Author Topic: HOW TO: Heated mirror install, & LED puddle lamps  (Read 20700 times)
icspots
  • Fighting natural selection one moron at a time.
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Transaction Count: (3)
  • Date Registered: August 10, 2005, 01:14:55 PM
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« on: February 21, 2008, 12:14:22 AM »
First off credit goes to billm and BiggBlunt for their previous walkthroughs.  I  just followed their directions and then took pictures of what I did to make this How To.  If after doing this install you have any suggestions for changes to the walkthrough please let me know and I'll do my best to keep it updated.
This is designed to help you install heated side mirror glass on Mz3's so that they come on with the rear defroster, and also in installing LED puddle lamps in your mirrors.
The OEM glass with the heating elements is about $41 per side and only requires you to add wiring between the glass and the mirror side of the wiring harness plug as all the rest of the wiring is already present in the car.*  For another walkthrough check out billm's walkthrough.
I also installed a few LEDs in the bottom of the mirror mounts to act as puddle lamps when I unlock my doors.  If you're not doing this then you can ignore those steps.  I wired the LEDs as detailed in the Lighted Door Sill Install.  They come on when: I unlock the car, open a door, or turn off the ignition.  For another look check out BiggBlunt's walkthrough.
* Mz3's with manual mirrors may not have mirror wiring run to the door, and the mounting hardware may be different from the power mirrors.  Please check your car before buying.  Also all info provided is from US spec Mz3's, and specs do differ from country to country.
Parts needed:
Supplies:
-Driver's side heated glass p/n BP8M-69-1G7
-Passenger's side heated glass p/n BP8M-69-1G1
-wire (approx 30")
-small spade connectors
-solder
-pack of diodes
-electrical tape/heat shrink
-small zip ties
-LED lights
-Lithium grease
Optional:
-barrier strip
-fork spade connectors
Tools:
-phillips screwdriver
-T26 torx driver/bit ('07+ models and some '06 models)
-8mm socket/wrench
-mini flathead screwdriver
-soldering iron
-drill (dremel, etc.)
-3/8" bit
-wire cutters/strippers/crimpers
Difficulty:
1-3 if you're comfortable with taking things apart and know how to solder/work with wiring.  4-6 if you've never done any wiring but can follow directions and are willing to learn to do new stuff.  7-10 if you don't know how and can't follow instructions. :P
Disclaimer.  This How To is for informational purposes only.  I take no responsibility for any damage caused to your vehicle while you attempt this install.  Be safe and have fun.
1.Start by removing your mirror from the car.  Open the door and grab the top of the triangular panel housing the tweeter and pull down and towards the inside of the car.  The bottom has a hook and will hinge slightly.  Unplug the wiring harness plug and remove the three 8mm bolts holding the mirror to the car.  Make sure to support the mirror since it will fall once the bolts are out.
from BiggBlunt
Now here's your mirror off of the car.
2.First remove the glass portion.  Note: If you live in a cold area make sure to let the housing/glass warm to room temperature before removing the glass, otherwise the flexing that occurs during glass removal may crack the stock glass.  The glass is held on by three ball joints, one large center one, and a small one to the outside and to the bottom of the large one.  Push the glass all the way to the outside (the motor will make popping noises but that's okay).  Then grab the inside edge of the mirror and pull towards you to release the center ball.
Next push the mirror all the way to the inside and grab the outside edge.  Pull back firmly to release the small outside ball.  Once that's loose push the mirror up and grab the bottom edge.  Pull back to release the bottom/last ball joint.  Set the mirror aside.
This is what the mirror motor looks like without the glass
3.Next we have to release the white plug.  Lift up the foam above the plug to reveal a little slot beneath a piece of black plastic.  Insert a flat head screwdriver into the slot and push firmly down on the white plug while pulling the plug out to release the little plastic tab holding it in place.  The black part does not move.
