Author Topic: Advanced Ignition Timing Mod  (Read 86491 times)
Monzsta
  • Drive it like you own it.
  • Grand Am Series
  • Site Posts: 476
  • Transaction Count: (0)
  • Date Registered: July 10, 2005, 08:57:15 PM
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« on: February 02, 2006, 07:40:07 PM »
Well, in my ongoing mission to thwart the ECU, I think I finally pulled one over on the little bugger.  The engine always felt a little lazy to me, and even in the worst conditions, I never heard any spark knock.  After reading the timing put in by the ECU, I determined the engine could benefit from more timing.  There are two ways to do this.
1. Flash programming the ECU to alter the timing map (not an available option yet.)
2. Alter the position of the crank sensor.
I chose option 2, as it's the only way at this point.  I went to examine the sensor, with the idea of modifying or making a new bracket for it to allow some adjustability, when lo and behold, Mazda had already done it for me with a nicely slotted sensor at it's mounting point.
After removing the belly pan and the passenger side splash shield, I turned the tire out to the right to allow a little working room.
The sensor was held in place by two 8mm bolts, one being partially obstructed by the A/C belt.
I then marked the sensor's original position, (wich was 3/4 of the slot down) with a permanent marker, and loosened the bolts.  Looking at the sensor thru the wheel well, I slid it counter clockwise all the way (down toward the ground) and snugged the bolts back up.  BE CAREFUL with these bolts!  They only need to be snug and are very easy to strip.
I then reassembled the splash shields and started it up.  The engine started smoothly, no CEL, and settled into it's usual idle.  After a short trip around the block, I heard a slight spark rattle when I approached 7,000, confirming the timing had indeed been advanced.  After a few more times to the redline, the rattle subsided, indicating the ECM was beginning to finaly utilize the knock sensor and pull a little timing.  The engine feels a little crisper, and hopefully I'll see a few more MPG.
« Last Edit: February 02, 2006, 09:31:09 PM by Monzsta »
08'  Tribute..
BC3I
  • Silver Bullet
  • Le Mans: Prototype Class
  • Site Posts: 1065
  • Date Registered: January 30, 2006, 05:33:21 PM
  • Contributing Member
    • Car Domain
  • Car Model: 3i
  • Car Year: 2004
Re: Advanced Timing Mod
« Reply #1 on: February 02, 2006, 07:45:21 PM »
wow nice.
R.I.P
Link is now false advertisement
http://www.cardomain.com/ride/2073592
red_genisis
  • Short Track Racer
  • Site Posts: 177
  • Date Registered: August 03, 2005, 04:32:00 PM
  • My Car Hates Me!
« Reply #2 on: February 02, 2006, 08:06:00 PM »
so what exacty are the benefits of doing this
2004 Velocity Red Mazda 3s 4dr, Injen CAI, Eibach Pro Kit, Painted Red Calipers, Marquis Tint, Trubendz 2.5 High-flow Catback
Monzsta
  • Grand Am Series
  • Site Posts: 476
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« Reply #3 on: February 02, 2006, 08:53:05 PM »
More power, better mileage.  I'll post more on it tomorrow, after my 80 mile round trip to work.
08'  Tribute..
red_genisis
  • Short Track Racer
  • Site Posts: 177
  • My Car Hates Me!
« Reply #4 on: February 02, 2006, 09:03:14 PM »
if it turns out good, take a few pics of the senser a post em....oh and are there any draw backs to this
superjudge
  • Restricted Avatar
  • F1 Driver
  • Site Posts: 21678
  • Date Registered: December 06, 2004, 01:11:21 PM
  • Car Make: Ford
  • Car Model: Honda Civic EX
  • Car Year: 2008
« Reply #5 on: February 02, 2006, 09:12:50 PM »
This is seen in the Ausi/VW world and there is a gain in power, or at least it feels. I haven't heard any long term issues with it though. Monzta is right about the bolts though. Longevity of the VVT unit may be questionable over time, but keep us posted. I would avise anyone wanting to do this to be careful though, the ECU is very delicate.
What's the use of happiness? It can't buy you money.
