DIY Cabin Air Filter Change: How-To Guide w/Pics - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 369 (permalink) Old 12-02-2007, 01:16 AM Thread Starter
I replaced my cabin air filter today in my 2006 Mazda3. It has 45,000 miles, I've never had this replaced before, I live and drive around Chicago, the car is garage kept. With picture taking, it took about 4 hours. I had searched through these boards in the past to find a good write up on the cabin filter, but no real good one existed. These boards rock when it comes to How-To's so I figured I'd grab my camera, some tools, and document my experience. I had to stop after taking the passenger’s side all apart and re-read some posts because I couldn't find the filter! These boards have helped me with plenty in the past, but have not done too well with the cabin filter. So to you, fellow DIY'ers and forum members, and cabin filter want to replacers, here is YOUR guide:
Tools needed:
1) Philips head screwdriver
2) Flat head screwdriver
3) Long nose pliers
4) 12mm socket head and ratchet with extenders
5) shop-vac
Here's my replacement filter (I paid $37.35 for it at my local dealership):
Open the glove compartment door:
Remove the plastic trim by pulling up underneath the trim from where the glove compartment door closes. NOTE THE HOOK AT THE RIGHT END OF THE TRIM! Don't expect the trim to first pop off from the right because it first pops out from the area over the glove compartment, then bows out, and carefully pull back to completely remove:
Unscrew the two screws with the Philips head:
I have the navigation system, thus the DVD player in the glove compartment makes this next step pretty difficult. You'll have to first pull out and down from the top of the glove compartment and carefully wiggle out:
Once unlatched, you'll notice the lamp. I unscrewed it out:
There a plastic cover, right above the passenger's feet, that's held up by two tabs. Tough to explain, but too easy to remove. Push the two tabs towards the front of the car, pull down, viola:
There another plastic cover to the feet's left:
Use the flat head to pry the center plug a bit. CAREFUL, don't pry the outside plug or you'll risk scratching everything and not accomplishing anything:
There two twist plugs holding up the fuse box. Give each about 1 turn and the fuse box is loose:
Unplug each of the connectors to the fuse box by turning the black loop by 180 degrees. This was a bit tricky, but once you see how it works, it's a piece of cake to do the rest:
Use the ratchet with the 12mm socket to remove the two nuts from the fuse block bracket. I used two extenders to make removing them easier. There were tightened to about 980 lbs. Seriously, they were pretty tight.
Move the bracket and plugs away from the center console, as that's where we’ll be working next. I found that by removing the gray cable tie (in picture) from the fuse block bracket (with pliers) gives plenty of lee-way to maneuver the bracket and plugs away from the center console.
Remove the two screws holding the black sensor:
Unplug the white sensor connector, move both out of the way:
Remove the 4 screws holding the white plastic cover:
Slide out the bottom cabin filter (there's two, one on top of each other), then slide out the top one that falls after you take out the bottom one:
Here's what the inside looked like BEFORE I cleaned it out with a shop-vac and a windexed cloth:
Here's what it looked like AFTER:
Here are the old filters above the new filters. Yes, folks, I had a tough time believing this. It made it all worth it:
This part was tricky. You have to slide the top filter in first:
Now slide it up, use your magic powers to hold it up, then slide in the bottom filter. Oh wait, I didn't have any magic powers handy! Somehow, I got it anyway:
Now put everything back in the way you took it out and congratulate yourself on a job well done. Here's my only casualty.
pkokkinis is offline
post #2 of 369 (permalink) Old 12-02-2007, 01:17 AM
Re: DIY Cabin Air Filter Change: How-To Guide w/Pics
oh thats nice
j-easy is offline
post #3 of 369 (permalink) Old 12-02-2007, 01:42 AM
Great writeup and excellent pics. I should be replacing mine soon (once it gets warmer).
sorry to hear about the broken connector. Hopefully you can get away without replacing it.
work to live
tonyzoomzoom is offline
post #4 of 369 (permalink) Old 12-02-2007, 10:18 AM
Send a message via AIM to chaos4 Send a message via Yahoo to chaos4
WOW! 4 hours!!! Since my dealer only charges $150 (including filters), I am sure there is a way to do it in an hour or less. What is your take on that?
MS CAI, MS CBE, Yellow Racing Coilovers, Hotchkis fonrt and rear sways, Enki RP01 17" with Hoosier R6 (track), AutoPower Race roll bar, GeForce 6 point harness, Cobb mild tune, 278 whp, 310 wtq on a Dyno Dynamics (heart breaker) dyno, Autometer Cobalt boost, oil pressure and oil temp gages. COM SCC 2007, 2008, 2009 and 2011 ST2 Class Champ. Chief of Event Operations, COM SCC
Come race with us!
chaos4 is offline
post #5 of 369 (permalink) Old 12-02-2007, 04:37 PM Thread Starter
Next time should take me about one hour. I could probably do in a half hour if I rushed and had a wall of spare parts at my disposal, like dealers do.
post #6 of 369 (permalink) Old 12-02-2007, 05:26 PM
There is also this write-up on changing it as well which is basically the same thing, but by-passed removing the glove box.
http://www.mazda3forums.com/index.php?topic=22427.0
spikeymike is offline
post #7 of 369 (permalink) Old 12-02-2007, 10:53 PM Thread Starter
I must've missed that write-up somehow. I'm glad I did because I probably wouldn't of removed my glove box, but, in not doing so I would've made this a lot tougher project. Removing the glove box allows better access to the two top screws to the filter compartment, and, you can reach one arm in through the glove compartment area to do your work, as opposed to laying on your back and loosing feeling in your right arm.
post #8 of 369 (permalink) Old 12-03-2007, 07:38 AM
Do you think Mazda could have screwed this location up any worse?
5 Mins to change the filter out in our Accord. Same with the Civic I traded in on the 3.
Im not looking forward to this task at all.
O-Well
psyshack is offline
post #9 of 369 (permalink) Old 12-07-2007, 02:05 PM
Send a message via AIM to Three3Mafia
Good DIY, im due for an air filter change too...not looking forward to the install at all, though it must be done rather than being raped by the stealership.
CHEAP ASS MODS List = Red Painted Engine Cover / Stubby Antenna / Red Painted Door Switch Panel / Mazdaspeed Valve Stem Caps / Hello Kitty Foam Sticker on Dash (the girlfriend's mod)
Three3Mafia is offline
post #10 of 369 (permalink) Old 12-07-2007, 03:24 PM
Send a message via AIM to mshu7
Nice write-up. I've changed mine a couple times. No need to mess with the glove box.
Mike Shumaker, Owner
Serving Central Indiana & Surrounding Midwestern Areas
Authorized Pro Coating Installer
My source for auto detailing products:
mshu7 is offline
