Author Topic: BSD how-to by me :D  (Read 15594 times)
hate_romania
  • Le Mans: Prototype Class
  • Site Posts: 1727
  • Transaction Count: (0)
  • Date Registered: April 15, 2005, 03:34:02 AM
  • Montreal the Pothole CAPITAL of the world...arhhhh
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
BSD how-to by me :D
« on: April 09, 2006, 10:32:38 PM »
Balance Shaft Removal Kit Install
Required Tools        Required Materials:6 Quarts Oil  (I suggest Amsoil or Motul)
3000+lb. Floor Jack or Ramps        Motorcraft FL-910 Oil Filter
(2) Drain Pans        Purolator PL15505 Oil Filter
Oil Filter Wrench        Permatex Ultra-Grey Silicone Gasket Maker or Victor razin
Gasket Scraper
Ratchet(s)
6" Extension
8mm Socket (Deep)
10mm Socket
13mm Socket
15mm Socket
18mm Socket
21mm Socket
Bear, good friends and time :D
A small word before starting
If you are the average guy how knows about the engine a bit but never worked on a engine forget it its freaking complicated, if will do the mod I will worn you now if you will do it in the garage while lying on the back its going to be difficult and you will taste some oil, dirt will fell in your eyes and your hair you contain oil … me I think I was lucky and I was crazy when I made the decision
I find bsd very very very very complicated and not for the week of heart
Ok lets start
If you want to fell the difference between the before and the after BSD i recommend you NOT to reset the ECU.
1.  I used one of those to jack up my car so i can work underneath it
2.Remove splash shield 6x12mm screws– No need for pictures and explanation here
3.Drain oil 1x17mm screw – place drain pain under the oil pan and remove the drain plug to drain the engine oil.  Let drain completely.  Replace plug and tighten.  Remove drain pan from work area. A small advice if you have run the car before the install let the engine cool down or you will get burn from the hot oil.
4.Unbolt A/C Protector and A/C Compressor and rest it on a jack, or leave it hanging. 3 nuts 12mm for the metal plate that protects the compressor and 4 very long bolts 12mm for the ac compressor
5.Unbolt and remove oil pan. I have attached a schematic of the oil pan and the bolts disconnect the bolts in REVERS ORDER from 13 to 1. All the screws that go vertically are 10mm the 3 screws that go horizontally into the tranny are 17mm, and the 4 screws that are on the passenger and go horizontally are 8mm screws
Now after removing the screws right next to the oil filter there was a small gap put a flathead screw driver and pry the oil pan off
6.With the oil pan removed, remove the 2 long screws that hold the oil pickup, the black tube and remove the oil pickup. Put the pickup aside in and keep it clean
7.Remove 4x10mm bolts that hold the balance shaft assembly from the block.  Use caution as the balance shaft assembly is heavy (18lbs, 8.1 kg) if you do the operation on the back trust me that thing is freaking heavy. Set the assembly aside. A lot oil will spill when you take out the shaft from the hole that the kit will go on. If you place the bsd right under the car you will see that one of the legs (lack of a better word) that where attaching the balance shaft on the block a small secondary hole that was the oil feed for the balance shaft now look on the block you will see the extra hole right in front of the oil filter.
8.Place Cosworth Balance Shaft delete plate with O-ringed bung into the oil supply port used by the balance shaft assembly.
Before the cosworth
After the cosworth
9.Use a small amount of Red Loctite on the attachment bolt and secure the plate to the block.  The bolt should be torqued to 20ft/lbs.
10.Reinstall the oil pick-up tube and torque 8-10ft/lbs. WARrniNG I scraped a screw here don’t use more power then brain the screw will broke. I had a nice neighbor that made me a custom screw.
11.Use the Gasket Scraper (a razor blade will do in a pinch) to remove any old sealant from the block and oil pan mating surfaces. A trick that my father teach me (after giving me the shit for opening the engine :D) put some gasoline on the old sealant it works perfectly the old sealant just peeled off by its self.  Use a clean rag to remove any oil from the mating surfaces on the oil pan.
12.Sparingly apply Ultra-Grey Silicone to the oil pan sealing surfaces.  The best method is to smear the silicone across the surface evenly with your finger.  DO NOT USE EXCESSIVE AMOUNT OF SILICONE!  Excess will simply squeeze out when the pan is tightened and make a mess!  Excess inside the oil pan can get loose and clog the pickup or get caught in moving parts.
The underlined text is a copy from marcymotorsports install I call it bs
From the service manual fallow the line of the oil pan and put the silicon gasket the silicon line has to be min 2.2mm and max 3.5mm don’t use the finger to spread the silicon just by tightening the oil pan the silicon will spread out.
