Author Topic: F2 S/C Thread (Updated 01-20-10, Details on OP)  (Read 47607 times)
ryukensfj
  • "Sex should be like a Civic; slow, obscene, and loud enough for the neighbors to hear."
  • F1 Driver
  • Site Posts: 5966
  • Transaction Count: (10)
  • Date Registered: June 15, 2006, 03:55:15 AM
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Model: 08 3s sport MT w/ 6cd/moonroof
  • Car Year: 2008
« on: July 07, 2009, 05:19:19 PM »
The Supercharger kits are currently having issues with shipping. The kits are not for sale yet, still fine tuning a little to get it perfect for you guys!
Stage 2 has not been released yet, a few things to finish on. The SC kit have only been tested on the 2.3l, 2.0 and auto models is currently in the testing stages. The 2.5l will be worked on after stage1 and stage2 are done for the 2.0 and 2.3l models.
Click here for Official F2 SC FAQ
Click here for Warranty Info on F2/Rotrex Supercharger
FAQ
1. I'm a noob, should I post questions
Please look through the Original Post(OP) before asking any questions. Most of the time your question will be answered by this post and if you still have a question then ask away :)
2. Will it come with a tuning solution.
Tuning for stage1 is controlled by Kraftwerks Power card, Stage2 and on will be controlled by either the CP-e SB or XFC.
3. Can I use my aftermarket intake?
No, the SC comes with its own intake.
4. Will the F2 SC kit be carb approved?
F2 has submitted the papers for CARB for the stage1 and is currently CARB pending. Stage2 and up will not be CARB certified.
5. Is stronger aftermarket engine mounts recommend?
Yes, at the very least you should change out the lower rear mount as it will help get the power to the ground.
6. I already have the CP-e SB or another tuning solution, will it work with the SC?
If you already have standback, F2 can provide you with a stage 2 kit, and you can tune it, or pay extra for the F2 tune for standback.
7. What spark plugs are required for the F2 SC kit?
The supercharger kit comes with colder iridium plugs that are pregapped. just thread them in.
8. What octane is required?
The F2 SC kit will be tuned with 91 octane, so at the very least 91 octane is required
9. What mods are recommended for the manual?
F2 recommends a new/stronger clutch. Gears are not required.
10. What mods do I need for the ATX?
ATX owners, expect to add a external trans cooler, and valve body mods to increase line pressure. F2 will not be altering anything atx related. We will make the power, if your trans breaks on stage 2, that's on you. Stage 1 s/c kit for the atx people will be within the power levels that the rest of the powertrain can handle, including the transmission.
11. What tools are required to install the kit?
If you have a wrench set between 10-19 mm, you can install our Supercharger kit.
12. What kind of maintenance is involved with the F2 SC kit.
Your usual stock maintenance plus the Rotrex supercharger has a scheduled oil change every 40-50K miles using a specially formulated oil made for the Rotrex superchargers.
13. Is Stage 1 safe for my stock engine?
Yes, as long as nothing is added or removed from the kit and 91 octane is used you will be fine for many miles. Please keep your routine oil changes and the supercharger maintanance and you will enjoy your vehicle for a long time. Take care of your car and it will take care of you.
14. Is Stage 2 safe for my stock engine?
Yes, again same with stage 1 take care of your car and it will take care of you. Do not try to remove or add anything without adjusting the tune and you will be fine. Also do not push the engine beyond its limit.
15. What are the terms of warranty for the supercharger?  How does a header, exhaust, and/or intake manifold affect the warranty of the Stage 1 kit?
Stage 1 kit will allow for an exhaust upgrade, no header or intake manifold should be added with out a piggy back ECU to add more fuel to the car. The warranty for the supercharger will not be void but if you add any other parts you might just blow your engine. adding parts to ths stage 1 kit will be at your own risk.
16. What are the terms of warranty for the supercharger?  How does a header, exhaust, and/or intake manifold affect the warranty of the Stage 2+ kit?
The stage 2 kit will also not void any warranty, with the stage 2 kit you can add any parts you desire but please make sure you get the car tuned correctly. Either by our support or someones else that knows.