Monzsta
  • Grand Am Series
  • Site Posts: 476
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« Reply #6 on: February 02, 2006, 09:23:10 PM »
To wit; the ECU isn't in danger, worst case scenario is you strip the little bolts and/or get a CEL, which is why you mark the position of the sensor so you can return it to its original position if needed.  The VVT has nothing to do with this, as the sensor reads off the little teeth on the crank pulley.  Just be careful with the bolts and this is probably one of the safer mods you can do.
08'  Tribute..
superjudge
  • Restricted Avatar
  • F1 Driver
  • Site Posts: 21678
  • Car Make: Ford
  • Car Year: 2008
« Reply #7 on: February 02, 2006, 09:25:38 PM »
Ohh I stand corrected, thanks for straightening that out.
Monzsta
  • Grand Am Series
  • Site Posts: 476
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« Reply #8 on: February 02, 2006, 09:29:27 PM »
No problem.  I'm a little worried about fooling with the VVT yet, as I don't have enough information on it yet.  There is some scan tool data I can't identify that I suspect is related to the VVT but I haven't proven it out yet.
08'  Tribute..
superjudge
  • Restricted Avatar
  • F1 Driver
  • Site Posts: 21678
  • Car Make: Ford
  • Car Year: 2008
Re: Advanced Ignition Timing Mod
« Reply #9 on: February 02, 2006, 09:40:28 PM »
I was actually thinking of something else when I posted that... I don;t think there is a scan tool availible as of yet.
Titanium
  • Why are all these Minivans on my race track?????
  • Short Track Racer
  • Site Posts: 224
  • Date Registered: December 31, 2003, 03:53:13 PM
    • http://omaharacing.com
« Reply #10 on: February 02, 2006, 10:09:46 PM »
I can't say for sure but I believe that when the knock sensor detects pre-detonation it will drop the timing much below what the timing would be set from the factory.  This certainly has some potential, but I would adjust it until I would never hear detonation. Premium fuel would help in this as well. I am interested in this so I hope others will try this and give feedback.
2004 Mazda 3s 4dr 5sp 12/03 build date.
Audiobahn A8002T, JL 300/4, Infinity Kappa 60.5cs, and one Infinity Perfect 10.1d.
2003 Yamaha Vmax, Kerker full exhaust, K&N, SPA tach/speedo and one big grin.
WWW.OMAHARACING.COM
hoffo
  • Le Mans: GT Class
  • Site Posts: 905
  • Date Registered: June 29, 2005, 04:38:34 PM
  • Forum Member
  • Car Make: Mazda
  • Car Model: 3i (velocity red)
  • Car Year: 2005
« Reply #11 on: February 02, 2006, 10:22:17 PM »
Yes that is typically the case with most timing systems on EFI cars that i know about. Hopefully it isn't knocking your timing down to stock or below levels otherwise there is no sense in this unless you use high octane.
2005 Mazda 3i 2.0 5spd manual, velocity red, power package, corksport rear motor mount insert, mazdaspeed short shifter, redline mt-90, k&n air filter, denso iridium plugs, carbon fiber shift boot
deepsleep
  • Short Track Racer
  • Site Posts: 159
  • Date Registered: December 26, 2005, 08:28:02 PM
  • Forum Member
« Reply #12 on: February 02, 2006, 10:40:23 PM »
i accidently filled my car up with premium today! :bash: maybe i should try this tomorrow? what kinds of gains are we talkin? 1-4 hp? or like 10+?
dream with your eyes open, and make them come true.
MajesticBlueNTO
  • Go-Kart Driver
  • Site Posts: 82
  • Date Registered: August 19, 2004, 10:42:51 PM
« Reply #13 on: February 02, 2006, 11:28:34 PM »
Cool mod Monzsta!
Here is some data pulled from my scan tool when I was stock.  The base timing varies from 6.5 to 10 degrees at idle.  The ECU advances the timing to as high as 50.5 degrees at part throttle (1939RPM) and 46mph (74km/h).
