Author Topic: How to: Instantaneous MPG on a Mazda3  (Read 12872 times)
seventynine
  • Go-Kart Driver
  • Site Posts: 70
  • Transaction Count: (0)
  • Date Registered: October 30, 2006, 06:57:05 AM
  • Car Year: 2007
« on: February 24, 2008, 08:03:10 PM »
Quote
I found out about this neat trick so I'm spreading the word.  It may not work on all cars, but it is known to work on 06+ Mazda3's with a 6-cd Player. My car is the Touring trim. A Trip Computer function is available on Grand Touring trim.  It seems that the functionality in "lesser" models exists in the electronics, but is disabled. Use the following steps to enable it!
1. Get in car and close door.
2. Put key into ignition (DO NOT TURN YET!)
3. Hold down the AM/FM button AND the CD button.
4. With your other hand (while still holding the buttons) turn your key to the ACC position.  The "Hello" message will appear on your display, and as soon as it goes away it will be replaced by DIS ON.
5. You may now let go of the AM/FM button and CD button.
6. Turn ignition off.
Now consult your owner's manual for how to use, but substitute the "Set" button in place of the "Info" button.  Pressing "Set" toggles through the functions and is also used to reset. Press "Clock" to go back to clock mode.
The functions are:
    * Current MPG, updated every 2 seconds
    * Average MPG
    * Approximate distance to empty, based on current avg mileage
    * Average speed
Ok, it won't change your life, but the Instant MPG is good to know, and you can see how conditions and driving habits alter the MPG. Naturally, it is zero when you are sitting still, but jumps to 99mpg when you are coasting in gear. All cars should have such a simple device, just to make people aware of what they're using and how their driving affects how much they're using.
Hopefully I've helped a few readers save some gas and save some money!
Bill
Found this on consumerreports.com forum. My sincere apologies if it has already been posted before.
2007 Mazda3 i 2.0 MT Touring Galaxy Gray
ryukensfj
  • "Sex should be like a Civic; slow, obscene, and loud enough for the neighbors to hear."
  • F1 Driver
  • Site Posts: 5921
  • Transaction Count: (10)
  • Date Registered: June 15, 2006, 03:55:15 AM
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Model: 08 3s sport MT w/ 6cd/moonroof
  • Car Year: 2008
Re: How to: Instantaneous MPG on a Mazda3
« Reply #1 on: February 24, 2008, 11:09:32 PM »
It had been posted here already, but thanks for trying. It works on 06-07 no matter what trim or cd player you have. For 08 you need to have the 6-cd player in order for this to work.
astrob0y
  • Le Mans: GT Class
  • Site Posts: 974
  • Transaction Count: (8)
  • Date Registered: September 17, 2007, 09:44:39 PM
  • Car Make: Mazda
  • Car Model: 3s
  • Car Year: 2008
« Reply #2 on: February 25, 2008, 01:03:47 AM »
Damn that sucks
seventynine
  • Go-Kart Driver
  • Site Posts: 70
  • Car Year: 2007
« Reply #3 on: February 26, 2008, 04:41:27 PM »
I attempted on my 2.0i Touring 2007. Single CD player. Didn't work !?!
1. Entered and closed door.
2. Put in key.
3. Held CD + AM/FM.
4. Turn key to ACC. Then released CD + AM/FM once "Hello" came up.
"Hello" came up and everything went normal.
5. Turned ignition off.
6. Turned ignition on.
7. Pressed SET several times.
Still saw the clock and everrything as usual.
What did I miss?
« Last Edit: February 26, 2008, 04:47:18 PM by seventynine »
cromus
  • F1 Driver
  • Site Posts: 3022
  • Transaction Count: (1)
  • Date Registered: May 02, 2006, 10:14:38 AM
    • My Car
  • Car Make: Mazda
  • Car Model: rx8
  • Car Year: 2004
« Reply #4 on: February 26, 2008, 04:44:07 PM »
darn i had high hopes that this thread would give me a few more MPG. it failed to deliver :(
John_in_the_LBC
  • Resident Mr. Know-it-all
  • Senior Member
  • F1 Driver
  • Site Posts: 26503
  • Transaction Count: (4)
  • Date Registered: April 20, 2006, 12:04:35 AM
  • If you have any poo, fling it now!