17. Is Stage 1 safe for my transmission (list automatic and manual differences in power handling)?
Stage 1 is safe for all transmissions and even the stock clutch, but you must take care of your car. If you like to burn rubber a lot then no your parts will not last. Do not power-shift or abuse the drivetrain.
18. Is Stage 2 safe for my transmission (list automatic and manual differences in power handling)?
Stage 2 will require a new clutch for the MTX, if you have an atx at this point we cannot recommend stage 2 for the ATX.
19. When will the Stage 1 & 2 kits be available for the 2.0?
At this point we are looking at getting a 2.0L in the next week or two and start the testing on it...our plan is for it to be a 2.0L ATX and we will also work with CPE to make the standback available on the 2.0L. Expect the 2.0L to be ready Mid February...
20. What is included in the Stage 2 kit? Stage 2 will come with larger injectors, intercooler, tuning with CP-e standback 2, and no restrictor. Pulley changes may be an option, but let us finish testing stage 2 until we will know for sure.
Latest update...
Click me for F2 Supercharger Kits
Current pricing:
Stage1 $3250.00
Stage2 TBA
Stage3 TBA
Here are some pictures of the kit installed...
So here is our time line for the release of the superchargers....please note that this might change but we hope not...
04-05 2.3L Mazda 3 - November 27, 2009
06-09 2.3L Mazda 3 - December 11, 2009
04-09 2.3L Mazda 3 AUTO - December 21, 2009
04-09 2.0L Mazda 3 ALL - January 8, 2010
2010 2.5L & 2.0L Mazda 3 - January 22, 2010
And of course the Mazda 5 and Mazda 6 somewhere in between....
Expected power
Stage 1 - 196whp
Stage 2 - 215/220whp
Stage 3 - 250whp
OK guys here is the dyno graph of our last run on an 2004 Mazda 3 2.3L 5 Speed trans....
Please note the the superflow dyno is more conservative than a dynojet....so the numbers on a dyno jet will be higher...
Superflow Dyno
184whp
186ft/lbs
Dyno Jet the number are as follows
195whp
196ft/lbs
Here is the final version of the Supercharger mount and it starts getting installed Tomorrow on a Mazda 3....Fusion will be installed in a few weeks....
The supercharger is going to be sold with carb pending. We prefer to have a kit that nobody can hassle you about(Local authorities)
Rotrex C30-74
« Last Edit: July 09, 2010, 04:50:53 PM by ryukensfj »
08 CWP Mz3 S Sport 2.3l 4dr
Current mods: F2 turbo kit, F2 exhaust, F2 BSD, F2 oil baffle kit, F2 rear swaybar, KW V2 Coilovers, SPC Rear Camber Links, WR ETD, Medieval Rear MM, FI Grounding Kit, Eibach Pro-Kit, RKM STS, XenonExpert pedals, 15% tint, 35w DDM 6000K HIDs, Dome and Map LEDs, Lamin-X Yellow Fogs, Sharkfin Antenna
Future mods: lip kit...
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
Re: F2 S/C Thread ==NO COMMENTS PLEASE== (Updated 7-7-09)
« Reply #1 on: August 12, 2009, 05:08:09 PM »
Direct quote from the man himself!
"Tomorrow Randy will be working with his dad on the supercharger as we have planned to complete it by next Saturday...we have an appointment with Oscar Jackson at his shop..."
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #2 on: August 20, 2009, 09:52:45 PM »
Cell Phone video of the S/C running with no piping...
« Last Edit: August 20, 2009, 09:53:52 PM by ryukensfj »
ekanddsm
  • Grand Am Series
  • Site Posts: 410
  • Transaction Count: (0)
  • Date Registered: April 18, 2007, 05:35:33 PM
Re: F2 S/C Thread ==NO COMMENTS PLEASE== (Updated 8-28-09)
« Reply #3 on: August 24, 2009, 11:57:24 PM »
No freebies,
But I need a 2.0 to try the kit out on.
The car needs to be all stock, no exhaust or nothing and close to southern cali.
2.0 can be auto or stick, pzev or not.