BEFORE APLYNG THE GASKET DO A TEST FIT FOR THE INSTALL OF THE OIL PAN IN MY CASE I REMOVED THE GUN PIECE THAT ATACHES THE TRANNY TO THE REAR ENGINE MOUNT 3X19MM SCREW cause was in the way. IF EVERIGHING OK TRY AGAIN once the silicon is on the oil pan you have to be fast and there is no second try you miss you have to redo the gasket.
13.Reinstall oil pan.  Tighten bolts in the following order at 12-16ft/lbs
14.Place a drain pan under the oil filter.  Remove the old filter and install the new one.
15.Pour 3 quarts of oil into the engine.  Check for leaks.  Add 2 additional quarts if there are no leaks.
16.Reinstall A/C Compressor and protector at 13-19ft/lbs.
17.Reinstall splash shield 6x12mm.
18.Go take a shower, whatever just let the car and silicon dry for a least 1 h
19.Start the engine but don’t rev-it  let it warm completely and the stop the engine
20.check for oil leaks under the car….none then go zoom zoom
Hope this helps, special thnx to Philidonis, Brian aka MrTea, Flo a friend of mine, theBeansolider, Goldfish and to my father who even if he was very pissed off on me cause I opened the engine he helped me Thank you.
« Last Edit: April 10, 2006, 07:47:09 AM by hate_romania »
Driving a 2010 mazda 3 gt with sunroof bone stock
SOLD: Mazda3 2005 Black mica 5dr, CAI AEM with AEM dryflow, Custom grounding cables, TWM SS, ETB Coolant Bypass, AWR 70d engine mount, Advance Timming Mod,
Cosworth Bsd, The only mazda 3 with dealer removed speed limit yey...230km/h
MrTea
  • Former Staff
  • Site Posts: 2253
  • Transaction Count: (1)
  • Date Registered: August 17, 2004, 03:23:41 AM
  • Car Make: Mazda
  • Car Model: Mazda6i
  • Car Year: 2003
Re: BSD how-to by me :D
« Reply #1 on: April 09, 2006, 11:23:23 PM »
glad you got it all done man!  i was a bit worried since i missed a call from you after i got to work, but looks like it ended up ok.
'03 Mazda6i ....bunch o' mods
goldfish
  • Le Mans: GT Class
  • Site Posts: 560
  • Date Registered: August 29, 2005, 05:35:09 PM
  • Forum Member
« Reply #2 on: April 10, 2006, 02:20:42 AM »
Righton, grats on the install.
WetsuitxNinja
  • F1 Driver
  • Site Posts: 2897
  • Transaction Count: (3)
  • Date Registered: December 02, 2005, 08:23:02 PM
  • Forum Member
  • Car Model: Mazda3 Hatch
  • Car Year: 2006
« Reply #3 on: April 10, 2006, 02:32:16 AM »
Props for the how to.  Does not look horribly hard but being on your back trying to work on it would be a bitch.  Good work  :D
MrTea
  • Former Staff
  • Site Posts: 2253
  • Car Make: Mazda
  • Car Year: 2003
« Reply #4 on: April 10, 2006, 03:26:38 AM »
..that damn thing weighs soo much when you are laying down there by yourself without anyone to help hold it!!!
seemed to find that the spin-on conversion (at least on the 6) was less obtrusive that the cartridge system when removing the oil pan as well.  also, any input on removing the pan in regards to the rear mount, or was that not an issue after all?  and i'd also recommend removing the 2 8mm bolts that hold the dip stick tube onto the intake manifold to get that out of the way, only issue is it's bitch to get the bottom one back on sometimes.
thebeansoldier
  • 203whp / 136wtq
  • Former Staff
  • F1 Driver
  • Site Posts: 6415
  • Transaction Count: (18)
  • Date Registered: July 14, 2004, 12:29:25 AM
  • Car Model: Honda S2000
  • Car Year: 2002
« Reply #5 on: April 10, 2006, 05:41:31 AM »
Great job on the pics and write up, Alex :goodjob:
:thinking: What the heck did I do?
K&N Drop-In | Spoon X Brace | HKS Hi-Power | Rays VR TE37 + Lugs | RE01-R | Pioneer P6900UB + Polk Audio DB651x2
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #6 on: April 10, 2006, 07:43:34 AM »
removing the filter from the block helps alot, but the main prob that i had was the gun piece that ataches the trany to the engine mount, cause of it i wasn't able to install the oil pan from one shot. If you have to remove that one put a juck under the tranny and preare yourself i have never ever seen screws tight so hard.
o yea forgot to tell about the dipstick...on the 3 is only 1x8mm screw not 2 very easy accesible from under the car
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #7 on: April 10, 2006, 07:49:31 AM »
thx
you hellped me by providing a basic how to that give me a ideea what i have to do then i added my opinoins about the install, my picts and here is it, thx
Egz
  • Grand Am Series
  • Site Posts: 179
  • Date Registered: August 31, 2004, 10:43:31 PM
    • Car Domain page
  • Car Make: Ford
  • Car Model: Ford Fusion 2.3l SE Turbo
  • Car Year: 2006
« Reply #8 on: April 10, 2006, 12:30:54 PM »
Little tip on the oil pickup tube.