4.Flip the mirror upside down and pull the foam section from around the corner to run the wiring.  Take care not to tear the highlighted sections.  You don't have to fully remove it, just expose the bottom corner section.
5.Remove the triangular panel by prying up the corner with the bulge.  Try not to pry from any other part as it could break the clip on the opposite side.
Remove the three screws under the cover and then pull to separate the two sections.  They won't pull very far because of the wiring inside, but it will be enough to let you run wires through it.  On '07 and newer models (and some '06 models) these screws are torx instead of phillips head.
6.Time to start running wires.  Start at the white plug and run the wire between the pieces of foam to come out where the rest of the OE wiring is.  Then run the wire through the channel towards the hinge section.  Once through to the hinge run the wiring up through the tube with the springs. Note: If installing thespeedline mirrors with the supplied wiring you need to run the wire starting from the glass side and ending at the white plug
If you're installing LEDs then repeat step #6 so you have two pairs of wires.
7.Now it's time to fabricate the new pins for the harness plug.  Pull out your pack of diodes (it doesn't matter which ones you buy, just try to find ones that match the size of the pins in the plug) and cut the "legs" off of the diode.  You need about an inch or so for each pin, but confirm the length by sticking it into the plug and matching the depth of the OE pins.  Here's about how long I cut mine.  If you're unsure then cut them long to begin with as you can always shorten them later.
All the pins cut and ready to solder.  Strip off the ends of the wires and tin them with solder, then solder the pins onto them.
8.Now we insert the newly pinned wires into the white plug.  We want them to come out of these two holes to match up with the green and black wires on the other side of the plug.  To help the wires stay secure it helps to add a layer of shrink wrap around the end of the wire insulation and insert the wire into the plug far enough so the shrink wrap covered insulation is inside the plug..... basically there's less wiggle room.  Note: if using the wire supplied with thespeedline mirrors the insulation is thick enough that you don't need the heatshrink.  This is a good time to gauge the length of the pins you have and trim them down if they stick out too far.  Don't worry about aligning them perfectly right now as we can take care of that later.
If you're only installing the heated glass then skip to step #10.
9.If you're installing LEDs then you can either insert more pins like I did or run a separate wire out like BiggBlunt  I used the two empty slots to add more pins.
10.Once all your pins are in and the lengths are correct zip tie all the new wiring to the existing wires to keep them from moving around.
11.Once done with that reassemble the two pieces of the mirror housing arranging the wires so they're not pinched anywhere in the process.    Reinsert the white plug and replace the foam trim.
12.Trim off any excess wires on the glass end of the wires and attach mini female spade connectors onto the ends of the mirror wiring.
If you're only installing the heated glass then skip to step #17.
13.On to the LED installation.  I used 4-chip white superflux LEDs from www.oznium.com.  Determine where you want your LED to be placed and drill the hole to match your LED size.  Test fit your LED to make sure it fits to your liking.  The superflux's mount in a 3/8" hole, however I had to bore it out a bit to get it to fit very snugly.  Mine ended up sitting slightly more flush than this once installed.
14.Once you're satisfied with the placement/fit apply some super glue the the sides of the hole and insert the LED.  I also painted a bit of glue around the back of the LED once it was in place.
15.Now we run the LED wires behind the mirror motor to come out by the top of the tube with the spring.  You may or may not have to remove the motor to do this.  I was able to fish a wire behind the motor of one mirror and pull the wiring through, however I just couldn't get it to feed on the other side.  Removing the motor however is as simple as unscrewing these three screws.  Then just pull the motor forward slightly and run the wire behind it.  Reattach the motor.
16.Connect the LED wiring to the wires going to the white plug and then tuck the excess wiring behind the black frame behind the motor.
17.Reinstall the mirror housing onto the car in reverse order of step #1.