Someone who does alot of communting would be ideal, but more so clearence testing and fitment on a 2.0
There is no hacking done on this kit. And no wiring either. Completely reversible, within a couple of hours.
Car could be returned to stock in under 3 hours.....
PM me for inquries.
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #4 on: August 28, 2009, 08:53:45 PM »
*edit* The above post can remain
Quote from Randy...
Piping is complete. Pics to follow later......maybe
Fuel Controller has been delayed. Vehicle in question is ready to be tuned, but will not be completed until after Labor day.
Follow closely, first drive videos will follow after dyno tuning.
Also, you cant call Kraftwerks looking for a supercharger kit for the Mazda3, F2 is making the kit, not Kraftwerks........for those who called and asked.
« Last Edit: September 02, 2009, 08:05:17 PM by ryukensfj »
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
Re: F2 S/C Thread ==NO COMMENTS PLEASE== (Updated 09-03-09)
« Reply #5 on: September 03, 2009, 11:08:58 PM »
From Ricardo himself...
"we have a dyno tune session next weekend at kraftwerks"
« Last Edit: September 03, 2009, 11:17:33 PM by ryukensfj »
rhopsi
  • Moped Rider
  • Site Posts: 27
  • Date Registered: May 25, 2009, 11:40:29 PM
  • FMVenthusiast
  • Car Make: Mazda
  • Car Model: 3
  • Car Year: 2008
« Reply #6 on: September 04, 2009, 12:24:40 PM »
I have a 2.0 stick 2008
I also have a CAI but i dont mind switching it, if necessary, for the for the stock intake if you still need a test car. Other than that though my car (performance-wise) is completely stock.
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Transaction Count: (8)
  • Date Registered: April 12, 2005, 01:48:32 AM
    • http://www.f2fusion.com
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
« Reply #7 on: September 09, 2009, 10:30:30 PM »
Here are the final revision and this car is ready for tuning at Kraftwerks this weekend...check it out so far...
Owner of
www.f2fusion.com
2008 Focus SES Coupe (For Sale Soon)
2008 Ford Fusion
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
Re: F2 S/C Thread ==NO COMMENTS PLEASE== (Updated 09-09-09)
« Reply #8 on: September 09, 2009, 11:18:08 PM »
Awesome Ricardo!!! Can't wait for the numbers. Will you have an intercooled version or just this version?
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
« Reply #9 on: September 10, 2009, 12:48:48 AM »
At a later time we will have an intercooled version...we will only have this version for a while. We are submitting paperwork for CARB EO with this setup....
Owner of
www.f2fusion.com
2008 Ford Fusion
will0899
  • Moped Rider
  • Site Posts: 48
  • Date Registered: June 24, 2009, 05:16:51 PM
  • FMVenthusiast
  • Car Make: Mazda
  • Car Model: mazda3 2.3l hb
  • Car Year: 2007
« Reply #10 on: September 10, 2009, 12:59:01 AM »
any idea of how expensive? ball park es maybe??
07 mazda 3 gt hatchback, body kit, exhaust, cosmo racing intake, dvd, 5 point grounding kit,  more mods to come.
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
« Reply #11 on: September 10, 2009, 01:02:59 AM »
In the supercharger I am not sure yet as I am talking to Rotrex and Kraftwerks on the parts I have to buy from them...we are making the tubing, bracket for the supercharger.
My estimate so far based on costs that I got so far...$3600-$3700, but remember this kit will also be CARB legal...
Owner of
www.f2fusion.com
2008 Ford Fusion
LuisDC
  • Le Mans: Prototype Class
  • Site Posts: 1408
  • Date Registered: May 05, 2008, 11:39:54 PM
  • Car Make: Mazda
  • Car Model: Mazda 3 2.3L Sedan
  • Car Year: 2007
« Reply #12 on: September 11, 2009, 01:25:36 PM »
Whats the psi set at and whats the max psi you can get out of a rotrex supercharger?