Remove one bolt, and loosen the other so it pivots out of the way.  That way, you can't forget to reinstall it.  If you remove it, make sure it goes back.  I know of one engine where the owner forgot to reinstall the pickup tube.  Needless to say, the engine wasn't happy.
2003 Ford Focus ZX3 2.3l N/A = 206HP, 150ft-lbs; 13.96@100.88
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
Man12345
  • Short Track Racer
  • Site Posts: 134
  • Date Registered: July 30, 2005, 09:09:05 PM
  • Forum Member
« Reply #9 on: April 10, 2006, 02:10:49 PM »
how exactly does this mod work/help
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #10 on: April 10, 2006, 02:40:37 PM »
it removes weights that was comsuming engine power it dosn't necesarly adds power it just frees the engine so it can rev faster
the engine res faster and drops rpm faster then normaly
tehnicly should be giving better fuel economy cause there is no parasitic loss of the engine power
my car for what ever reason its slower now then philidonis car before i was beting him by like a halp of a car now he beats me, i will reset my ecu to see what happens
Phildonis
  • Site Posts: 1030
  • Date Registered: October 03, 2005, 02:42:11 PM
  • Black Belt in Natural Aspiration.... ITB's FTW!
  • Car Model: Mz3s 4dr going back to stock AE86 drift/road racer
  • Car Year: 2005
« Reply #11 on: April 10, 2006, 04:44:27 PM »
That's just because you shift like a girl.  :lol:
Glad to have helped man, btw your writeup is amazing.
1985 AE86 20V - Cusco engine/tranny mounts, 6-point cage, front triangle bar, coilovers, Oil Catch Can - TRD F&R Sways, 4-1 Header, 2way LSD, Short Shift Kit - T3 Rear 4-Links, Panhard bar, Front Control Arms, Roll Center Adjusters, Tension
Control Rods, Gold 48mm Velocity Stacks, Rad Shroud -Razo Knob - Momo Wheel -Bride Tsuchiya Seats - Defi Guages - Apexi AFC Neo - 14x7 RS Wantanabes - RE01R
dmention7
  • Senior Member
  • F1 Driver
  • Site Posts: 6512
  • Transaction Count: (10)
  • Date Registered: August 27, 2005, 10:46:59 AM
  • Car Model: Laser Blue MSP
  • Car Year: 2003
« Reply #12 on: April 10, 2006, 04:55:11 PM »
nice writeup, hate_romania!  How does the engine feel since you did the mod?  I just ordered one of these a few days ago, and I'm hoping there's a noticable difference in how freely the engine revs.
2003.5 Laser Blue MSP #2543
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #13 on: April 10, 2006, 05:59:40 PM »
yes the enine revs more freely, it make a souns at 2100rpm but no vibration same thing on phil's car, starting the engine nd stopon the engine it feels direct cause there is no more weight that keeps momentum, the engine more alive and don't now fr what reason my car vibrates alot less and i have the awr mount
Phildonis
  • Site Posts: 1030
  • Car Year: 2005
« Reply #14 on: April 10, 2006, 06:07:04 PM »
time to update your sig buddy  8)
thebeansoldier
  • 203whp / 136wtq
  • Former Staff
  • F1 Driver
  • Site Posts: 6415
  • Car Year: 2002
« Reply #15 on: April 10, 2006, 08:26:39 PM »
oh yea, i forgot i made a small write up... glad to know everything's working great.
909
  • 909 Land of trailers and meth labs.
  • Site Posts: 1227
  • Date Registered: November 28, 2005, 09:16:55 PM
  • The avatar police keep givin me tickets!!
    • Sport Compact Industries
« Reply #16 on: April 10, 2006, 08:27:17 PM »
This is the link to our kit install instructions. This might help someone but the install looks alot worse than it actually is.
http://www.sportcompactindustries.com/pubdocs/SCIBSD.pdf
mrgogh
  • Moped Rider
  • Site Posts: 11
  • Date Registered: February 09, 2006, 11:06:17 PM
  • New Guy
« Reply #17 on: April 12, 2006, 12:11:31 AM »
I purchased the kit and the external oil filter kit from 909. It was a very informative install with great pics and info. If used with the above info no one should have any problems. Dealing with Sport Compact Industries was a great experience. I sent the owner an email and he called me to explain any questions I had about the products.