  • Car Make: Mazda
  • Car Model: Whitewater Pearl S GT Hatch
  • Car Year: 2006
« Reply #5 on: February 26, 2008, 04:52:31 PM »
2. Put in key.
3. Held CD + AM/FM.
What did I miss?
you need to see "DIS ON" before releasing the buttons.
http://www.mazda3forums.com/index.php?topic=69347.0
: Stubby : Tint : Buddy Club Condenser : XE Pedals : Garage Vary Valiant Lip, Grill and Eyelids : Custom JL/Alpine Audio : MazdaSpeed Accessory Springs and Swaybars : JDM MazdaSpeed Strut Bar : Koni Yellows : 5Zigen Pro Racer zr520 : Sumitomo HTR ZIII : Black Rays Lugs : OMG MOVE :
http://www.cardomain.com/ride/2331859/1 My car thread Pearl White 3 in the LBC
makballer
  • Grand Am Series
  • Site Posts: 496
  • Date Registered: January 03, 2008, 01:43:59 PM
  • Car Model: Mazda3
  • Car Year: 2008
« Reply #6 on: February 26, 2008, 06:49:17 PM »
i think this should be a sticky somewhere
i just did this to my car but had to use a diff method
NOTICE: 2008 MODELS
to unlock the trip computer on the 2008 model you must...
1. pop yo hood and disconnect the NEGATIVE battery thingy
2. leave it off for 2-3 mins
3. reconnect the thingy to the battery
4. turn your key to "ON"
5. turn on your radio
6. now to cycle through your trip computer modes press the ":00" button
7. give yourself a pat on the back
« Last Edit: February 26, 2008, 07:36:04 PM by makballer »
oredith
  • F1 Driver
  • Site Posts: 3299
  • Date Registered: December 21, 2007, 06:58:44 PM
  • Car Model: BM HB
  • Car Year: 2006
« Reply #7 on: February 26, 2008, 06:57:44 PM »
NOTICE: 2008 MODELS
1. pop yo trunk and disconnect the NEGATIVE battery thingy
6. first, to enable the auto power window function, roll your driver's side window all the way down
7. roll it all the way up and once it reaches the top hold "up" for 3 seconds
8. now to cycle through your trip computer modes press the ":00" button
9. give yourself a pat on the back
is this serious? it sounds like one of those "i can't believe you actually fell for that" type of deals.
'06 Hatch - Mods : almost NONE <- win?
I rememeber when mine was that small... now it's like 4 inches!  haha
ryukensfj
  • F1 Driver
  • Site Posts: 5921
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #8 on: February 26, 2008, 07:15:03 PM »
This is stickied. John gave the link to it above.
NOTICE: 2008 MODELS
Pop the trunk and discconect the negative battery terminal? Never knew we had the battery in the trunk. What is with this step? Don't we already have the auto down power window function?
bustednutz
  • Short Track Racer
  • Site Posts: 151
  • Date Registered: October 25, 2007, 08:38:10 PM
« Reply #9 on: February 26, 2008, 07:20:43 PM »
I used the original posters method.