Angel Eyes, Advance timing, Fujita intake, Flex Inovations grounding kit, 2.0 Oil Conversion, triple guage pod, Glowshift oil pressure,fuel pressure, volts, AEM WideBand, vcts removal, LightWeight pullies, BSD Removal, Upgraded Rear motor mount, Upgraded Passanger Mount, TRZ Tranny Mount, vibrant header, vibrant exhuast, racing beat front sway bar+front endlinks,racing beat rear sway bar, TWM short throw shifter, EBC redstuff brake pads, Michelin pilot sport a/s plus
dtravman
  • Just drive in the
  • Le Mans: GT Class
  • Site Posts: 649
  • Transaction Count: (1)
  • Date Registered: January 31, 2008, 03:59:38 AM
  • Car Make: Ford
  • Car Model: 07 2.3
  • Car Year: 2009
« Reply #13 on: September 11, 2009, 01:58:42 PM »
somewhere between 6-9 psi, but my question is that will you need any type of retarding of timing to control and prevent detonation under certain conditions while you are running the supercharger at full boost, or will the ECU be able to control its own ignition and prevent detonation on its own? because i know our cars are ok as far as ignition for FI for up to 14 psi, per dee at reactive. but superchargers have their differences, which is why i was asking about ignition control
« Last Edit: September 11, 2009, 02:09:13 PM by dtravman »
Youngun
  • Site Posts: 1349
  • Date Registered: June 24, 2007, 11:19:14 PM
  • Mines Faster
  • Car Make: Mazda
  • Car Model: Mazda 3S, Silver
  • Car Year: 2004
« Reply #14 on: September 11, 2009, 06:05:34 PM »
This kit is going to be sold at 5psi with a fuel tuning solution made for this kit exclusively. There should be no problems or need for timing control.
My Duratec got Nuked
ekanddsm
  • Grand Am Series
  • Site Posts: 410
« Reply #15 on: September 11, 2009, 07:53:02 PM »
PSI is not what we are concerned with, on the kit.
I could have 4 psi make more power than 10 psi.
The beauty of the kit, is the lack of heat that will be thrown into the engine. The supercharger is far more efficient then the turbos we have used in the past.
Look up efficiency of the rotrex c-30/74 and compare to a garret turbo. The rotrex doesnt heat the air up until you start moving alot of air, like 15-20 psi.
So stay tuned.....
But I still need a 2.0 pzev or non pzev to try the kit out on...
Youngun
  • Site Posts: 1349
  • Mines Faster
  • Car Make: Mazda
  • Car Year: 2004
« Reply #16 on: September 11, 2009, 09:15:47 PM »
Oh yes I forgot that the air is not pre heated like the turbo air is.....denser air = more HP.
BTW if you are all un-aware the above poster is F2's mechanic and tuner. He is a wealth of knowledge on the Mazda platforms.
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #17 on: September 13, 2009, 08:07:46 PM »
OMG!!! :shock: I just heard the most exciting news for the SC but Ricardo wants to post it himself so you guys just have to wait  :quiet:
« Last Edit: September 13, 2009, 08:11:26 PM by ryukensfj »
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
« Reply #18 on: September 14, 2009, 02:44:47 PM »
So here is some video of the car at Kraftwerks...more details to follow
« Last Edit: September 14, 2009, 02:47:09 PM by f2focus »
Owner of
www.f2fusion.com
2008 Ford Fusion
Youngun
  • Site Posts: 1349
  • Mines Faster
  • Car Make: Mazda
  • Car Year: 2004
« Reply #19 on: September 14, 2009, 03:14:08 PM »
Man your lucky Randy didn't break your camera :P
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
« Reply #20 on: September 14, 2009, 03:15:30 PM »
Well I did not let him touch it.... :lol:
Owner of
www.f2fusion.com
2008 Ford Fusion
biped
  • bawdy man
  • F1 Driver
  • Site Posts: 9940
  • Transaction Count: (7)
  • Date Registered: January 09, 2006, 11:59:07 AM
  • wM6.66 | fancy pants
  • Car Make: Mazda
  • Car Model: 2.3
  • Car Year: 2006
« Reply #21 on: September 14, 2009, 04:26:05 PM »
so what is it puttin down?
