ATF MV vs Dexron III - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 16 (permalink) Old 05-31-2011, 05:31 PM Thread Starter
Hi guys,
This question might have been asked a couple of times before, but the truth is I haven't been able to find a definite answer.
Is ATF MV equal to Dexron III?
'07 Black Mica 3s (Mexico)
'10 Gray 3i Sport (USA)
robtrevino is offline
post #2 of 16 (permalink) Old 05-31-2011, 05:49 PM
Re: ATF MV vs Dexron III
Short answer is probably not.
Longer answer is that ATF-MV is pretty close to Mercon V, except that ATF-MV has a higher anti-shudder property than Mercon V (I believe anyway, don't quote me on that). Dexron III is similar to Mercon, and Mercon is different than Mercon V, so Dexron III isn't probably a good replacement for ATF-MV.
IBrakeForNobody is offline
post #3 of 16 (permalink) Old 06-01-2011, 04:50 PM Thread Starter
the reason I ask is this:http://www.bobistheoilguy.com/forums...697&page=2
Please read the first post of that page
post #4 of 16 (permalink) Old 06-01-2011, 05:42 PM
Maybe I or that poster have different or outdated service manuals, but I wasn't able to find anything. This obviously isn't every document in the service manual that states the fluid type, but I read through the entire section and didn't find any special notes or anything.
[img width=352 height=768]http://img.photobucket.com/albums/v172/cayun/Mazda3/cf8098c5.jpg[/img]
Mazda did release a service bulletin regarding Mazda ATF-MV and Ford Mercon V, but it doesn't mention anything about Dexron III.
http://www.finishlineperformance.com...05-08-1928.pdf
post #5 of 16 (permalink) Old 06-01-2011, 06:02 PM Thread Starter
wow, cool. Thanks for the detective work.
post #6 of 16 (permalink) Old 06-01-2011, 07:49 PM
Moderator
DrWebster's Avatar
Our transmissions are fairly picky about fluid, and are certainly quite hard on it...I'd only use fluid that specifically says it's M-V compatible (not just Mercon V). Mobil 1 Synthetic ATF has worked quite well for many folks around here, myself included.
DrWebster is offline
post #7 of 16 (permalink) Old 06-03-2011, 12:59 PM
I saw this posted elsewhere on the forum, but this seems like a good place to post.
How about this fluid?
http://www.amazon.com/Red-Line-30504...825&sr=8-1
They have 4 and 12 packs available too.
I'd want to keep away from the Mazda Fluid, as it goes bad very quickly (at least the stock stuff did).
ryann is offline
post #8 of 16 (permalink) Old 06-03-2011, 01:53 PM Thread Starter
seems very expensive, specially since Mobil 1's is like 25% cheaper no?
post #9 of 16 (permalink) Old 06-03-2011, 07:00 PM
I have Mobil1 in my car right now. It's not the right kind, is it?
ryann is offline
post #10 of 16 (permalink) Old 06-03-2011, 07:05 PM
Moderator
DrWebster's Avatar
[quote author=ryann link=topic=191508.msg4040283#msg4040283 date=1307142021]
If it's Mobil 1 Synthetic ATF, then it's just fine -- it's rated as being compatible with ATF M-V. I've been using it since I had 30k on the car, and the car has 82k on it now.