18.Plug the heated glass into the spade connectors (it doesn't matter which plugs in where) and reinstall the glass to the motor.  If you want to test to make sure the glass heats up properly before installing the glass skip to step #23 for aligning the pins, then continue with the rest of step #18.  I suggest lubricating the ball joints/holes with white lithium grease (or similar) as the new glass will not have any lubricant on it.  Also if there's any debris on the ball joints this would be a good time to clean them off.  If you do that definitely reapply some lube.  First connect the large center ball by pushing against the center.  As hard as you have to push you'll feel like you're about to snap the glass in half but then you'll suddenly hear a loud pop and it will be connected.  Do the same thing on the bottom and side for both of the small ball connectors.  Make sure you're centered on the ball joints when you push and try not to put any force perpendicular to the cylinder the ball joints are on as that could break them.
From billm
19.Now on to wiring up the car side of the plug.  I initially opted to not run a separate wire from the mirror like BiggBlunt did because I liked the idea of all the wiring being inside the factory plug.  What I did was inserted new spring clips (from an old computer connector) into two of the empty spots of the car side of the harness.  I later had some connection problems with my driver's side LED so I ended up wiring it the way BiggBlunt did.  Basically just run the LED wiring out of the mirror housing next to the white plug instead of stopping at the plug.  Then just add a few quick disconnects to attach to the wiring you'll run into the car.
To line up with the pins I put on the mirror side of the plug I'm inserting the clips into these two spots.  Just push the clips into the back of the slot and push it all the way in with a mini screwdriver.  You can see the different shape of the new clips vs. the originals.  Due to the shape I ended up angling the pins upward a bit so that instead of going into the hole like on the other slots they push against the top of it.
20.From here we get the joyful job of running the LED wiring into the car and to a power source.  The first thing to do is remove the inner door panel.  Remove the two phillips head screws behind the door release and the door handle respectively.  Then pop the "bowl" from the door release out of the door.  Next we pop the panel loose by pulling towards the inside of the car to release the tension clips.  There are clips all around the side edges and bottom, and a few around the center.  Once all of these are loose the whole panel will slide upwards out of the window channel.  Note: Don't pull the top towards the inside as it must slide upwards.  Once the panel comes free disconnect the various harnesses from the switches in the panel and set it aside.
21.Next we run the wire through the boot.  I have an explanation in one of the posts further down this thread HERE.  There was a picture I found on the forum but it's apparently gone bye bye.  Once you've run the wiring through the plastic plug you need to reattach the boot.  There are some better instructions courtesy of XCEL28 HERE, and some even better ones from Jeba HERE.  If I remove my door panels again anytime soon I'll take some newer/better pictures to cover these steps.
22.Once you have the wires inside the car you can either run them directly to your power source (in this case the maplights), or you can run everything to a central location.  What I did was mounted an eight position barrier strip on the base of the gear shift under the plastic paneling.
I ran the wiring from the map light following the lighted door sill walkthrough (see above)
down the driver's side A-pillar to one side of the barrier strip, and then connected the wiring of each mirror LED to the opposite side.  I used the upper portion of the barrier strip to wire up my interior blue LEDs (See THIS thread for details).  I decided to wire things this way as I wanted to minimize the amount of wiring up in the headliner, and it made a convenient way to consolidate all of the LED wiring.  Plus if I decide I want to add something else later it's simply a matter of screwing the wires on to the appropriate terminals.
23.Now is when you take the time to make sure all of the pins are aligned properly.  The diode legs are pretty bendable so you should be able to easily position them with a small flathead screwdriver.  While adjusting the pins you might accidentally push them back into the mirror's plug.  If so just pull them back out with a pair of pliers and continue adjusting.  If you followed the shrink wrap/insulation inside the plug suggestion earlier this should be less likely.  Reinsert the plug and test everything out, and make sure the little orange piece on the bottom isn't sticking out keeping the plug from going in.  I initially tested them off my drill battery, but once I wired them up it's very clear that they're amazing lights.  Once both were installed it easily lit the area around my car in my garage, and I can imagine them being just as, if not more, useful when parking in random places. Here's the mirror on the car with the LED installed as well as some lighted pictures..