Also with the external oil filter much easier to change. The engine revs great and I do not feel any additional vibes after the install (removal of the balance shaft) kit.
Thanks Again  Sport Compact Industries
05 Velocity Red Hatch
909
  • Site Posts: 1227
« Reply #18 on: April 12, 2006, 03:32:54 AM »
Glad to be of service, thanks so much for the  :goodjob:
Phildonis
  • Site Posts: 1030
  • Car Year: 2005
« Reply #19 on: April 12, 2006, 10:53:53 AM »
i like the write-up 909
dmention7
  • Senior Member
  • F1 Driver
  • Site Posts: 6512
  • Car Year: 2003
« Reply #20 on: April 12, 2006, 11:56:27 AM »
hate_romania, you mentioned in another thread that you and phildonis noticed your engine temps seemed to be elevated after doing this mod... any ideas as to why that might be?  If anything, it would seem to me that having more oil flowing through the engine would help keep things a tick cooler.
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #21 on: April 12, 2006, 06:28:27 PM »
i think the temperature increases cause by doing the bsd you block the oil feed, and by the size of the balance shaft that amount of metal cools the oil pretty good plus it conects to the block so it extend the surface where the oil comes in contact with metal (the block)
WetsuitxNinja
  • F1 Driver
  • Site Posts: 2897
  • Forum Member
  • Car Year: 2006
« Reply #22 on: April 13, 2006, 01:30:17 AM »
"The owner" eh??!  :P
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #23 on: April 25, 2006, 06:22:12 AM »
UPDATE 4000km after the bsd running perferct, noi oil consumation, no vibration, no oil leaks...
dmention7
  • Senior Member
  • F1 Driver
  • Site Posts: 6512
  • Car Year: 2003
« Reply #24 on: April 25, 2006, 09:25:14 AM »
Planning on doing mine the weekend after next... taking monday and friday off, and have a bunch of small mods planned  :)
Puffy
  • Le Mans: GT Class
  • Site Posts: 778
  • Transaction Count: (2)
  • Date Registered: September 01, 2005, 03:17:19 PM
  • You gotta love me =(.
    • Puff Interactive
« Reply #25 on: April 29, 2006, 01:09:52 AM »
I need to get stands... I want to remove every last bit of the stock intake and do this + install my Simota and buddy club condenser =D!
Freddyboi
  • Site Posts: 2434
  • Transaction Count: (16)
  • Date Registered: April 21, 2005, 07:57:35 PM
  • Car Make: Ford
  • Car Model: All options with navi
  • Car Year: 2005
« Reply #26 on: May 08, 2006, 03:46:24 AM »
now i wanna do this.. but im scared.. or its more like.. i know im gonna fark up..
All Stock!
Puffy
  • Le Mans: GT Class
  • Site Posts: 778
    • Puff Interactive
« Reply #27 on: May 08, 2006, 10:12:22 AM »
I know how you feel... I just fixed my bumper all the way from installing halos like... 5 months ago ... lol
hate_romania
  • Site Posts: 1727
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #28 on: May 08, 2006, 01:50:51 PM »
before the bsd i had no mechanical experince whatsoever, i just had guts and i went for it, its intimidating but i can tell you its easy and its a lot of fun, take your time don't rush it helps alot when you have some friends with you that can give you advices, and help.
If you need any help just ask and i will be happy to answer
blam
  • Regional Whoredinator
  • Regional Coordinator
  • F1 Driver
  • Site Posts: 34524
  • Transaction Count: (6)
  • Date Registered: August 14, 2005, 09:46:59 AM
  • You're gonna love my nuts.
    • Photography on the lam
  • Car Make: Mazda
  • Car Model: 2.3L Titanium Gray Hatchback
  • Car Year: 2005
« Reply #29 on: May 08, 2006, 02:00:25 PM »
bigtrucker and I did this the last weekend and its more a pin in the ass then it is difficult. the instructions provided are NOT very good.
we took about 3-4 hours to do it.  mostly because we couldnt get the oil pan off. we didnt have any screw drivers so we had to find some to pry the pan off.
the instructions said nothing about removing the AC compressor. we took a good 30 minutes trying to wrestle thaqt pan off. and then during installation we took another good 20 minutes putting it back on and decided to just remove the engine mout, which by the way made it WAY easier.
if we were to do it again on my car it would take less then 2 hours easy.
CLICK THE SIG FOR CAR SPEC/INFORMATION/PICTURE THREAD
