P0455 code - alert - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 09-05-2008, 08:26 AM Thread Starter
LMO
P0455 code - alert
I want to say thanks for the help I've recieved over the last couple of years here by alerting my fellow readers to a common condition in 2004-6 Mazda 3's.
It starts with an intermittent "soft" p0455 code when you check engine light appears- you can kill it off then because the condition is intermittent at the start. Eventually the code goes "hard" and you're at the dealer getting the evaporative solenoid valve replaced along with the gas cap. The dealer I go go even had the parts in stock because the tech said it is so common.
I was lucky- I caught it 2K miles before the warantee expired and saved about $300. If your cel goes on - and even if you can kill the P0455 code at first- get to the dealer. It's more than a lose gas cap- it's this common problem in the evaporative system.
There is a tech bulletin on this for the techs- they are very familiar with the problem.
Hope this helps!
LMO is offline
post #2 of 5 (permalink) Old 09-23-2008, 10:42 PM
Re: P0455 code - alert
What was the solution to your problem?
Symptoms and code are similar to mine. I have replaced the "purge solenoid valve" but CEL is back on.
My codes were p0442 and p2177 (if I remember well).
Car runs fine but I think it uses a little more gas.
Mazda 3
2.0
2004
98000 km
blabla08 is offline
post #3 of 5 (permalink) Old 09-29-2008, 10:20 AM Thread Starter
LMO
Two things needed-
1. new purge valve
2. new gas cap
The tech ran a smoke test to find the leaks.
LMO is offline
post #4 of 5 (permalink) Old 09-29-2008, 10:36 AM
Send a message via MSN to WinningBlueMica`05
I had these same codes on my `05 and replacing the purge valve did the trick for me
WinningBlueMica`05 is offline
post #5 of 5 (permalink) Old 10-04-2008, 11:13 PM
Thanks guys, I will try with new gas cap and see if it fixes it.
blabla08 is offline