Installed LED photos below.
« Last Edit: April 15, 2010, 10:39:16 PM by icspots »
                  Audio Input Thread || Key/Flip Key Thread
Chupacabra
  • Grand Am Series
  • Site Posts: 422
  • Transaction Count: (6)
  • Date Registered: April 24, 2007, 12:09:51 PM
  • Car Make: Mazda
  • Car Model: S GT Hatch-Aurora Blue
  • Car Year: 2007
Re: HOW TO: Heated mirror install, plus LED puddle lamps 56k Go Home
« Reply #1 on: February 21, 2008, 12:48:10 AM »
this is freakin awesome. you've done two things that i've wanted on my ride for a while now. thanks for the write up/walkthrough. got any pics of the courtesy lights at night? how bright are they?
Dual Tone Door Sills. Xenon Expert Pedals. LED Side Markers. Shark Fin. Fujita F5. JDM Rainguards. LED Interior Bulbs. Hotchkis Front/Rear Sway. Tein HTech. Painted Calipers. Amber Fog Overlays. Paint Match Fuel Door. Speedline Blue Tint/Heated Mirrors. LED Reflectors. MS3 Rear Valence. Stealthbox. Ally Wing Lip Spoiler. Evotion Condensor/Grounding Kit. Speedy Lite Fins. SS Brake Lines. GT Spec Rear Tie.
to do: hoodlifts, tint, MS3 exhaust, angel eyes...
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #2 on: February 21, 2008, 11:19:24 AM »
« Last Edit: November 17, 2008, 11:28:31 PM by icspots »
danielj
  • How may I help you?
  • FMVmoderator
  • F1 Driver
  • Site Posts: 15540
  • Transaction Count: (11)
  • Date Registered: February 28, 2007, 04:08:52 PM
  • Car Make: VW/Audi/Porsche
  • Car Model: GTI
  • Car Year: 2010
« Reply #3 on: February 21, 2008, 11:30:17 AM »
Terrific write-up!!
Do you know if there is a mirror kit that will allow the mirror to tilt when the car is put into reverse?
Hi Everybody :wavey:
Click here to see what I used to drive.
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #4 on: February 21, 2008, 11:42:43 AM »
Terrific write-up!!
I haven't seen any kits like that around, though I know what you're talking about as my friend's BMW does that.  The BMW has mirror presets so I think when it goes into reverse it moves itself to the "reverse" preset and then back to your current one when you're done backing up.  Since our car doesn't have presets I imagine you could wire up a timed circuit that moves the mirror down for "x" amount of time when you go into reverse, and up "x" amount of time when you go out.  Beyond that I'm not sure how you'd do it.  billm would be the guy I'd ask about wiring something like that up.
bombsquad
  • Short Track Racer
  • Site Posts: 175
  • Transaction Count: (0)
  • Date Registered: December 10, 2007, 02:28:20 PM
  • Car Make: Mazda
  • Car Model: '08 Mazda 3 Touring ATX 5-doo
  • Car Year: 2008
« Reply #5 on: February 21, 2008, 06:16:35 PM »
As usual, this is a very good write-up from icspots.  Three things that I would mention though.
1. The 3 screws on the bottom of the mirror assembly are torx type screws on newer models, I think 07+, so that should be mentioned.
2. Also I would say to cut the leads from the diodes as long as possible. You can always cut them down if they are too long, but you can't make them longer.
3. Finally, a smart tip is to not attach your spade connectors on the mirror side of your wires until they are run through the mirror and cut to length.
These are all the things that I learned from my install experience.