Works just fine for me.
pretty cool
makballer
  • Grand Am Series
  • Site Posts: 496
  • Car Model: Mazda3
  • Car Year: 2008
« Reply #10 on: February 26, 2008, 07:26:46 PM »
NOTICE: 2008 MODELS
good catch lol i made the edit.
disconnecting the battery i guess resets the auto window function and doing steps 6-7 supposedly reprograms it.
i had tried the original posters method and got the DIS ON but when i restarted the car i didn't have the trip comp on so i did some further research and found this method on another website. it worked so i figured i'd share it!
ryukensfj
  • F1 Driver
  • Site Posts: 5921
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #11 on: February 26, 2008, 07:31:37 PM »
When I reset mine, my auto power windows still work.
makballer
  • Grand Am Series
  • Site Posts: 496
  • Car Model: Mazda3
  • Car Year: 2008
« Reply #12 on: February 26, 2008, 07:34:55 PM »
alright then i'll take out steps 6-7
khoi
  • Grand Am Series
  • Site Posts: 319
  • Date Registered: October 12, 2007, 06:11:27 PM
  • Car Make: Mazda
  • Car Model: SunlightSilver Mazda3 sTouring
  • Car Year: 2009
« Reply #13 on: February 26, 2008, 08:25:56 PM »
Do you have 2008 with 6disk CD player? or single disk CD player?
makballer
  • Grand Am Series
  • Site Posts: 496
  • Car Model: Mazda3
  • Car Year: 2008
« Reply #14 on: February 26, 2008, 08:29:29 PM »
6cd. i have read somewhere that on the 2008 models it only works on the 6cd player but idk if whether has been confirmed or not.
khoi
  • Grand Am Series
  • Site Posts: 319
  • Car Make: Mazda
  • Car Year: 2009
« Reply #15 on: February 26, 2008, 08:31:44 PM »
Yeah, that's what I read also.
frankh21
  • Stangster
  • Grand Am Series
  • Site Posts: 432
  • Date Registered: July 04, 2005, 02:47:37 AM
  • Socom FTB2
  • Car Make: Ford
  • Car Model: '05 MZ3 Hatch, '98 Cobra
  • Car Year: 2009
« Reply #16 on: February 27, 2008, 03:16:41 AM »
Has anyone tried this on an '05 model yet or is this just for '06 and up?
2005 Mazda 3S Titanium 5-sp. ABS,SAC,Moonroof....sold =/
1998 Crystal White Cobra  Steeda Springs, Steeda Caster/Camber plates, Tokico Adjustables, Steeda Ball joints, Urethane bushings.
ryukensfj
  • F1 Driver
  • Site Posts: 5921
  • F2 Turboed
    • cardomain
  • Car Make: Mazda
  • Car Year: 2008
« Reply #17 on: February 27, 2008, 03:25:09 AM »
Only works for 06+ I tried it on an 05 and it does not work.
astrob0y
  • Le Mans: GT Class
  • Site Posts: 974
  • Car Make: Mazda
  • Car Model: 3s
  • Car Year: 2008
« Reply #18 on: February 27, 2008, 02:00:25 PM »
NOTICE: 2008 MODELS
So is there really a battery in the trunk? o.o
Jabooh1
  • Short Track Racer
  • Site Posts: 116
  • Date Registered: November 14, 2006, 10:56:56 AM
  • Forum Member
« Reply #19 on: February 28, 2008, 12:21:45 PM »
Worked on my 06 with a 6 disc changer.
'06 S Sedan Fog mod, TB Ground, Red Calipers, Shark Fin antenna, Instant MPG mod.... more to come.
blinkbcrbass
  • Bicycle Rider
  • Site Posts: 8
  • Date Registered: March 02, 2008, 12:50:16 AM
  • Car Model: Mazda3 2.3 AT (5-door Touring)
  • Car Year: 2007
« Reply #20 on: March 02, 2008, 02:58:41 PM »
This is confirmed on my 2007 M3 5-Door 2.3 AT
lordkosc
  • Short Track Racer
  • Site Posts: 200
  • Date Registered: July 17, 2004, 09:44:08 PM
  • Godspeed , Zoom Zoom !
  • Car Model: 2008.5 Mazda 3 Grand Touring ATX 5-door Metropolitan Gray Mica
  • Car Year: 2008
« Reply #21 on: March 02, 2008, 10:59:26 PM »
My 2008.5 came with the trip computer stock, just press the info button next to the clock button.