0   mph
6.5   deg
699   RPM
0   mph
8.5   deg
694   RPM
0   mph
9   deg
689   RPM
46   mph
50.5   deg
1939   RPM
61   mph
47.5   deg
2598   RPM
AzMs3
  • Senior Member
  • F1 Driver
  • Site Posts: 5955
  • Transaction Count: (2)
  • Date Registered: January 21, 2004, 04:30:17 AM
  • Car Make: Ford
  • Car Model: Mustang GT
  • Car Year: 2010
« Reply #14 on: February 03, 2006, 01:11:09 AM »
This has actually been posted awhile ago, but retarding timing for the turbo guys.
This is a very simple thing to do, I'd like to see it done ona dyno.
I doubt there would be huge gains, if anything at all it will be very small gains, maybe drivablitly improvement.
2010 Mustang GT
Roush Exhaust
284whp & 294wtq
red_genisis
  • Short Track Racer
  • Site Posts: 177
  • My Car Hates Me!
« Reply #15 on: February 03, 2006, 02:02:11 AM »
i might try this after class 2marrow but can some give me a pic of the sensor just so i can be sure im messin with the right thing (i am the world champion f#$k up)
mica3speedy
  • the IT guy
  • FMVmoderator
  • F1 Driver
  • Site Posts: 4798
  • Transaction Count: (1)
  • Date Registered: April 01, 2004, 01:02:32 PM
  • Car Make: Mazda
  • Car Model: 3s sedan
  • Car Year: 2004
« Reply #16 on: February 03, 2006, 09:48:01 AM »
this sounds interesting... keep us posted on how it's working for you 8) .
2004 black mica 3s w/5-spd
AEM CAI | Vibrant exhaust| advanced timing
Monzsta
  • Grand Am Series
  • Site Posts: 476
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« Reply #17 on: February 04, 2006, 12:19:06 AM »
After the 80 mile beat down, everything's okay, the engine revs freer, no spark knock, it seems to be an improvement. (could be the new mod placebo effect)  Next I'll see how much fuel I use during the next week.  Feel free to try it.  No pics yet.
08'  Tribute..
MPTX
  • I feel the need for speed....on a budget
  • Grand Am Series
  • Site Posts: 403
  • Date Registered: November 10, 2005, 09:48:32 AM
  • Safety????
« Reply #18 on: February 04, 2006, 03:51:09 PM »
I think that i will try this today.
3s ATX/K&N typhoon CAI/ Tru-Bendz 2.5 SS exhaust/ custom grounding kit/Techna-fit SS brakelines/ 35/25 tint/  interior neons/ vibrant strut bar/ hankook ventus tires
all Royal Purple race fluids
Drive it like you stole it....because an adrenaline gland is a terrible thing to waste
mica3speedy
  • the IT guy
  • FMVmoderator
  • F1 Driver
  • Site Posts: 4798
  • Car Make: Mazda
  • Car Year: 2004
« Reply #19 on: February 11, 2006, 01:48:20 PM »
 :bump: :ttiwwp:
it's been a week now... any updates?
MrTea
  • Former Staff
  • Site Posts: 2253
  • Date Registered: August 17, 2004, 03:23:41 AM
  • Car Make: Mazda
  • Car Model: Mazda6i
  • Car Year: 2003
« Reply #20 on: February 11, 2006, 02:43:19 PM »
this should give you the jist of it, though this is on a 6 and not a 3.  but you can see the sensor on the left side, just loosen the 2 bolts and move, retighten.
:::edit::: and i'm completely retarted (no pun there) which is why my sensor is pushed all the way up.
« Last Edit: February 11, 2006, 02:45:27 PM by MrTea »
'03 Mazda6i ....bunch o' mods
MPTX
  • Grand Am Series
  • Site Posts: 403
  • Safety????
« Reply #21 on: February 11, 2006, 02:54:18 PM »
is it lil lever looking thing that u pushed up that is the timing sensor.
MrTea
  • Former Staff
  • Site Posts: 2253
  • Car Make: Mazda
  • Car Year: 2003
« Reply #22 on: February 11, 2006, 03:04:21 PM »
sorta, it's not a "timing sensor", it's a crank shaft possition sensor...the ecu actually manipulates timing according to the algorithm it gets from this sensor.  yeah, pretty much the same, but not quite as easy.
and yes, it's pushed all the way up in the pic.
MPTX
  • Grand Am Series
  • Site Posts: 403
  • Safety????