Grounded TB :: DIS Computer Mod :: Black Leather Interior :: Moonroof :: All-Weather Floor Mats :: Rear bumper guards :: Auto-dimming mirror w/ compass :: Polished Mazda 3 License Plate Cover :: RDX Stubby Antenna :: OEM Heated Side Mirrors (glass only install) :: 17" Miata wheels :: Dual-Tone Fiamm Horns :: Smoked reflectors
bombsquad
  • Short Track Racer
  • Site Posts: 175
  • Car Make: Mazda
  • Car Year: 2008
« Reply #6 on: February 21, 2008, 06:46:45 PM »
Also, a word of warning.  I don't know if you should run those LEDs directly to 12V.  From the website it looks like they are supposed to run at 3.5V at 80ma.  To achieve that current with 12V, you need about a 100 Ohm resistor in series.
Ohm's Law:
V = IR
R = V/I
R = (12V - 3.5V)/0.08 Amps
R = 106.25 Ohms
This would also have to be a 1 Watt resistor since P = VI and the resistor would have 8.5 V and .08 Amps running through it.
P = 8.5*.08 = 0.68 Watts
« Last Edit: February 21, 2008, 07:01:03 PM by bombsquad »
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #7 on: February 21, 2008, 07:37:30 PM »
Added
Quote
Added
Quote
:thinking:  I didn't attach my spade connectors before the wires were run.  I thought that was pretty obvious as there's a step for running wires, and later a step for attaching spade connectors, but if not let me know how I should change it.
I purchased prewired superflux LED's :arrow: http://www.oznium.com/prewired-superflux.  they come wired with a resistor, ~6-8" of wire, and are in a waterproof housing.  It seemed perfect for the application I was using.  However for someone buying plain superflux LEDs :arrow: http://www.oznium.com/four-chip-led then you certainly do need to add resistors.
Thanks for the comments, keep 'em coming.
untouchable
  • The Line Starts here...
  • F1 Driver
  • Site Posts: 23753
  • Transaction Count: (4)
  • Date Registered: December 06, 2004, 11:08:53 AM
    • http://www.azmazda3.com
  • Car Year: 2004
« Reply #8 on: February 23, 2008, 02:26:10 PM »
Nice!
bbrich57
  • Virgin1, Rally White, 5-Sp
  • F1 Driver
  • Site Posts: 3343
  • Transaction Count: (1)
  • Date Registered: February 15, 2006, 07:27:37 AM
  • ~~Nice Ass!!~~
    • MySpace.com
  • Car Model: Mz3S HB
  • Car Year: 2004
« Reply #9 on: February 23, 2008, 02:27:05 PM »
As usual, very nice write-up Spots!
Are you planning to connect the mirror LEDs to the interior lights so they come on w/remote unlocking, or some where else?
Resident curmudgeon and smartass
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #10 on: February 23, 2008, 11:25:29 PM »
Yup, that's what I did.  They're wired to come one when:
-I unlock the doors via the remote
-I open a door
-I turn off the ignition
Basically every time the map lights come on other than when you push the button for them.  I think after some trial and error that I'm going to redo the LED wiring at the mirror and just run a wire out like bigblunt did.... I've been having some intermittant issues that I think I can attribute to the not-so-perfect pin/receiver set up.
bbrich57
  • F1 Driver
  • Site Posts: 3343
  • ~~Nice Ass!!~~
    • MySpace.com
  • Car Year: 2004
« Reply #11 on: February 24, 2008, 12:25:21 AM »
That's G-R-E-A-T Man!!  Good job!!  I think that's what I woud've done too... and now you've got me thinking about doing it.
:hornets:
« Last Edit: February 24, 2008, 12:26:42 AM by bbrich57 »
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #12 on: February 24, 2008, 11:31:08 AM »
:hornets:
Do it man do it!  Really aside from running the wires through the door boots the install was pretty easy.  I got a 8-position barrier strip from radio shack which I mounted to the right side of the shifter mount (the black thing).  So all the power/grounds run there and then the LED wires pick it up.  It looks pretty clean.  I also rewired my blue accent lights and ran them to the strip as well so that all the wiring's in the same place.
elsosa2007
  • Short Track Racer
  • Site Posts: 103
  • Date Registered: February 24, 2008, 10:15:47 PM
  • Car Make: Mazda
  • Car Model: 3 hb
  • Car Year: 2005
« Reply #13 on: February 24, 2008, 10:21:54 PM »
why did you add the 2 pins alone, do they connect one way or another to the wire loom for led to work??