New Hotness: 2008.5 Mazda 3 Grand Touring ATX 5-door Metropolitan Gray Mica , Bose/Moon/Leather/Remote Start
Traded in old Hotness: 2004 Mazda 3s Ti Grey @  92k+ miles
phoenix249422
  • Moped Rider
  • Site Posts: 24
  • Date Registered: February 10, 2008, 09:02:53 PM
  • Car Model: Mazda 3i
  • Car Year: 2008
« Reply #22 on: March 02, 2008, 11:08:11 PM »
Does anyone know if this different process works with the 2008 M3 Single Disk?
makballer
  • Grand Am Series
  • Site Posts: 496
  • Car Model: Mazda3
  • Car Year: 2008
« Reply #23 on: March 03, 2008, 08:33:38 PM »
can't be done on an 08 w/o the 6 disc
John_in_the_LBC
  • Senior Member
  • F1 Driver
  • Site Posts: 26503
  • Car Make: Mazda
  • Car Year: 2006
« Reply #24 on: March 03, 2008, 08:40:35 PM »
Damn that sucks
that's what they say...i don't know firsthand
danielj
  • How may I help you?
  • FMVmoderator
  • F1 Driver
  • Site Posts: 15540
  • Transaction Count: (11)
  • Date Registered: February 28, 2007, 04:08:52 PM
  • Car Make: VW/Audi/Porsche
  • Car Model: GTI
  • Car Year: 2010
« Reply #25 on: March 03, 2008, 08:48:54 PM »
Damn that sucks
That's weird. GT's have the trip computer regardless of the optional 6 disc.
Hi Everybody :wavey:
Click here to see what I used to drive.
seventynine
  • Go-Kart Driver
  • Site Posts: 70
  • Car Year: 2007
« Reply #26 on: March 04, 2008, 02:05:27 PM »
Well....I turned mine off after just 3 days. It was a constant distraction and I was paying a lot more attention to it than I should've. Though it's not the guage's fault that I was getting distracted. But I turned it off and went back to calculating MPGs at gas fillups - which gives a better overall picture anyway.
Punktual
  • Moped Rider
  • Site Posts: 33
  • Date Registered: February 06, 2008, 11:38:13 PM
  • Car Model: Galaxy Gray Mica 2.3S Touring 5-Door MTX One Hell of a Wallet-Sucker
  • Car Year: 2008
« Reply #27 on: March 06, 2008, 01:29:07 AM »
Bump for a great little trick. Have the '08 5 door MTX and had to do the 2 minute battery disconnect, but that little display works great and sure is helpful!...but distracting
'08 Galaxy Gray Mica [Mazdaspeed CBE] [BCC] [Simota CF SRI ] [TWM SS + Boot] [Skunk2 Knob] [LED Tails] [Blue LEDs in and out] [trip Computer Unlock] [20% Front/ 15% Rear Tint] [Stubby (but I accept that)]
And now I'm out of money...paychecks can't catch up with the car:(
To Come (hopefully)
->Weighted Knob ->F/R Sways ->road magnet 1.25"
vipz
  • Moped Rider
  • Site Posts: 25
  • Date Registered: January 14, 2008, 04:35:47 AM
  • Llamalicious
  • Car Model: Mazda3s Sport hatchback, silver, 5-spd
  • Car Year: 2008
« Reply #28 on: March 20, 2008, 04:41:43 AM »
So for those with an 08 single-disc (like me), what are the options for getting the trip computer?
What about trip computer + MP3 capability in the CD player?
colnagordr
  • Go-Kart Driver
  • Site Posts: 82
  • Date Registered: June 05, 2006, 05:19:26 PM
  • Car Year: 2006
« Reply #29 on: March 22, 2008, 08:43:06 PM »
I have a 06 5 door with the single CD and this did NOT work for me.
2006 3, 5 door.  Thule fixpoint. Stubby
