How to : Coolant flush + Install of new Radiator hoses - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 58 (permalink) Old 02-20-2009, 01:00 AM Thread Starter
Send a message via AIM to TEKWATCH Send a message via Yahoo to TEKWATCH
I am going to cover my version of a Coolant flush and installation of new Radiator hoses.
Another great write-up ( Provides more technical information ) - http://www.flex-innovations.com/coolant.htm
Materials needed:
1 - flathead screwdriver
1 - 10 mm wrench
1 - pair of pliers
1 - pair of locking pliers
1 - Drain funnel
1 - Drain pan or 2 empty Milk jugs or both
1 to 2 - Gallons of coolant ( see your owners manual )
10-15 - various wrenches, pliers, you will see LOL!!!
UPDATE - Replace the pressure clamps with all new screw style metal clamps, they will keep your hoses from leaking.
So I ordered a set of those nice new OBX radiator hoses from our forum sponsor :
Darkstar Motorsports
Plus they came in blue so how could I resist.
Well if you replace the hoses you have to drain the coolant. I figured this was the perfect time to do both and be done with it.
I have to admit, this took me a lot longer than I planned ( 6 hours ), ran into a few snags with hose clamps both removing and re-installing them, very tight spots to work in and having huge hands does not help. Plus taking 40 plus pictures and several breaks.
Actual work time - approx 2 hours.
Tip - take your time and breath, don't do like me and yell and get crazy, also helps if you do not listen to Death Metal, wait I did not do that
Also drain 2 times for a more complete flush, this was not needed for my car, coolant was not that dark.
Anyways lets begin.
I started by getting the car up on the ramps, I had to use 2 x 4's because I am lowered and my car will not clear the ramps without a little help. You can jack the car up, but extra clearance is needed for a drain pan and removal of hoses. If you have a lift, your golden.
Next - remove the lower splash guard, lots of 10mm bolts, you may have to remove the front lower guard as well, mine is removed already.
Locate the drain valve.
I removed the coolant fill tank for easier access to the lower hose and to completly drain. This is optional, I just wanted to do it. There are 2 clips on the frame which hold this in place, easy to remove, just press on them with your thumb or use a flathead screwdriver. Pull straight up.
Here is the spot where the coolant tank sits.
[img width=576 height=768]http://i83.photobucket.com/albums/j287/TEKWATCH/RAD%20HOSES/DSC06440.jpg[/img]
Special thanks to:
http://www.darkstarmotorsports.com/
They provided the OBX Radiator hoses.
Double Layer Reinforced Performance Radiator Hose Kit
Gave your Mazda 3 more effective flow & cooling during hard driving conditions, when stock factory rubber hose get hot so the rubber hose collapse cause a shortage flow inside your radiator. By having this part installed will max out your car's cooling potentials !!!
Compound by both EPDM material and 2 Layun mesh layer woven. Double wrapped provide high endurance and reliability. Double layer pressure bearing 10Kg/ 1cm², 150% stronger than OE rubber hose. No necessary to worry about the high temperature or pressure will broken your upgrade radiator hose during long time driving or high turning.
Direct replacement for the Mazdaspeed 3 or Mazda 3 (2.3L or 2.0L) Radiator Hoses
Colors; Red, Blue, Black
Eortiz3 likes this.
[b]
TEKWATCH is offline
post #2 of 58 (permalink) Old 02-20-2009, 01:14 AM
Re: How to : Coolant flush + Install of new Radiator hoses
Wow. Really great writeup. +1 for a sticky. Great prices on the hose too.
mattjackson86 is offline
post #3 of 58 (permalink) Old 02-20-2009, 02:33 AM
Send a message via Yahoo to darkstarmotorsports
Great write up!!
1+ for sticky
For the FASTEST Customer Service....
darkstarmotorsports is offline
post #4 of 58 (permalink) Old 02-20-2009, 10:37 AM
your car is so clean and nice. but nice right up!
|Bc Coil-Overs|SPC Rear Camber Kit|8k HID Lows and Fogs| 7k Angel Eyes| 17x7.5 Speedy Lite-Fin Wrapped in 225/45/17 General Exclaim UHP| Custom Interior- Painted pillars, Door panels two Toned Black and Red Suede, Black Leather Headliner|
Carowen is offline
post #5 of 58 (permalink) Old 02-27-2009, 08:54 AM
Send a message via AIM to mshu7
Thanks for the great write-up!
Thread STICKIED!
Mike Shumaker, Owner
Serving Central Indiana & Surrounding Midwestern Areas
Authorized Pro Coating Installer
My source for auto detailing products:
mshu7 is offline
post #6 of 58 (permalink) Old 02-27-2009, 04:26 PM
Good writeup,
As a suggestion, maybe you should provide a link to my walkthrough which provides more technical knowledge and information directly from the factory manual for those that want to make sure they don't introduce air into the system or use the wrong type of coolant.
Or I think I posted the walkthrough on this forum somewhere as well...
Anyways, those hoses look pretty sweet.
HouRman is offline
post #7 of 58 (permalink) Old 02-27-2009, 05:40 PM Thread Starter
I will add the link now, and I used your writeup as my Direction on how I did mine basically.
Thanks!!!
[b]
TEKWATCH is offline
post #8 of 58 (permalink) Old 03-03-2009, 02:14 PM
when its time to do mine, I'm getting those hoses. I've got an Aurora Blue HB so those blue covers would come in great
How did you paint the blue engine cover? That's not powder coated is it?
vtrin is offline
post #9 of 58 (permalink) Old 03-03-2009, 04:58 PM Thread Starter
[quote author=vtrin link=topic=136818.msg2973523#msg2973523 date=1236107659]
I spraypainted my engine cover just like everyone else does on these forums. I used Metalspec Blue and clear.
I have another engine cover waiting to be painted, I am going for a gloss look next time with a different design.
[b]
TEKWATCH is offline
post #10 of 58 (permalink) Old 03-24-2009, 05:00 PM
What about purging the air?
tronix102 is offline