Youngun
  • Site Posts: 1349
  • Mines Faster
  • Car Make: Mazda
  • Car Year: 2004
« Reply #22 on: September 14, 2009, 04:33:24 PM »
Some sort of F2 gang sign last I checked.
The numbers are not going to be posted until the final tune is done next week. What can be said is the first tune looks like it put down some really really impressive numbers that will surprise some people!
ryukensfj
  • F1 Driver
  • Site Posts: 5966
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #23 on: September 14, 2009, 06:11:34 PM »
Yeah those #'s were f**king amazing! I can't wait until Ricardo post the #'s so I can read the reaction of the people here. :lol:
Youngun
  • Site Posts: 1349
  • Mines Faster
  • Car Make: Mazda
  • Car Year: 2004
« Reply #24 on: September 14, 2009, 06:18:54 PM »
Hey msg me on the F2 thread. I want to make a friendly wager with you on the final whp tune.
TSBMazda3
  • Le Mans: GT Class
  • Site Posts: 983
  • Date Registered: July 23, 2008, 02:18:55 PM
  • Car Make: Mazda
  • Car Model: Black Mica Hatchback.
  • Car Year: 2008
« Reply #25 on: September 14, 2009, 11:26:18 PM »
It is more expensive than the turbo by a good amount but this is including the tuning solution correct?
It is worth it because by the sound of it I can install this by myself and use the "tuning solution" that is so secretive. As with the turbo I had to save more money for the 1k install and tune up at chicago..
It really evens out.
I hate you all I was gonna go to sleep, but now my mind is just gonna be thinking about this all night... :lol:
HKS Catback---Koni Yellow Struts---Eibach Sportline Springs---SPC Camber Links--- 18x8.5 Flat Black Rota Grids on 225/40/18 Nexen N3000 Tires---Red Muteki Lugs---Injen CAI--- 20% Tint---Blacked out sidemarkers & tail lights
f2focus
  • Gold Sponsor
  • Le Mans: GT Class
  • Site Posts: 711
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2008
Re: F2 S/C Thread ==NO COMMENTS PLEASE== (Updated 09-14-09)
« Reply #26 on: September 14, 2009, 11:40:57 PM »
Here are some details...the Supercharger will be more than a turbo. but the supercharger will be CARB legal, that matters to some and not to others. But it does mean no tickets for a modified car.
The tuning solution is a proprietary solution that Kraftwerks uses. The installation will be real easy and should take no more than 3-4 hours. The hard part will be to prep the supercharger as that is the most important part otherwise you will be purchasing a new supercharger...
This Saturday is what I hope one more trip that we can nail this setup down...we need to try a new belt and a new pulley (smaller diameter) and then we are testing two more 2.3L cars and we need some 2.0L cars to test as well.
Anyone know anyone with a Mazda 5?
We already have a Mazda 6 that we are testing as well....
Owner of
www.f2fusion.com
2008 Ford Fusion
yamibear
  • Le Mans: GT Class
  • Site Posts: 534
  • Transaction Count: (3)
  • Date Registered: December 24, 2007, 11:10:54 PM
  • Car Make: Mazda
  • Car Model: SNAIL SEDAN
  • Car Year: 2005
« Reply #27 on: September 14, 2009, 11:55:12 PM »
man i love this sc unit! lets go F2!!!!!
PS. come out with awd conversion and twin charger plz :D
biped
  • bawdy man
  • F1 Driver
  • Site Posts: 9940
  • Car Make: Mazda
  • Car Model: 2.3
  • Car Year: 2006
« Reply #28 on: September 15, 2009, 06:16:06 AM »
man
supercharged mazda 5 would be pimp.
ekanddsm
  • Grand Am Series
  • Site Posts: 410
« Reply #29 on: September 16, 2009, 09:35:31 AM »
In testing fuel economy numbers on the supercharger test car,
It handed a BMW 328i newest model year, it's ass from a stop light, 0-80 mph it took the car by four lengths. The law student didnt even know what hit him.
then it proceeded to get better than stock fuel economy.......
4mpgs over stock.
and youngun,
Your car dropped the camera, not me. I was trying to use my right foot as traction control.
