Spare Keyless Remote Self-Programming - How To Guide - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 182 (permalink) Old 06-26-2004, 02:45 PM Thread Starter
dhl
I found this on the Mazda6 forum and it works for the Mazda3:
http://forum.mazda6club.com/index.ph...mp;#entry55368
Yes, this does work and I actually used it to program a 3rd remote for my Mazda3i (with power door locks). *8)
*NOTE*
Have all the remotes that you are going to be using, maximum of 3, with you when you do this programming as all of them have to be reprogrammed into memory.
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. *Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. *ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Sticky this please...
NOTE: Sticky it is. Should it be here or in another section, like the one where you learn how to program a key? Dinu
My 2004 Mazda3i Totaled 10/15/2008. R.I.P.
dhl is offline
post #2 of 182 (permalink) Old 06-26-2004, 11:21 PM
Sounds like a whole lot of useless steps.
1998 Automatic Sandlewood Mazda Protegé LX 1.5L - purchased fall 2000
98LX is offline
post #3 of 182 (permalink) Old 06-26-2004, 11:26 PM Thread Starter
dhl
Originally Posted by "98LX"
Sounds like a whole lot of nonsence.
Yeah, sure does sound like a lot of nonsense until you have to program a 3rd remote. Then you discover it works. 8) The other instructions that were floating around here were for the Mazda Millenia and a few other Mazdas, but they don't work; the MZ6 instructions do work for the MZ3. Though I think you need power door locks for this to work, which I do have, but someone without power door locks will have to tell us if it doesn't work for them. You can test it out yourself to see if it works and post your results, but I know for sure it worked for me.
dhl is offline
post #4 of 182 (permalink) Old 06-27-2004, 11:33 AM
Send a message via AIM to heliotropic
Uh, if you don't have power door locks how is a keyless remote going to work in the first place?
heliotropic is offline
post #5 of 182 (permalink) Old 06-27-2004, 02:37 PM
is there ways to program in to open all the windows as well? or close the sunroof?
Mazda3 GT Sport Auto/Sunroof/AC/Leather
icecube is offline
post #6 of 182 (permalink) Old 06-27-2004, 03:10 PM Thread Starter
dhl
Just covering all my bases, you know someone with out power door locks will eventually ask how to program a keyless remote.
dhl is offline
post #7 of 182 (permalink) Old 06-27-2004, 05:10 PM
Do you buy an unprogrammed remote from the dealer?
Or are aftermarket remotes compatible?
ando is offline
post #8 of 182 (permalink) Old 06-27-2004, 06:05 PM Thread Starter
dhl
You can buy it from the dealer or buy the same ones off of ebay.
dhl is offline
post #9 of 182 (permalink) Old 06-28-2004, 12:56 AM
Thread re-open. My bad. sorry guys.
ONLY QUALITY HID KITS!!
M3-GT is offline
post #10 of 182 (permalink) Old 06-30-2004, 11:58 PM
can someone let me know what is the model number of the remote you guys in NA has?
I'm buying a remote for the Protege off eBay and the model number of the remote is 41706.
The remotes we have in Singapore does not come with the panic button and is labeled Model number 41835 on the casing and model number 41803 on the PCB.
I'm trying to see if this programming trick works for SG MZ3s.
Thanks in advance.
limck is offline
LinkBack to this Thread: http://www.mazda3forums.com/95-maintenance-care/208243-spare-keyless-remote-self-programming-how-guide.html
visteon model number 41835 This thread Refback 03-09-2017 05:46 PM
programmer manette - Mazda 3 Quebec This thread Refback 11-18-2015 11:39 AM
2013 Mazda2 key programming - Mazda2Forums.com This thread Refback 11-12-2015 08:45 PM
