's it, that's all you need to start this little project!
Step 1: Take out your light housings (you can leave the middle two in place, but the outside two housings must come out to gain access)
Step 2: Try to stuff the LED strips inside the housing, this is the hardest part. It all depends on your luck, for example, first 2 took me about 1 hour to do, but the last 2, I kind of got the hang of it, and took me like 10 minutes.
Step 3: Once the LED strips are in the housing, use a small pen or screwdriver to get it tight against the sides. Some of you might ask "hell, if it's in there, it's going to get out of place", I thought of the same thing at first, but since the LED strips are rubber material, it will stick and stay in place. Trust me, I've had them in there for about a month now, with the crappy roads out here where I live, they haven't moved a bit.
Step 4: If you can get the LED strips in there, you've done the hardest part. The rest is easy, just splice in LED's wires to the parking lamps, that's it!
Hope this little short write up is clear. If you have questions feel free to PM me.