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #14 on: February 24, 2008, 10:40:32 PM »
I added four pins to the mirror side of the plug (2 for the mirror, 2 for the LED).  On the car side of the plug there were five receivers for the pins on the other side (2 for the heated mirror, 3 for mirror movement).  Since I added more pins on the mirror side for the LEDs and there wasn't anything opposite them I had to add something for them to make contact with on the car side of the plug.
corwest
  • Zoom Zoom.
  • Short Track Racer
  • Site Posts: 223
  • Date Registered: February 22, 2006, 08:01:28 PM
  • Forum Member
  • Car Model: 2008 GT Galaxy Gray
  • Car Year: 2008
« Reply #15 on: February 25, 2008, 03:11:45 PM »
So my question is how do you get the damn wires through the door boot? I cant find where it comes in to the car.
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #16 on: February 25, 2008, 06:55:35 PM »
That was definitely the tricky part.  I stole this picture from another old thread but I'll point out a few things.
First thing is to give yourself a bit of room to work with.  The piece of rubber going up the front of the door can be slightly released by carefully prying loose the little plastic clips that hold it in place with a little screwdriver.  You can just barely see one to the left of the buldge above where he's holding the rubber piece, and there were a couple more below that I popped loose.  Next pull the rubber piece he's holding off of the white plastic, and use the screwdriver to pop the clips holding the "face" of the plastic channel on (you'll know what I mean when you're looking at it).  Next you have to pry the rubber boot off of the connector where it goes into the car, and once removed the connector will be loose in the hole.  Now get some stiff wire or a hanger (I used some 18 ga solid core copper wire) and feed a piece through from the door side of the white piece next to his hand.  You'll be able to see the wires at the back of the white piece when you pull back the piece he's holding and where they go into the accordian part of the boot.  Try and feed the wire as far up the boot as you can, but the way I pulled it through the top was by sticking a finger down from the other end and hooking my finger over the end.  Okay now you have the wire through the rubber boot, but how do you get it into the car.  There's a spot on the white connector that you can stick a wire through without any modification, but it's difficult to find.  On the passenger's side it's on the top forward section and on the driver's side it's on the top back section (same plug but different sides of the car).  I was able to feed my guide wire through and tape the power wire to it, but the hole was too small for the taped bundle.  I ended up having to actually stick the wire through very carefully (once I was sure of where the sweet spot was) and then I reached my other arm into the dash towards the jam.  The passenger's side was easier since I could remove the glove box, but it was still a bit of a reach.... basically reach in as far as you can until you can feel the wires on the back side of the harness and jiggling it makes the white plug in the door move.  Feed the wire in carefully until you can grab it from the inside and pull it through.  The driver's side works the same way except: A) there are a whole lot more wires in the bundle so it's a bit more difficult to get the guide wire through the bundle, and B) you can't remove as much of the dash to reach from the inside.  I ended up buried almost up to my shoulder and could just barely reach the wires on the inside.
Now the fun part is putting things back together.  The door side of the boot (the thin rubber thing he's holding in the picture) goes back on relatively easily with a bit of TLC, however the other end of the boot where it connects to the white plastic connector on the car is the biggest PITA you've ever imagined.  It helps if you can reach one hand from the inside and push the white part outwards in order to give the rubber enough room to fit around it.  Basically just work it around as well as you can tugging/pushing/pulling.  On both sides I was about ready to tear my hair out when it all just popped back into place.  I was having more trouble applying pressure on the driver's side so I ended up pushing against the inside with a mini-mag since it was harder for my hand to reach the plug.