« Reply #23 on: February 11, 2006, 04:40:24 PM »
I just want to make sure about this.  you mention two bolts earlier is it the thing that is bolted to the ac belt thing or is it that lil lever that you see in the top right of the pic pushed all the way up?
sorry for the repeat ?
MrTea
  • Former Staff
  • Site Posts: 2253
  • Car Make: Mazda
  • Car Year: 2003
« Reply #24 on: February 11, 2006, 04:44:00 PM »
if you look at the center of the crank pulley, the sensor is at about 8:00.  center/left on the pic, you can see where i moved the bolts.
ak47clown
  • Site Posts: 1534
  • Date Registered: April 25, 2005, 11:13:35 PM
« Reply #25 on: February 11, 2006, 06:27:12 PM »
looks pretty interseting to me
'05  sunlight silver metallic 3s: leather, abs, sports package, moonroof, 6cd changer.
Eclipse CD8445 HU w/ full steering wheel control, sirius, infinity reference 311a amp w/ perfect 12.1d sub, ported box, rainbow slc 265 components, diamond d3 amp, custom amp rack, superbright white led map and dome lights, sharkfin antenna, aftermarket heated seats, Ark Shortshifter
mica3speedy
  • the IT guy
  • FMVmoderator
  • F1 Driver
  • Site Posts: 4798
  • Car Make: Mazda
  • Car Year: 2004
« Reply #26 on: February 12, 2006, 12:09:18 PM »
so to advance the timing, do the opposite of yours... and push it down :dunno: ?
Monzsta
  • Grand Am Series
  • Site Posts: 476
  • Viper Tech
  • Car Make: Ford
  • Car Year: 2004
« Reply #27 on: February 12, 2006, 12:19:40 PM »
Yes, slide it down toward the ground.
After a week, the results aren't groundbreaking, but noticeable.  The engine is a little more peppier, more so toward the rev limiter, where before it seemed to ease up a bit just before the rev limiter, now it eagerly crashes into it, making me wish the rev limiter was a bit higher. (probably not wise with a 3.75" stroke cast crank engine!)  Fuel mileage hasn't changed.
I'm ready to take this a bit further, and it'll work for you as well, Mr Tea.  Measure the air gap between the trigger wheel and sensor.  Then remove the sensor and carefully push out the metal inserts.  Reinstall the sensor and move to the new position.  After determining your position, reestablish the air gap to what it was previousely.  It should be worth a few more degrees either advanced or retarded.
On a side note; Mr Tea, was there any noticeable difference when you installed the new pulley?  Is it lighter, or just an under drive pulley?  Being the 3 has an electric power steering pump (upgrade for your 6 maybe?) an underdrive pulley probably wouldn't be as noticeable.
« Last Edit: February 12, 2006, 12:24:17 PM by Monzsta »
08'  Tribute..
hate_romania
  • Site Posts: 1727
  • Date Registered: April 15, 2005, 03:34:02 AM
  • Montreal the Pothole CAPITAL of the world...arhhhh
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2009
« Reply #28 on: February 13, 2006, 12:30:37 AM »
can this cause a cel?? adn if you want to take it back to stock how can you align then perfectly?
Driving a 2010 mazda 3 gt with sunroof bone stock
SOLD: Mazda3 2005 Black mica 5dr, CAI AEM with AEM dryflow, Custom grounding cables, TWM SS, ETB Coolant Bypass, AWR 70d engine mount, Advance Timming Mod,
Cosworth Bsd, The only mazda 3 with dealer removed speed limit yey...230km/h
MrTea
  • Former Staff
  • Site Posts: 2253
  • Car Make: Mazda
  • Car Year: 2003
« Reply #29 on: February 13, 2006, 03:26:59 AM »
it's pretty obvious how to put it back to stock, as you can see on my sensor where it sat originally.
i don't have my car, so i can't do anything at this point.  which leads me to answer the question about the pulley.  this was a focus pulley i test fit as it's the same setup on the focus as the 6.  well my car didn't like it and i ended up burning a valve and possibly screwing up a ring on #1.  so unless you are getting the pulley from SR, don't bother.  the teeth on the focus gear are different by just a tad, ford uses a different ecu, different wave for the sensor, so timing took a poop....especially under boost.
