DIY How-To Repair Rock Paint Chips COMPLETE with Pictures *Updated 3/18/2012* - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 123 (permalink) Old 11-24-2007, 11:27 PM Thread Starter
[size=10pt]
Repairing Rock Chips on your Mazda
By: Tronix102
Email: tronix@xenonflux.com
Web: www.xenonflux.com
PDF Document:
https://docs.google.com/fileview?id=...thkey=CKrgtMQI
[size=10pt]Tools & Materials needed:[/size]
- Touchup or color matched paint - google touch up paint
- Clearcoat (optional) - auto parts store
- Primer - auto parts store
- Rubbing Alcohol - cvs
- Small sanding block or piece of wood
- 1200, 1500, 2000 grit automotive sandpaper - auto body or parts store
- Small bowl
- Compound – 1000 grit remover, 2000 grit remover (optional) - some auto parts store has them or auto body has all this
- Orbital Buffer (optional – but makes it easier) - look online
- Paper cup
- Toothpicks
1.) Start by cleaning the chip and surrounding area with rubbing alcohol to get rid of grease, dirt, etc.
2.) Depending on what kind of paint you have you will need a paper cup to hold some. Since I have a spray can, I sprayed some in the cup. If you have touch up paint in a little bottle you don’t need a cup
3.) Break the toothpick so it doesn’t have a sharp point anymore and dip it in the paint and let it drip into the chip. You can do the same for this if you have a brush for the touch up paint bottle.
4.) You will want to repeat this process several times so you form the paint above the chip like in the picture below: **Note, if you want to use clear coat, use clear coat before the paint *blob* goes above the surrounding surface, and just build up clear coat to sand off like you would with just building up paint. The clear coat will be what you sand off and not the paint so make sure you only do a few coats of paint and the rest clear if you desire this.
5.) If you are worried about getting paint everywhere, you can tape around each chip:
6.) Yah I have a lot of small chips as you can see.
7.) Next comes the sanding. Make sure you soak your automotive sandpaper for 24 hours in water prior to using.
8.) Take your block of wood and wrap the sandpaper around it shown here:
9.) You will want to sand in a back and forth movement until the “blob” of paint is no longer visible and the surface is smooth again. Take your time, as this process is time consuming. Keep the surface wet, and dip your sandpaper in water frequently to clean off paint and to keep it wet.
**See picture above, I didn’t put enough paint so you can still see the chip after sanding
10.) At this stage you can either apply clear coat to the chip area and re-sand or just buff the scratches out which I did because I don’t have patience.
11.) If you buff by hand, apply compound to a micro fiber and rub back and forth until the surface is glossy again.
12.) And there you have it, a complete how to repaint paint chip guide. Some things I didn’t use was primer. If the chip is down to bare metal, you would use the same process as dipping the tooth pick in primer and putting a drop on the chip so the paint will stick.
13.) Put a nice coat a wax on after you buff since it will remove all wax that you “buff” off the car.
For all those that would like a PDF version, I have made one available here for download. http://www.xenonflux.com/Repairing_R...your_Mazda.pdf
Good luck all, I hope this helps.
Thanks to Design for this:
Here are a few things to help you out. :smokin:
1. Paint prep pen: Great for smaller chips where you don't want to scratch the surrounding paint. They come in a variety of grades.
2. Syringe: I think you need to be 18+ to get this... but it works great for thin, hairline scratches. Fill the syringe with touchup paint of choice then apply a thin, even coat across the affected area.
3. Patience, patience, patience: Touching up paint the right way can take several days. Not only do you need to wait 24 hrs after you apply the primer, but you also have to do the same for each layer of touch-up paint you apply. For deep chips, you may have to apply 6-7 coats to effectively match the top surface area. The top layer should be barely above the surrounding area, so when you sand it down it will closely match in thickness.
Hope this helps.
AntBee likes this.
tronix102 is offline
post #2 of 123 (permalink) Old 11-24-2007, 11:55 PM
Re: DIY How-To Repair Rock Paint Chips COMPLETE with Pictures
Thanks! This is really helpful, I've got a few chips I'll take out using this. I'll probably even put up before/after shots too.
brandonv is offline
post #3 of 123 (permalink) Old 11-25-2007, 08:52 AM
Send a message via AIM to laraw
This is an AWESOME thread. I'll be trying this someday soon.
+1000 for a sticky.
2007 Mazdaspeed6 GT in Black Mica
AutoEXE | Cobb | Corksport | Gram Lights | H&R | HKS | SURE | TWM
laraw is offline
post #4 of 123 (permalink) Old 11-25-2007, 09:22 AM
STICKY!!!!
El Boris of Puerto Rico
2006 Mazda3 2.3L ESL
RockBlocker & 42% Tinted Windows|VG Shark Fin Antenna|Flip Key|OEM LED Tails|LED License Plate Bulb|Color-keyed Vent-Visors, Rear Roof Spoiler, Eyelids & Sporty Fuel Filler Door|OEM AUTO LIGHT sensor|3rd LED Brake Light|Lower door mouldings|FUTURE MODS: OEM Auto-folding side mirrors, auto-dimming + Homelink mirror
ahmed1rusty39 is offline
post #5 of 123 (permalink) Old 11-26-2007, 03:27 AM
Keep in mind that if u do not have a machine polisher I highly suggest that you do not use sand paper on your car.
The cyclone pictured is supposedly going to do a faster job than a Porter Cable DA polisher so if you are not experienced at removing 1500-2000 grit sand paper haze from paint then do not try this.
Just mask off the chip with tape, and paint INSIDE the crater, then let dry. I just know that sanding can make a chip look worse if u can't fix it.
HouRman is offline
post #6 of 123 (permalink) Old 11-26-2007, 10:37 PM
NICE!!! STICKY!!!!
d-machine is offline
post #7 of 123 (permalink) Old 11-26-2007, 10:52 PM
Send a message via AIM to chris17house Send a message via MSN to chris17house
Makes me realize just how badly i need to go buy a porter cable.
Sticky this thread. There is nothing like it on the forums.
chris17house is offline
post #8 of 123 (permalink) Old 12-05-2007, 05:12 PM Thread Starter
post #9 of 123 (permalink) Old 12-06-2007, 01:19 PM
How much is "too much sanding"? if you sand you will remove the clear coat? I have a lot of chips on my door, and my car is black, any suggestions?
thx!
hyper-x is offline
post #10 of 123 (permalink) Old 12-06-2007, 01:35 PM
john_in_the_lbc's Avatar
yes, it's very important to go slowly and not sand completely thru the clear coat. Inevitably, you will remove some of the clearcoat when sanding.
to the OP: Great post...the forums have been needing this.
My car thread
john_in_the_lbc is offline