Hopefully that made sense. :)
maxuz
  • wM9 "Cedar Teeth"
  • F1 Driver
  • Site Posts: 3127
  • Transaction Count: (5)
  • Date Registered: June 30, 2006, 09:03:38 PM
  • I'm talking bout O-Town
  • Car Make: Mazda
  • Car Model: RX-8
  • Car Year: 2004
« Reply #17 on: February 25, 2008, 07:06:08 PM »
holy crap great writeup.  subbing.
2 rotors, 0 pistons, 100% angry weed eater
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #18 on: February 26, 2008, 07:36:03 AM »
Thank you. :)
elsosa2007
  • Short Track Racer
  • Site Posts: 103
  • Car Make: Mazda
  • Car Model: 3 hb
  • Car Year: 2005
« Reply #19 on: February 26, 2008, 11:08:00 PM »
can you email me at elsosa2007@hotmail.com//
so that's how led go on ha??is there any other current that can be used??
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #20 on: February 27, 2008, 11:14:19 AM »
e-mail sent.
iirc the only other power in the door is that for the windows/locks/mirrors.  All of that should be hot with the ignition.  I didn't want white lights shining down next to my car while I was driving around, rather just when I'm getting into/out of the car.
ckong1
  • Grand Am Series
  • Site Posts: 260
  • Transaction Count: (8)
  • Date Registered: March 11, 2007, 06:13:18 PM
  • Car Model: Mazda3 S-Touring
  • Car Year: 2007
« Reply #21 on: February 27, 2008, 09:56:31 PM »
wow this is great... where did you buy the mirror parts?
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #22 on: February 27, 2008, 10:17:33 PM »
I purchased the mirror glass from bagman1 (aka Jason our forum sponsor from www.onlinemazdaparts.com).  He was one of the big helps in figuring out that we could do this mod in the first place and has always given me fantastic service.  Everything else just came from Radio Shack.
jimmycoop2005
  • Short Track Racer
  • Site Posts: 116
  • Date Registered: February 21, 2008, 01:02:33 AM
« Reply #23 on: February 28, 2008, 01:43:05 PM »
IC you are a genius man!! Must be that Virginian in ya haha jk, since you are so close you will have to help me do this haha j/k
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #24 on: February 28, 2008, 04:39:36 PM »
Thanks, however billm was the real pioneer of the glass only replacement.  If you want to figure out a time then I'm more than happy to help you out, though it really is quite easy.
jimmycoop2005
  • Short Track Racer
  • Site Posts: 116
« Reply #25 on: February 29, 2008, 01:05:40 AM »
I'm not very good with this stuff, so yeah maybe one weekend I can go your way. do you have fixed with the interior lights so when you unlock your door they come on and lock it they go off?
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #26 on: February 29, 2008, 10:00:06 AM »
Yup.  This is how they work.
Lights turn on when:
-I unlock the door via the remote
-I open the door
Lights turn off when:
-I lock the doors via the remote
-I turn the ignition to ACC/ON
-After they've been on for a set time (I think it's 30sec to one minute) after the last thing that triggered them.  So if I leave the door open they'll be on for that set time and then turn off.  If I open another door then they'll turn back on.
jimmycoop2005
  • Short Track Racer
  • Site Posts: 116
« Reply #27 on: March 01, 2008, 01:04:31 AM »
sweet man good deal.
ckong1
  • Grand Am Series
  • Site Posts: 260
  • Car Year: 2007
« Reply #28 on: March 02, 2008, 06:22:38 PM »
which tab is positive and which is negative on the glass?  or does it not matter?
icspots
  • FMVmoderator
  • F1 Driver
  • Site Posts: 13133
  • Paramagic
  • Car Make: Ford
  • Car Year: 2005
« Reply #29 on: March 02, 2008, 06:31:48 PM »
I believe the green is positive and the black is negative, however the posts on the glass aren't marked so it shouldn't really matter.  Kind of like on a car horn.  You need power on one and ground on the other and it doesn't matter which.
